I also started working on the chassis, as I need to plan for the couplers and their height:
The platforms on each end will have to be strengthened to be capable of accommodating some pulling. Again, OCCRE thought in terms of static model, here. The height of the platforms is also too large, due to the excessive size of the trucks. We will have to be creative....
Yves
Yves, good plan to be able to operate this car in a train. Will the wheels have enough side play to allow the trucks to roll smoothly into and thru a curve? I know in HO and N, there is a little wiggle room in the trucks.
Ken
Started: MS Bounty Longboat,
Some small progress. Second truck built and rolling very smoothly:
These trucks are crude overall, and I hope that once painted, they will look a little bit better. The modification I brought, allows them to roll freely and behave so much better on a layout than the original design, created for static purpose.
Overall view of the car (above). Again, I find the trucks slightly oversized..... Just my opinion.
I built the end platforms and I am waiting for some KADEE couplers to finalize them. Height and strength have to be adjusted very precisely.
The car is sitting high and the couplers will be located underneath the platforms, which is conflicting with the location of the bumpers and usually, where the European couplers are located. I will try to come up with a decent solution.
Third Class seats..... You should really bring your own cushion or have a fat bottom...
Honestly, I'd rather pay a few more pesetas and travel in Second Class.....
The instructions booklet is superb: glossy paper and full colors.
Hope you are enjoying this trip in the early 20th Century Cataluna.
Yves
I have never travelled 3rd class on any railway - this had long been abolished in my part of the World. However, trams used to have similar seats (on some older trams e.g. in Vienna they are still in use today, I believe) and I found them more comfortable than many modern plastic seats, particularly when the latter are formed like the negative of your bottoms and only allow you to sit in one position. I gather, the 2nd class seats are only better than the wooden ones as long as they are not sat through ...
I am not a railway expert, but would agree that bogies look rather high. I wonder, whether there are not any drawings of these coaches to be found on the Internet for verification.
Yves, do you have a coupler height gauge for this scale? Kadee makes one.
Looking at the truck bolster(round pad) and the car bolster, sanding is an iffy proposition to lower the car height. Does Kadee make offset couplers in this scale?
Ken
I am now working on the window frames, which is a very tedious work. Especially the painting in red that requires at least three coats in all directions....
The frames are made of basswood in 2 x 2 mm.
In the meantime, the other side has been partially completed:
The original side  has all its window frames, painted:
Spaniards love the red color.... Honestly, I think it brings a nice contrast to all this dark wood.
Yves
Yves
It must be the small amount of Spain in my DNA. I like the red as well.
Really cool project Yves, coming along nicely!  Love the colors and textures involved in this project.
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    Hs129B-2 1/48  SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32   IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   CLC Annapolis Wherry  Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48  Eduard Sikorsky JRS-1 1/72
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
I've been quietly watching this very nice build - have to say that cutting all those short wood strips may have sent me to my bottle of a very  nice Irish thirst quencher. My only comment is based on what you said about the trucks and wheels:
"These trucks are crude overall, and I hope that once painted, they will look a little bit better. The modification I brought, allows them to roll freely and behave so much better on a layout than the original design, created for static purpose."
I used this search term in Google "old wood European railroad coaches". From what little I could see, the wheels are fine but the actual trucks may need some help. Yes, many of the photos that came up in that search are models  but the rest, including some European and US, are actual coaches,
I have been working on the windows of the coach and that unit has a LOT OF windows.....
First painting both sides with three coats of red. Then installing the window frames after staining them with some dark walnut liquid:
Then, fine sanding to remove all traces of the sprues links and to make the frame fit into the painted opening.... I am so glad I did not finish the interior as suggested by the instructions. If you ever do that model, do not follow the instructions. Instead, build each side of the car on a flat surface, paint, glue, smooth and finally, glue the sides to the main frame.
Also, I have decided to not glue and install the clear window film provided in the kit. I will leave everything open for a much better peek inside the coach.
Now, on to the other side.....
Yves
Finished building the luggage racks over the Second Class area:
These are very delicate to put together. CA and Acrylic (Gator) glues are your best friends.
The roof holders are now glued to the walls. That step concludes the Second Class Compartment. The only missing feature is the numerous ashtrays, usually located between the seats, right under the windows. OCCRE did not provide that small details.
There won't be any update for a while, as I need to build all the Third Class seats and build the racks above. Lot of work in perspective.
Yves
Some really cool details there Yves - great work!
Mike
Nice work on the Second Class compartment. 😄 That Gator Glue is a good product. It's really good for gluing dissimilar materials together. It retains flexibility after it sets, unlike CA which becomes brittle.
Ken
Not being ready to build all the numerous seats yet, I decided instead to look into the Clerestory section of the roof. This part of the roof is what makes this coach car so interesting.
The roof is planked like a hull would be, using 2 x 4 mm planks and a lot of wood paste to fill up the cracks:
In situ (at least almost there):
The roof fits perfectly and I am impressed by the precision of the assembly. I have also built both roof ends to receive the clerestory section.
Light are installed inside:
Now, on to the 10 third class seats. I cannot procrastinate any longer....
Yves
The roof walk/running board makes the car look like one of the passenger cars used on the Denver and Rio Grande Western branch that ran into New Mexico from Antonito, Co to Santa Fe, NM. Some of these cars had a handrail along side, also.
Ken
Denver and Rio Grand is still a narrow gauge tourist train that runs between Durango and Silverton, Colorado using cars similar as you mentioned as we;; as open cars and pulled by a 100+ year old ALCO steam locomotive built in my long time past home town of Schenectady, NY. We rode that train in 1981 and paralleled its track in 2017as we couldn't ride with our two pups. Well worth the time and ride
There 2 parts of the old D&RGW left, both are tourist lines in spectacular areas. The line you rode is now the Durango and Silverton, running between those named towns in southwestern Colorado. The other segment is the Cumbres and Toltec, operating between Chama, NM and Antonito, CO. The C&T does a little freight hauling, too. Antonito was also the northern terminus of the line to Santa Fe, NM. That line disappeared in the late 40s, I think.
Ken
Made it half way through the Third Class compartment:
You can see the difference between the plain wood coming out of the kit, and the seats after treating the wood with Oil. It almost looks like the real seat freshly varnished. In situ (below):
Five more seats to go (of smaller width) and the luggage racks and we can move to the roof.
Yves
