I have been more than pleased with my progress on this ship right up until masting, gaffs and spars. My problem is failing eyesight and small parts.
The kit quality is great. Plans quite good. Manual could use more up close pics on both sides, and less "follow the plans" guidance.
Posting this is primarily for older folks thinking of this build. I hate quitting after such great progress on hull and deck, but my progress level after is snail paced and frustrating. Too bad....very nice ship.
Need to carefully pick a new build. Would one of Vanguards cutters be a possibility, or will I be faced with the same issue?
Edited by bigcreekdad
Since all of Chris' designs are in 1/64 scale, you will run into the same issue -- and more often. You may need to look into doing kits in 1/32, 1/24, or even larger. You should take a look at Chesapeake Light Craft's model kits -- they are small craft, but done in large scales, e.g., 1/8 scale.
Current builds: Brigantine Phoenix, Vought SB2U Vindicator
Sorry to hear that. I do understand the vision struggle.
Jeff
How about the Caldercraft gun boat William, that is 1/32. I have in stock and looks to be a good kit.
Current Build(s):
Completed Builds:
34 minutes ago, bigcreekdad said:
Thunder... I looked at that, but could not find any finished build logs.
Have you looked at this?
JoTiKa Ltd. ~ HM Gunboat William Construction Page 1.
Current Build(s):
Completed Builds:
I've looked at both Spray and Gunboat William. I'm very familiar with Jotika's kits as I've previously built 4 of their ships. However, I kinda like the Spray. My big concern with relates to comments from a fellow shipbuilder who thought the britanis castings were too many, and a pain to work with. Any thoughts on this?
While trying to decide which direction to go I decided to fumble along with Erycina. Yesterday, I dropped 5 small blocks. All but one "disappeared" , and likely eaten by my carpet. This old age eye crap is a real bummer. My other two indoor hobbies are tying trout flies for a Michigan fly shop, and selling collectible postage stamps (mostly Canadian) in an online store. Good eyesight for both of these makes a world of difference.
I would be the same, RE the blocks, amount of time spent on all fours looking for them. Why do they always find their way to the most unlikely of places.
Current Build(s):
Completed Builds:
After losing pieces in the rug, I put a new crisp white drop cloth under my work area. Makes it easier to find pieces and keeps the rugs safe (not just from glue and paint but also from when you stab yourself in the hand with a razor blade and bleed all over yourself).
Realizing after all these years that it seems majority of kits that I like are 1:64, I decided to just move on with the Erycina. Eye crap is just a fact of aging. I guess it will just take longer. At least my hands don't shake....that would likely do it. Also, why I purchased a black work table is beyond me....I have spent several minutes on occasion just looking for the cap of my CA glue bottle.
Go to you tube...... type in herbs to improve eyesight...... you can find these herbs on ebay.  I use herbs and they work.
Can I suggest the lancing armada armed pinnacle ,  a small boat on a large easy to see scale  and a pleasant model when finished  also very customisable with extra on board items of your own making   , im doing this kit myself   due to the problems with small scale kits of much larger vessels
Well, sometimes. I'm always sensitive to posts regarding failing eyesight. I lost use of my right eye more than 30 years ago and suffer from a whole swarm of permanent floaters in the left. Many age-related vision issues (though not all) can be treated: near- and far-sightedness and astigmatism with glasses or surgery; cataracts with what is today fairly simple surgery. Macular degeneration is more serious but if caught early it can be arrested. If you've not visited a vision specialist, you should. Don't simply accept that your vision will decrease with age. Many people do and won't seek medical advice. Foolish pride says this half-blind man.
You do adapt to low vision. I'd pretty much given up hobby work until about 10 years ago when I discovered that good lighting, magnifying visors and patience can overcome many vision issues. Granted, I'm not as good at small details as I used to be but planning and patience are the most important. You will lose small parts. Have a good number of spares handy. Take frequent breaks. Whenever your eyes are tired or you feel frustrated, find something else to do. Even during long stints of working, focus on things at different ranges every couple of minutes.
Well... I'll step down off my soap box now.
Bad eyes as we get older is a problem.   I've found that my optometrist will do "custom" glasses (single magnification, cheap frame and at a very good price that not quite as low as department store stock (if you even find it anymore).  Basically "reading classes" and just about any magnification one might want.  I'd suggest give them a call and see what have,
As someone who also has poor eyesight, I am fortunate to be able to do the 1/100 and 1/96 ship kits. That being said, you could try Midwest's Sea Bright Dory, a beautiful looking rowboat in 1/16 scale with little to no rigging.
It should be easy on the eyes, and I'm sure you could make it look magnificent.
Edited by Ferrus Manus
Sorry to hear  that. I'm in the same boat as they say. Failing eyesight,shaking hands and generally a lot slower when working on my models. All age related. I find the small parts hard work. And rigging is just about doable without to many blocks.
I find wooden models to much work now, so have turned to plastic kits whitch are a lot more easy to do, And then I make my modelling harder by adding PE to the model.
I use a 10x table magnifier lamp and is a huge help. Paired with some 3x glasses it has improved my modelling enormously. Some of the lamps also have a smaller higher powered magnifier at one side. And a headband magnifier is also a good investment.
In Work: HMS Hood
Finished: -queen-mary-2
Finished: rms-titanic-1912
Finished: king-of-the-Mississippi
Finished: Sanson
Jeff......don't worry about the "soap box"  thing. I've been to the eyedoc many times over the years. Started with a retinal artery occlusion about 15 years ago, which left me blind in most of my lower right eye. Had cataract surgery and need to go back for some last work on the left...its clouded up, like looking through a dirty window. Hopefully, that will help some.
Well, now I've done it.... I have accidentally ruined the brass mizzen iron color (5 hole) for my Erycina build. I doubt Vanguard replaces such individual small fittings that are not made individually. I was thinking I could buy some unfinished mast loops and  carefully drill the required holes.
Any other thoughts?
Sounds like between you and me we've got one good pair of usable eyes. Just need to take turns, I suppose! I find the lack of depth perception the most annoying for small scale work.
