Hi, my name is Thomas Gahm. My build log disappeared as so
many others during the recent crash, and I just try to reconstruct as much as I
can.
Bulkheads and filler blocks are being glued in place.
Gun ports are framed and the fairing of bulkheads is finished.
Planking of the upper part of the hull with bass wood
strips. The strips were selected for homogeneous color and texture.
Treenailing using the wood filler based method described by
Chuck in the instruction book. During my last ship model build (Anfora kit
Ictineo II) the combination of the applied wood stain and the slight fuzziness
of the treenail hole edges led to a larger treenail appearance than initially
intended. To avoid this effect I drilled holes which were slightly smaller than
the intended treenail size of 0.5mm and I opened them up with a needle of a
slightly larger diameter (0.53mm). This led to well defined, round holes with
sharp edges, which once filled with wood filler gave me the intended
treenailing effect.
Planking of the lower hull with bass wood strips. As this
part of the hull will be covered later by copper sheaths I did not particularly
select the wood strips for texture or color.
Finished hull planking.
Lower part of hull planking. Two brass pipes were buried in
the keel to allow for the possibility to mount the model later via two brass
carriers inserted in these pipes. If these mounts should not be needed the
holes can be covered up via the false keel.
Stern view of the Syren. Mounting the Syren name turned out
to be a bit tricky due to the small size of the photo etched letters. The
following method worked for me: I painted the letters (white) while they were
still attached to the photo etch grid. After separating them from the brass
grid I arranged them to form the name “SYREN” on a sticky tape mounted on a
flat piece of wood with the sticky side up. Once I was satisfied with the
arrangement of the letters I covered them with a second piece of transparent
tape with the sticky side towards the letters. After turning the whole
arrangement upside down so that the first tape was on top and the second tape
underneath the letters I removed the first tape while carefully making sure
that the letters did not come loose from the second tape. Now all that remained
to do was to apply some superglue to the uncovered letter backs and transfer
the name as a whole in its final arrangement to its destination on the stern.
The use of a transparent tape allowed for precise positioning. Once the letters
were glued to the hull the tape could be removed.
Building of the stern transom. To form the stern transom I
modeled it first with a piece of paper which I then used to cut out the wooden
(bass wood) counterpart. This was then soaked in hot water and bent to its
final shape in a jig.
The formed transom is glued in place.
Finished transom.
Front view of the Syren. The planks are stained with a
mixture of 1 part Minwax Golden Oak and 2 parts Minwax Natural wood stain.
Planking of the deck using selected basswood strips. The
planks were tapered towards the stern.
Finished deck planking with waterways. I painted the
locations of the future gratings black to prevent the possibility of the deck
planking to be seen through the openings of the gratings. The deck was stained
with Minwax Natural wood stain.
Stern view of the deck with treenailing.
Plank nibbing.
Deck view.
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Welcome back aboard Thomas!  And another Syren joins the fleet.
Spectacular effort so far!
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
The copper plating of the hull is finished. After
experimenting with different nail patterns I finally settled for one. The
following images show the hull preparation, the production of the nail head using a variation of
Alan’s method with the diabetes needles, and the resulting copper plating.
I first prepared the hull by filling every hole with wood
filler, treating the hull with MinWax Sanding Sealer and sanding it down to a
very smooth finish.
To produce the nail head I designed the desired pattern with
MS PowerPoint, shrank it to the right scale and printed it out (image 2.1). I
glued the image of the nail pattern on a piece of 3mm thick balsa wood which in
turn was glued to a thin piece of plywood. I made sure that no glue was between
the balsa and the plywood under the area where the printed image of the nail
pattern resided. Using a #80 drill (~0.3 mm diameter; Micro-Mark) and a micro
pin chuck (Micro-Mark) mounted in my drill press I drilled the holes for the
nail pattern (image 2.2). The soft balsa wood allows the thin drill to proceed
without bending. Once the drill hits the hard plywood the drill channel in the balsa
wood acts as a guide for the thin drill ensuring that it enters the plywood
without being deflected or bent. Next I removed the metal needles (~0.3mm
diameter) from the plastic heads of the diabetes needles bought at Wallmart
with a pair of pliers and inserted the needles into the drilled holes (image
2.3). Pushing the balsa wood surface against a flat piece of metal ensures that
all needles end in the same plane (image 2.4). The needle ends sticking out of
the plywood side were glued together with JB Weld (image 2.5). Now the nail
head can be cut out according to the drawing glued on top of the balsa wood.
The balsa wood surface is then sanded down until all needles show a complete
diameter perfectly aligned in the balsa wood plane (image 2.6). As a next step
the balsa wood can be separated from the plywood (for this reason it is
important to have no glue between balsa and ply wood underneath the nail
pattern drawing, see image 2.7) and the nail head is finished.
Experimenting with different nail patterns. The 3 nail heads
in the front were used for my model – one for starboard, one for backboard, and
a symmetric one for the dress belt.
The “Sensipress” (Micro-Mark) came in handy for the copper
plate mass production.
Resulting copper plate pattern.
Here are some additional views of the copper plated hull:
Building of the rudder.
Finished pintles and gudgeons.
Several views of Syren with mounted rudder:
Building of the starboard quarter gallery.
The windows are constructed out of birch veneer and bass wood (1). (2) shows three finished windows and the main gallery body, in which the windows are test-fitted (3) and finally mounted with separating columns (4). At the right side of image 4 the carvings of the lower gallery body are lined up. From top to bottom: chains, moldings, leafs. 5 shows the assembled gallery body. 6 depicts the carving of the side ornaments.
Images 7, 8 and 9 show the construction of the roof with the backplane carvings and the shingle body. The shingle body on the right side in image 9 (3rd carving attempt) was used for the final assembly.
Different views of finished quarter gallery along with Chuck's plan and the metal casting from the Syren kit.
Test fitting of quarter gallery.
I started to give the stern carvings a try. During this process I realized that I did not really understand the components of the central part of these ornaments. As a first attempt I tried to realize a medallion with two banners and a little eagle in the middle . . .  however I really would love to understand what should be there so that my next try might get a little closer (-:
Augie, Mark, Chuck, I just finished uploading my Syren build log and saw your kind remarks. Thank you very much! And by the way, the new site is great! Everything works so much better and is so much more up to date than it was before! Great job!
Thomas
Wow! I am so glad you reposted this. I will remember what you did with these quarter galleries when I get there and hope to do as well.
:o
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
I finished the stern ornamentation. One of the biggest problems
for me was (and still is) to find a good method to transcribe the drawings shown
on the plan to the target  piece of wood, which in this case was a piece of Swiss pear
sanded down to about 5/64 inch. I chose the thickness of the wood slightly larger than
what the ornament finally should be. As transcription method I ended up with using a copy of the drawings
in the plan, blackened the backside of the paper with a pencil, placing the
paper on the target wood and tracing the drawings with a pen. This leaves the
traced part of the drawings as fine black lines on the wood. These lines I reinforced
again with a pen (image1.1). However, I would highly appreciate ideas for
better transcription methods! As a next step I glued the piece of wood with two
little droplets of superglue on a larger block of wood for easier handling.
Using a rotary tool as well as little chisels and an Exacto knife I first generated
the coarse shape and then the fine details (image 1.2). Finally the wood piece
with the carvings was detached from the wood block and sanded down until the
wood matrix (background) disappeared (image 1.3) and only the carvings remained
due to their larger thickness. This method allows generating carvings which ultimately
are thin enough to match the scale of the model. Image 1.4 shows the finished
result, images 2 and 3 show the Syren’s stern with the mounted ornamentation.
Production of stern carvings.
Mounted stern carvings.
Stern view of Syren with mounted carvings.
Hi Thomas, That is a fantastic job you are doing on your Syren. I'll enjoy following along. :)
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Hello Rusty,  Thank you for stopping by. What are you up to in the moment? I followed your Syren build very closely, and I was totally in awe of your Confederacy. Both turned out absolutely beautifully!
Thomas
Here a little update: I am finally finished with the 2nd page of chapter 9. I still had to do some adjustments to the starboard quarter gallery and had to finish the port version as well. Both are permanently mounted now as you can see in the following pictures.
Finished quarter galleries
Stern view from above
Starboard side
Port side
Port side, close up view from above
Starboard side, close up view from above
Starboard side, close up view from below
Port side, close up view from below
I am no longer talking to you as those quarter galleries are so perfect I am about to jump off a bridge.  It's embarrassing :wacko: .
But seriously, yours add a whole new dimension to an already beautiful piece of work.
Carry on, mate!
Augie
Previous Builds :
Bob and Augie, thank you for the compliments! They are always appreciated!
Looking at the next steps which are the gun port lids, I have a question, where I am curious how you handled this. Chuck's plans show holes over all gun ports which have upper lids (the 4 closed gun ports and the stern ports). I would assume that they are meant to have ropes go through which are attached to the outside of the upper lids to open them. Yet, they are nowhere shown, and for the stern ports Chuck writes in the instruction book that the ropes would go over the transom and belayed to a cleat above each port inboard? Having not read the whole instruction book I also would appreciate if you could point me to where the belaying of the ropes for the stern ports is described (what lines, which cleat) as it is probably easier to attach the lines to the upper port lids before I mount them (better access).
Thomas
Thomas-
I think I have these right.  The positions given are if you are standing on deck, looking outboard.
Bridle ports ...... the cleats are at the top right of the gunport
Aftmost ports .... the same as above
Stern ports ... Look at plans Sheet 8.  Looking down at stern you will see cleats (from left to right) labeled 'rudder pendant' (that will get the rudder pendant), 'Y' (that will get the boom guys),  then an unlabeled one (That's where the gunport line goes) and finally 'T' for the flag halliards.  The pattern repeats (in reverse) as you cross to the port side.
Let me know if this is understandable.
Augie
Previous Builds :
Thank you, Augie. Your description of the cleats makes sense. Then looking at the different models, including the one from Chuck, I would assume that only ropes are attached if the port was in use - that means no ropes for the closed side ports. That leaves the question for the stern ports: what are the holes for if the belaying ropes went over the transom? Or was it handled either way and we have a choice to go through the holes or over the transom?
Thomas
I thought the same.  But since the holes were already there that's what I used.  Later on you are going to have lines coming over the stern davits for the rudder pendants and also over the transom for the boom guys ...... so to me running the gunport lines through the holes just made a little more sense.
Augie
Previous Builds :
I think you have a good point there. What line diameter did you use?
Thomas
I did mine in .008 tan but I believe .012 might look nicer.  I did not want to take the chance of mixing line diameters for the rope coils on the  pin rails but that decision may have been short sighted.  I might still change them down the road.
Augie
Previous Builds :
Thank you, Augie! I guess I will take a similar approach.
Thomas
Hello Prodas, to produce these carvings I used a combination of rotary tool, small chisels, and Exacto knife, . . . and a lot of patience . . .  :)
Thomas
