Will, Carl and Per, thank you for your kind comments!
Will, I turned the belaying pins from tooth picks on a little Proxxon lathe. To be able to repeat the pattern reliably, I just used a little drawing with the measures/dimensions of my target pin, which I had always in front of me and which I could use for comparison (see image). That actually worked pretty well 🙂
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Thanks Thomas I'll give it a go this afternoon.
Stay well and stay safe
Will  :pirate41:
HM Cutter Cheerful  Syren Shipmodel Scratch 1:48 scale
On Hold:
Syren by pearwill Model Shipways 1:64 scale
1776 Washington Row Galley scratch scratch from NRG plans #121  1:48 scale
Completed Build:
Erycina 1882 Fishing Trawler by Vanguard Models 1:64 scale
Charles W. Morgan by Artesania Latina circa 1988, Lowell Grand Banks Dory 1:24 scale by Model Shipways, Norwegian.Sailing Pram 1:12 scale by Model Shipways, Muscongus Bay Lobster Smack 1:24 scale by Model Shipways
Thomas
Wow, that's a lot work there. I'm admiring your build and stealing some of your ideas. Verrrrry professional.
Steven E. Sylven
Thomas
Just a note of thanks. Today I finished making 125 belaying pins per your method and I'm quite proud of how they turned out. Again many thanks and I keep looking for longboat progress.
Will  :pirate41:
On Hold:
Completed Build:
Hi Will - what method are you referring to?  Is there a post # and build log you are referring?
“Here.  Hold my beer..." --- Common phrase uttered by Lord Admiral Nelson at any pub. 🍺
Some progress on the longboat: Planking and clean-up is finished (imgs 1-3), hull is painted (imgs 4-5), floor boards, front grating and thwarts are done (imgs 6-7), chocks are mounted on the gallows bits (img 8), and the windlass is installed (img 9). Img 10 gives an overall impression of the Syren with the (unfinished) longboat in place.
Thomas
Image 1
Image 2
Image 3
Image 4
Image 5
Image 6
Image 7
Image 8
Image 9
Image 10
That's a very well executed ships boat!
Up to your usual standard 😉
Keep it up!
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
Another miniature side build, very well done. It's a real beauty
Carl
1 hour ago, WalrusGuy said:
The longboat is perfect Thomas! So nice and crisp 😄
Agreed. Wonderful detail.
Thank you very much for your kind comments! They are highly appreciated. And thanks for all the likes!
Thomas
Good Afternoon Thomas
I've started rigging my carronades and would like to use your method for coiling the lines but I need some information on the tooling you made. Looking at the tool it appears to be sitting on a felt pad, then a wood disc, next I'm unsure of, then a clear plastic disc all held loosely by the pin. My questions are what is on top of the wood disc and how is pressure applied keeping the line between the ? surface and clear plastic? It appears the line is held in the center through a hole, is that correct?
By using the plank width i guessed the wood disc is about 1/2" dia and the clear plastic is about 1/16" thick. Based on these assumptions I'm going to make a tool and give it a try.
Many thanks for all you help and the beautiful photos of you Syren. Can't say enough of much help it is to follow your build.
Stay Well and Stay Safe
Will:pirate41:
On Hold:
Completed Build:
Hello Will,
Your description of the 'rope coiling tool' is pretty much correct. I used a basswood base of roughly round shape and about 1.5 cm diameter. The base has a little hole in the middle, so that a needle could just fit into it. The hole does not go right through but stops somewhere at 3/4 of the base thickness. For that reason the base needs to be a little thicker (about 7mm) to provide enough support for the needle. The needle is cut off at the end - the end needs to be flat. The idea behind this arrangement is that you can fix the end of your rope with the needle in the hole so that the rope cannot escape when you turn the arrangement. Once the coil is finished you just remove the needle and the rope coil comes free. The top layer of the tool is a transparent plastic piece. It needs to be sturdy enough to provide a flat stable surface and transparent for you to see what you are doing and how the coil develops. The felt pad is just to make sure that the whole device turns easily without leaving any scratches on deck.
The process goes like this: you put the end of the rope into the hole in the wood base, move the needle with the flat end through the middle hole in the plastic cover and by sticking it into the hole in the wood base (with the rope end in it) you fix the end rope in the hole so that it cannot escape. Now you add some diluted white glue on the wood base and lower the plastic cover. Applying enough pressure with some tweezers (with the right hand) on the plastic cover to keep it sitting flat on the wood base you turn the base slowly with the left hand always watching how the rope coil develops. Once it is big enough you carefully remove the plastic cover and the needle, with some tweezers lift the rope coil, cut off the rope piece which was in the hole and transfer the coil to its final location on the deck. If necessary you may need to flatten out the coil again and stabilize/fix it with diluted white glue to the deck.
Hopefully this description is not too confusing . . .
Good luck with the coils!
Thomas
Edited by Gahm
Thomas you da man. I'm off to the bench to make up the tool and give it a try.
Thanks again
Will :pirate41:
On Hold:
Completed Build:
Many Thanks Thomas one done 15 to go
Will   :pirate41:
On Hold:
Completed Build:
I finished the Syren longboat. The following pictures show the making of the gratings (Img 1), the finished cockpit (Img 2), the bowsprit holder (Img 3), the knees (Img 4), the oar locks (Img 5), the rudder with hinges (Img 6), and some images of the finished boat (Imgs 7-10).
Thomas
Image 1
Image 2
Image 3
Image 4
Image 5
Image 6
Image 7
Image 8
Image 9
Image 10
Wow.   I sure wish I could be a fly on the wall in your workshop.  Just wonderful skill.   That longboat is a thing in and of itself.
Gorgeous! So many nice details 🙂
I'm especially drawn towards the bowsprit holder. Very clean!
Edited by WalrusGuy
Current:
USF Confederacy - Model Shipways (Build Log)
HMS Pickle - Caldercraft (Build Log)
Complete:
Virgina 1819 - Artesania Latina (Gallery)
U.S. Brig Syren - Model Shipways (Build Log, Gallery)
On the shelf:
Armed Virginia Sloop - Model Shipways
Eamonn, Justin, Harshil, thank you for your kind comments and feedback! I really appreciate it. And thanks for all the likes!
Thomas
Well, I must say, you certainly have the longboat builds down pat. I've lost count on how many you have completed so far.
Nicely done, Thomas!
Mike
Edited by Stuntflyer
Current build - Sloop Speedwell 1752 (POF)
Completed builds - 18 Century Longboat (POB) , HM Cutter Cheerful  1806 (POB), HMS Winchelsea 1764 (POB)
Thank you, Alan and Mike! And Mike, you are right, it took me a while and several attempts to build something acceptable 😉
Thomas
Absolutely fantastic longboat. The details you have put into the thwarts leading edges takes this to another level of modeling. I think I'll call your work "artwork" not modeling. How the rear thwarts fit around the frames makes wonder how many you had to make to get perfection.
Thank you Thomas for sharing this with us mere mortals.
Will :pirate41:
On Hold:
Completed Build:
Thank you, Steven and Will, for your kind comments!
Thomas
Edited by Gahm
Thank you, Johann! I am constantly using your build log as inspiration for trying out new techniques and ideas 🙂
Best regards
Thomas
  • 4 months later...
After a little break the longboat is finally at its place, and I can start with the rigging.
Thomas
Img_1
Img_2
Img_3
Img_4
Img_5
Img_6
Img_7
Img_8
