Thanks for sharing Steve! The larger sizes would also work for the mast bands.  Great idea!
Brilliant idea we all should put that in our memory bank. Danny will also like it I think because he used cardboard.
Cheers
Greg
Photo from Danny's HMS VALTURE Swan log
"Nothing is impossible, it's only what limitations that you put on yourself make it seems impossible! "
Current log : The Royal Yacht Royal Caroline 1749 1:32 by Greg Ashwood:...
This looks like a good idea, but I wonder if the rubber tubing will stand the test of time. Like most things that are rubber based, would it not start to perish or break down over time? A couple of my models are 30 years old and I am not sure this would last that long. I'll be sticking with copper or cardboard. :)
Hornet
             Current Build: - USRC Harriet Lane - Model Expo.
             Completed Ship Builds:   Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
Well, this kind of shrink tubing is more like plastic than like rubber, isn't it? Especially after heat-shrinking it gets quite hard and stiff. I do not recollect seeing any of the typical disintegration which is typical for rubber.
As a reference you can have a look at old electric installations which were secured/insulated/finished with shrink tubing. It is not unbreakable but I have seen very old installations which under adverse circumstances have remained intact.
Very good idea!
Fair winds and following seas,
Jan-Willem
current build: Billing Boats Bluenose "the anonymous schooner" (enhanced-bashed-scratched-whatever) in a scale between 1:55 and 1:69
Let's just say I trust this stuff more than I would any glue. I have seen it being used to keep the rope ends of a kid's swing together and do away with the sharp ends and after years of (ab)use, rain, sun, frost and heat it was still intact. I have seen it in electric installations older than me and for instance on engines in direct contact with oil and fuel for years and years and still in one piece.
Good enough for me  :D
In fact, now that I think of it, it could be used to hold things together as well in places where glue is not practical.
Jan-Willem
Hi All,
Sounds like interesting stuff. What kinds of sizes does it come in?
Thanks,
John
Member:
Connecticut Marine Model Society
Model Ship World
"So we beat on, boats against the current, bourne back ceaselessly into the past" F. Scott Fitzgerald - The Great Gatsby
"If at first you don’t succeed.......skydiving is probably not for you”
Not quite sure. I have seen diameters from say 1 to 15 mm. but I bet there is more.
There are different types, the hard thin ones (the stuff which used to be around a pack of NiCd cells) and the softer ones which are a bit like elastic band.
Have a look in an electronics catalogue, you should find it there.
Cheers!
Jan-Willem
John,
Google "heat shrink tubing" without the quotes..
STRAPPING USING HEAT SHRINK TUBING: Great idea on the heat-shrink tubing!
I just checked Digi-Key.ca and they stock 1.0 mm inner diameter and up (260mm was the largest!) but you can special order 0.5 mm. I found 1.2 mm black tubing in stock: 4 feet (~1.2 m) costs $1.73 (Canadian).
Regarding durability: looking at some of the specifications on this plastic...when your model has aged into a pile of dust and rusted metal bits they could probably sift the mess and find the tubing intact! :o
Clear skies!
Gabe
Edited by GabeK
Current builds:  Harvey, Baltimore Clipper - Artesania Latina;  HMS Triton Cross Section, 18th Century Frigate - online scratch build; HMCS Agassiz, WW2 Flower-Class Corvette - HMV - card model
Completed:  The Matthew, Caravel - Scratch Built --- Build Log ---  Gallery; Swift, Pilot Schooner - Artesania Latina --- Build log --- Gallery;  Skeeter, Ship-in-Bottle - Ships a Sailin' kit --- Build log;  Santa Maria, Caravel - Artesania Latina --- Build log
Companion SiteHMS Triton log and live feed
CHEEP PAINT: If your tired of spending excessive amounts of money on model paints this tip might be for you. I save the small glass bottles from the modeling paints and refill them with spray paint. This came about because I use so much of the same colors of paint on my Byzantium. As the Byzantium is 1/20 scale there is allot of area to be painted, I can go though a whole bottle (or more) of model paint in just one session of light touch ups. By refilling the bottles with spray paint I save allot of money IE. one bottle of model paint cost about 2 dollars and one can spray paint cost about 4 dollars but contains 20 or more times the amount of paint.
Lextin.
Edited by qwerty2008
"I have no special talent. I am only passionately curious." - Albert Einstein.
Greg: I spray the paint at an angle so it hits the inside of the neck and drips down into the bottle. Also I only depress the nozzle half way so the paint comes out slower. If you spray directly into the bottle it will splash out really badly.
Lextin.
Hi all
In actual fact, I buy house water based sample pots from my hardware store. They can match any colour and a 500mL tub cost $6-$7 Australian. I water them down and do coats after coats and when it's ok, I used matt varnish.
This works for me!
Greg
**HOUSEKEEPING NOTICE**
Gentlemen,
This thread is drifting off-topic.  Please remember the following:
#1:  The House Rules provided by the original poster.
HOUSE RULES
To help with following this forum, may I suggest that you:
             - CAPITALIZE the name of the object at the very start of your post.
             - Please indicate scale with your suggestion, as various items could be used for different purposes in another
               scale.
             - Separate posts for each item AND purpose will make it easier for people wishing to search this topic.
             - Photos are actively encouraged !!
#2:  This thread is in the 'Discussion for a Ship's Deck Furniture, Guns, Boats, and Other Fittings' forum.  Posts should be limited to those items.  Tips for painting, etc., should be posted in the appropriate forum.
#3:  Please eliminate the banter!  Although we encourage camaraderie, a thread whose primary purpose is to serve as a compilation of tips loses its usefulness if a member has to scroll through pages of clutter in order to find the actual tips.  Use the 'like' button.
- Thank you!
SCRAPBOOK EYES
There are eyes for scrap booking that are great for many uses.  I use them for portholes and any time that I need a circular flange.  They come in many sizes.
In this example, I used two sizes of the eyes and a wooden dowel to make an anchor chain pipe.
Marc
PILL PACKAGING
Tablet foil that medical pills are packaged in make good checker plating for stairs/walkways etc. A light coat of grey paint and looks great. Obviously for those who are modeling more modern type of vessels.
Regards, Scott
Completed builds:
Awaiting construction:
SCRAPBOOK EYES
Bollards
Here is another use of the scrapbook eyes (See post 292).
Bollards.  These eyes come in many different sizes and I've used several different sizes to make bollards.  I drilled holes into a bronze sheet to match the skinny diameter of the eye. Epoxy the eye into the hole so that the large portion of the eye is the top of the bollard.  I filled the shaft with epoxy. Paint etc.
Here are small bollards that I made for the pin rails of a 1/76 ship
Marc
Edited by keelhauled
Cu TELEPHONY WIRE ( my favorite ) for WINDOWS SHUTTERS
On the Cutty Sark`s aft deck house, there is a nice skylight with six nice windows ( three on each side) with nice doubled shutters. And I wanted that shutters badly !!! Even if it looks like shutters
Problem was in scale ( cca 1:100), which means that every window is only 6 x 7 mm, and individual shutter is 6x3,5mm, which means that inside panel, considering cca 0,5 mm for frame is 5x2,5mm. Reaaaalllllllly small for my skills to make this from wood. I tried something with 0,1mm wire from old toy transformer winding I cannibalized long ago, and I was not satisfied with
After two days of thinking, expected brain storm hit me, and I got satisfied results
Drawing with hands, I just can not draw six completely equal squares 6x7mm with 0,1 mm felt pen. So I use Adobe Illustrator and drown 6 squares 6x7mm , cut arround and temporary fix strip with squares with self adhesive paper tape - only on edges to medical stick for throat overview. Important - paper under squares is not glued to surface ! On this picture you can see main tool for this operation - toothpick with sharpened and thinned top
Carefully pointed cutting marks to wire with 0,5 mm felt pen, and cut with blade several pieces. If they twist a little, I straightened them. It does not matter if edges are not vertical
Only with a bit of white glue on a same tom of sharpened toothpick, glue every piece of wire inside drawn square
Thin veneer by the depth as much as you can, and cut slices as narrow as you can (cca 0,5 mm) and glue them on position as on picture above, also only with a bit of white glue on top of toothpick
Add little drops of white glue around structure
After glue dry, only with a top of blade, apply putty around to fill all gasps
When putty dry, carefully sand excess of putty. I used a little rasp I made from 2x2mm strip with sandpaper I glued on two surfaces
If it is necessary, repeat putty and sanding. When you are satisfied, cover with acrylic. And here is explanation of main idea. Paper can not hold pieces together. But, putty can. Also, considering that acrylic paint turn on to plastic, whole structure is plasticized, and firmly enough for manipulating
After paint dry, carefully cut paper around window, and pull out window. Carefully sand edges, and thin whole structure a bit to get right surfaces
Then apply final coat of acrylic
And here is result
Edited by Nenad
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Drug ambalage
Not my idea. I found this on FB
Good to share
In progress:
Content of log :
Past build:
Huh?
Member:
Model Ship World
It's the aluminum foil used in the packages of Mucinex  decongestant. Cut the little sheets up and you have scale aluminum strips.
Jack
Current buildUS Constellation
Been saving those kinds of things myself.  That and clear acrylic wrappers for windows.
GEORGE
I get it now. Not much use for American boats from 1750 to 1890, but a good idea nonetheless.
Best,
John
Member:
Model Ship World
Best,
John
Member:
Model Ship World
After a somewhat bumpy ride towards the end o’ 2015, CaptainSteve be a-makin’ it his New Year’s Resolution to be steerin’ Kit-Basher’s back on her original tack. Thusly and therewithforth, I doth be planning on scouring the Build logs and a-pesterin’ some o’ you to share your fine ideas to repurpose-eth everyday items.
As such, the following was used with the permission of MSW member, Cobr@ ...
There is a way you can make good rings with brass wire.
First take something round which is the same diameter as the ring you want to make, a screwdriver for instance. Then wrap the wire around it in a spiral keeping it as tight as possible.
Once done, slide the spiral off the object you chose to wrap the wire round and cut it in the place i have highlighted in the second picture, you can cut off as many as you need all the same size and perfectly round. Note in the pictures the spiral was not tight as it was only to be used for reference purposes.
And here's a shot from Cobr@'s HMAV Bounty build, showing the above rings used to make door-knockers ...
... the brass rings can be chemically blackened and/or painted.
O’course, as ye well know, all may feel free to post their own ideas …
Edited by CaptainSteve
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
