Hi Ray,
resuming of my shipbuilding activities is scheduled for next autumn. Meanwhile my Diana is begging for accomplishment.
So when I'll tackle the lifeboats and the rigging I'll simply follow your inspiring example. (Sometimes) life can be easy...
Superb job
Kind regards
Christian
"The original always beats the copy"
(supportive statement)
Hi Ray,
What size anchors and oars did you use and were they from CMB?
Thanks,
Mort
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
Hi Guys thanks for the many ticks and comments
Mort
   The boat hooks are 57mm A4750/01
    oars 65mm A4405/01 (used so far)
            85mm A4405/02 ( to be use with the pinace)
    Kedge anchors 11mm A4400/01
all were from the every reliable C M B
Ray
 Current build A set of HMS Diana`s boats @ 1/48
 HMS Royal Marine a Military class Trawler
 Completed  HMS Diana
Completed build The Lady Nelson
Completed Build HMS Pegasus
Ray,
I love those 3 fantastic looking ship`s boats, real little gems..., well done !
Question: the green, blue and red stripes on the different boats, are these for better identifying by the crew ?
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you Ray.
Mort
The Display Stand
Before building the Pinn
ace I decided to build the display stand, I very much liked the one Mobbsie built for his Aggy so I take no credit for the ideas or the design, so its my version of Mobbsies stand.
Ray
 Completed  HMS Diana
The 32ft Pinnace
                              I built the Pinnace in the same way as the other boats, but did the decking differently, and a bit of white lining on the paint job, on the sides, to make the boat a bit more like the Captains boat,, I have really enjoyed building these boats, so much so that during my next project I am going to build some more at a larger scale,they will also be painted as they were in service, as this added to the boats protection on long voyages and will also be carval built as supplied to ships in service not in the channel.
1st planking holes cut to make breaking out inside easier
2nd planking
grating
keel added
ribs
deck and grating
fitting out
painting
Finished boat
Ray
 Completed  HMS Diana
Hi Ray
That is one smart looking Pinnace Ray.
You make it look so easy mate when in fact there is an awful lot of work in that little boat.
Great work and a great result, well done.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Hi Guys many thanks for all the ticks and positive comments,I will add a few photos of all the boats together. Now its back to the last of the rigging not to much to do now, the largest job left are the rope coils at the termination points.
David B
Below are the colours used on the boats I used colous that I liked, the blue and red matched the colours used on Diana.
White  Humbrol 130
Red     Humbrol 19
Green Humbrol 3
Admiralty paints French blue and Yellow Ochre.
Ray
 Completed  HMS Diana
The ships boats completed below some photos of the completed line up.
Back to the last of the rigging.
Ray
 Completed  HMS Diana
With the ships boats finished it has been back to the last of the rigging all be it slowly as other things have taken up most of my time in the last few weeks,the fore sheets tack and clue lines and the main sheets tack and clue lines have been added and rigging done !!!
I am now making lots of rope coils to add to the belaying pins and all the other rigging termination points.
Ray
 Completed  HMS Diana
You are the best, the very best.
Mort
The ropes have been added to all the termination points, and the rudder chains fitted.
Ray
 Completed  HMS Diana
Hi Paul the blocks used for rigging the cannons are Amiti 2mm they need to be as small as possible to allow some space between them.
Ray
 Completed  HMS Diana
The anchors were made up I used some split washers for the rings and added the puddening and used black tape for the iron bands,the overall look of the anchors are fairly good,they were then fitted in place.
I then went right through the rigging and made a few tweaks and a bit of re-tensioning (as photos below)and tidying up,only one job left adding the boats.
Anchors added
A stay pulled out of shape
Re rigged stay
Ray
 Completed  HMS Diana
Ray you did  nice job on your anchors but you forgot to blacken your rings or are you leaving them that color.
David B
Hi David the rings will stay as they are covered with .5mm nat coloured rigging thread.
Ray
 Completed  HMS Diana
The Last Job
The ships boats were put into the cradles and tied down. JOB DONE.
Just the final photo shoot to do.
Which will not be until the end of November as we are on holiday for three weeks 3rd to the 22nd.
chocks for the small cutter
ready to tie down
Two boats tied down
Three tied down
All done
Ray
 Completed  HMS Diana
