Good tip on the rope coils Ray. I struggle with those holding them in tweezers and doing all sorts of contortions so this looks like the way for me and just as I've got a deck full of guns to be rigged.
Top decks
With the the gun, deck guns, and fittings completed the next part of the build is fit the top decks, all be it they are in one sheet, the quarter deck, the gangway and the forecastle. The first part was to fit the beams between the gangways, the beams were fixed to under side of the ply deck and slots cut into the inner bulwark to allow the deck to fit I considered this better than shortening the beams. Then all the other beams were fixed to the frames. Next I snapped off the top of the frame stubs and dressed them level, the ply deck was trial fitted to ensure it went down on all the beams OK and the levels and cambers were correct a few slight adjustments were made.
The deck was then ready to fit, I normally use Speed Bond PVA but in this case you need a longer drying time so I used a std  PVA as it takes a fair bit of time to apply the PVA and place, and pin the deck down. With the deck now fitted I then decided to fill the gaps around the edges and were the frame stubs had been removed, the edges at the gangways had gaps around 2-3 mm as showed in the photos these had a ply filler added, you will not notice this from side on as it will be painted.
Deck beams added
Beams fitted stubs removed
glued and pinned
started filling
gangway gap
deck fitted and filled
gap filled
Edited by Ray
Ray
 Current build A set of HMS Diana`s boats @ 1/48
 HMS Royal Marine a Military class Trawler
 Completed  HMS Diana
Completed build The Lady Nelson
Completed Build HMS Pegasus
In cruising through this build log, I have determined that I need to build this ship as well.  Almost regretting not building it first, but there it is.  A classic Frigate.  Nuff said.  Thank you for sharing your progress with us.
Current build Andrea Gail (Billings)
Hello Ray,  You have a fine looking ship coming along, I admit i stumbled on your build log. glad i did.. Although i now torn between the Dina and the victory now :-s
Looking forward to updates
All the best Rich
Rich.
Builds in Progress:   HMS Victory
Completed Builds:   Constucto Enterprise
Future Builds 2021/2022 USS Constitution
Very nice very very nice.
Mort
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
Firstly thanks for the comments guys
The forecastle bulwarks
These were the next job,I decided to lay the waterway down first and add the inner bulwark planking over it, this way should give a nice edge better than cutting the waterway to fit the curve. The waterway was made up from 6mm deck planks glued together and cut them to the bulwark shape,if they look a bit wide this is to allow the deck planking to be joggled into them. I laid them both sides and then planked the inner bulwark did a bit of filling on the top and filed them both square. I then removed the capping rails from the sheet offered them up to the bulwarks and they were only just as wide with no overhang !! so I checked the bible and all the capping rails show an overhang, I laid the rail over the plan and they are about 3mm to narrow (see photo) so using the rail I marked and cut out two new wider ones from the ply sheet they came from, I did not cut the location slots, I will do them later, they were first painted, and then glued in place with thick cyno  and repainted.
Waterway
Waterways fitted
Bulwark planked
Undersize rail
New rail marked out
Ready for rail to be fitted
New rails made and ready to fit
Forecastle bulwark and rails completed
Ray
 Completed  HMS Diana
Forecastle deck planking
The deck was planked in the same manner as the gun deck using the maple planking and blackening the sides, I joggled the planks from the position as shown in The anatomy of ships Diana, the effect is much better than just tapering the planking but you do need the waterway to do it, I planked over the cutter-ways in the deck and will add the fittings over them, there are no joints as the plank lengths are to short where there are no fittings.
First plank down
A few rows down
Just more than half done
Joggled planks
Deck completed and varnished
Ray
 Completed  HMS Diana
i love the decking, well done
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Love what you are doing here Ray, those joggled planks are just great.
Thanks for sharing
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
The quarter deck
The forecastle deck now completed I now turned my attention to the quarterdeck ,this is were I change from the kit version, to the as built  in 1794 Diana with the open rails, and only 9 pounders. Firstly I cut out and fitted the waterways, I then discovered the gun ports were all wrong, the  bottom of the ports were to low as was the hight of the bulwark when a cannon was offered up to the port, Please note this problem only applies to the 1794 version not the kit version.
My solution was to remove firstly the outer hull planks, glue together two planks and plank the inner bulwark covering the old ports,then extend up the middle planking row and fill in the old ports,and lastly re-plank the outer hull,and when both side had been done I cut out the gun ports using a cannon to get the correct heights,I would highly recommend anyone building Diana to this spec build the bulwarks above the deck and do not cut out the gun ports until you reach this point. The ports were cut 1mm oversize to allow them to be lined. next I painted the outer hull and inner bulwark, the open rail is the next job.
Quarter deck waterway
Removing old planking
New planking
Fitting inside plank
Rebuilding bulwark
rebuilt bulwark
Re-cutting gun ports
New bulwarks completed
Ray
 Completed  HMS Diana
Hi Jason
Good Question, I have been pondering this point, and your question has made me make the decision on how I will depict the armament. I have looked at other open rail models, most do not show any guns, and some show 9-pounders at all the gun ports on the quarter deck, and four, on the forecastle, but this gives her too many carriage guns. I consulted my books The Sailing Frigate  A history in ship models (which backs up ) the information in The Anatomy of ship Diana,the book states that Diana received 32-pound carronades  on the 23rd of February 1795, but she was only given six,not eight, the establishment requirement and she also did not lose any of her 9-pounders, and she most likely received the other two 32-pounders at the time of her refit in 1796.
I will therefore arm Diana as in mid 1795 with four 32-pound carronades and eight 9-pound carriage guns on the quarter deck and two carronades on the forecastle with two 9-pounders as bow chasers. She would still have had an open rail quarter deck, as she did not have a refit until 1796, which logically would have been the first opportunity to fit solid quarter deck bulwarks.
Ray
 Completed  HMS Diana
The quarter deck open rails
I looked at the photos in my books and worked out a hight for the top rail, and then drew out a template, (see photo), which would give me good idea of what it would look like,  I also used the template to cut out the uprights. Firstly I made a trim to go at the top of the bulwark and under the bottom rail. The bottom and top rails were made from 5x2mm beech which bends really well even after a short soak the uprights were fitted into slots in the bottom rail which when they were all made were painted and glued on, the top rail was bent to shape, and all the upright positions marked, the rail was then drilled to just under the breaking through point,and then cynoed onto the uprights, one down one to do.
Rail profile drawn out
trim added under bottom rail
bottom rail
bottom rail and uprights
Top rail ready to fit
Top rail fitted
Ray
 Completed  HMS Diana
Great Job , Ray
I had some trouble while bending the 5x2 mm strips. As result the curves and even the straight parts are seperate. Because as seen from above this upper rail follows a certain camber or loop, if you like.
Kind regards
Christian
"The original always beats the copy"
(supportive statement)
The quarter deck open rails have now been completed, and also, the top rail across the top of the stern has also been added, and some more of the the side decoration strips have been added, just a bit of paint touching up is required.
Completed open quarter deck rails
Stern  rail
Ray
 Completed  HMS Diana
Quarter deck planking
Next I have planked the quarter deck same method used as before and I joggled the planks as I did on the forecastle.
Planking started
Half way
Nearly done
Quarter deck planked
Ray
 Completed  HMS Diana
Gangways
The gangways have now also been planked and the 5x2mm beech has been used to make the rail which joins up the quarter and forecastle decks just the inner batten to add and varnish.
One side done
Both sides planked
Ray
 Completed  HMS Diana
