7 hours ago, KeithAug said:
Soft solder I assume?
Hi Keith yes it is soft solder done with the hot air soldering gun.
Thanks ,John, Nils , Igor
I am going to see how turning up a pair of cast iron balls works today.
Michael
Oooh, nice! Also love the adjustable spanner (wrench) that you made lo those many years ago.
Do I assume that the compass will work when completed? Otherwise you might just use brass for the balls (adolescent snigger).
Hi Druxey yes the compass will be fully operational.
I spent some time this morning making some soft iron balls
They turned out well but are way to small for the scale I am working in as i was doing this I realized that I did not fully understand the mechanism for the balls or how they worked.
To be clear on the function of the soft iron Balls.
I read a number of articles about binnacles and found the technical stuff surprisingly hard to find.
This one was one of the better ones and also a child's article on making a compass has led me to rework the innermost parts of my own.
This picture shows the parts of the compass I have made and also the tiny parts from a ridiculous pocket knife compass that showed the alignment of the pocket knife and nothing else. The pocket knife compass though has a one piece that will be able to replace the huge brass mass with the rare earth magnets.
The cup hanging inside the gimbals  will need a bit of modification to hold the black cup and compass base.
I will make a new card to fit over the compass in the black cup, and rework the brass cup to have a needle for the new compass instead of the black plastic cup.
The other thing that will need to be done is a cover that will prevent the new compass from lifting off the pin, there is enough meat in the brass cup to drill and tap some holes for retaining screws on a 1/32 plexiglass cover.
The soft iron balls will no doubt wind up in the spare stuff tray.
Looks like a bit of lathe work is in order.
Michael
Very nice compass! The purpose of the iron spheres is to help mitigate the effects of an iron hull on the magnetic compass. There should also be a vertical iron rod (the flinders bar) to offset that component of the magnetic field. I hate to break it to you, but since your hull is wood, I doubt that your compass would have been fitted with those extras, they would do more harm than good.
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
Hi Andy great to hear from you.
Andy this is the conclusion that I came to after all my reading today. So they will not be installed and as I noted in the last post I just edited. However I think I will have a better gimballed compass at the end of the day as a result.
Michael
Michael -
I was going to say that your work on the binnacle is superb.  But if you are going to end up with a better one, I will hold off for now.  I am in danger of running out of superlatives.
Superb, nonetheless.
Dan
Hi Dan thanks for the kind words.
This evening I reduced the depth of the inner cup and machined a new insert it is drilled through with a .6mm hole at the top and threaded 1/4 inch deep x 8/32 thread on the bottom.
This allows the needle to be adjusted up or down, the needle is in fact the end of the 8/32 screw machined down and honed to a point to hold the compass.
The magnetic part placed on the pin
I tested the pivoting by bringing a pair of metal tweezers up to the compass and the needle swung to them
Next to find the print that I made for the compass and mount it on the metal magnetic part. Also the plexiglass cover.
Michael
Prototypically, the bowl of the compass should be filled with mineral spirits to dampen the movement of the card. May be worth trying, you could probably get a similar effect with rubbing alcohol. No air bubbles allowed!
Andy
USF Confederacy
Hi Michael, how disappointed I am that I found this build too late :(  I will need to take some time to read back through.
That compass is a work(ing) of art; a model in itself.
Very much enjoyed seeing how you did this.
cheers
Pat
Andy this has crossed my mind, it would entail sorting a couple of things out, not the least of which would be testing the printed card for deterioration in the oil or spirit. also I would need to seal a few spots to prevent leakage, eliminating the air is not a problem.
I shall consider my options on this one.....
Michael
good to see your back in the workshop :)    very nice work on the compass......your metal working skills are amazing.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Beautiful work Michael. Your tools reminds me of my own machinist training - a long time ago. Nostalgia is setting in ;-)
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Denis , Elmer , and Piet thanks for the kind remarks.
Did a bit more work cleaning up the compass and made the cover from some 1/32 plexiglass.
The bolts are some modified 00x90 1/4 in long hex bolts.
After cutting them to length and polishing the threaded end they were held in the pin chuck to reduce the hight of the head and to round it up a bit.
All the gimbal rings were given a final sanding with some 1200 grit wet and dry.
and fitted back into the copper dome.
Michael
Hi Mark
To make the front edge of the drill a scraper similar to a bit for brass.
Michael
That is simply stunning work; what is the size (diameter) of the compass card Michael?
cheers
Pat
Hi Pat, the card is 14mm or 35/64, the card rotates very nicely. I printed it up on photo paper and then coated it with CA glue. The Plexiglas  was very old I had it left over from my Architectural model building days so since 1984, the trick with removing the protective paper on old Plexiglas is to warm it up with a hot air gun. The paper then comes off as if it were a new sheet.
Michael
Thanks Michael, that is awfully good work at that scale.  Great trick to remember for the paper too - thanks
cheers
Pat
Magnificent work, Michael ... I've been sitting at my screen waiting for each new step, to enjoy all the marvelous details you create, and am flabbergasted with the result
Carl
Thanks for the kind words Carl, thanks also to all of you who have been visiting.
In between the hockey periods I did a little work on the companionway, and lowered the side walls by 1/2 inch 4 inches in scale which leaves them at 17 inches at the aft end and 13 1/2 inches at the forward end. I'm good with that.
I will shorten the hatch about 3 inches shorten the sidewalls length by 4 inches to make them 48 long and add a couple of round ports in them.
Michael
the hatch looks good.......and some amazing work on the compass.   very nice :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Michael - I have had problems in the past bolting directly on to perspex. After a while I noticed small cracks starting to grow from the bolt holes. I cured it by using rubber grommets to line the holes (slightly wider than the perspex thickness). It may be that I had a bad experience and you will get away with it.
Excellent work as always.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Hi Keith I have not had this problem in all the years I have worked with plex, perhaps it has something to do with the types of Plex, I prefer to use the Cell Cast type and not the extruded type.
First I bored out a piece of 7/8ths with a half inch drill
Then using a brand new tool bit which I ground from some 5/16 HSS steel, I was pleased that I was able to take a single depth of cut of .125" for a distance .312" which is the thicknes of the side walls of the cabin.
The first three porthole shells still a lot of work to do but it feels good to make some progress.
Michael
Hello Don,
I do not know of any Kits although at one time there was a hull that was either vac formed or glass fibre one that approx 46 inches long.
In this months Wooden Boat magazine there are some nice plans of a 29 foot daysailer along the lines of a traditional pilot Cutter.
Michael
Don
Re Bristol Pilot Cutter kit, this may be of interest http://www.kingstonmouldings.co.uk/products.html
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thanks Keith I could not remember the name of the outfit that made the hulls.
michael
