Gunther a new one but of course.... lol
Every once in a while I am on Jims page and putting an order together.
Related question, which accessories should be the first essentials?
Edited by Nirvana
Respectfully
Howie didn't specify new or used.   :)
Howie - to answer your initial question re: Shipping.  Go to the Byrnes website, select the item you want to buy (saw, any accessories, etc.) and click on the "Order" button.  This will take you to a page where you can enter your location and calculate shipping.
If that doesn't work for your location, they have a contact section where you can contact them and inquire about shipping, I'm sure they'd be happy to assist you.
Edited by GuntherMT
I think Howie are refering to a used one.
And so am I. ;)
Edited by Nirvana
Respectfully
With regards to the safety of using a 10" standard table saw previously asked in this thread. A full sized table saw is safe when used in the appropriate manner for the appropriate task. Some "rules" to follow:
- always use the anti-kickback pawl and splitter
- never stand behind the blade and fence
- use the right blade for the task at hand, rip, crosscut, plywood
- never cross cut freehand, always x-cut using the miter gauge with or without an extension piece and move the table saw fence out of the way
- always get a tail person or build an out-feed table when cutting long sheets
- never, never, never have a conversation while operating any power saw
Regards
PS I have a Jim Byrnes saw for 10 years. By milling my own lumber from stock (to include logs), this machine has paid for itself many times over; as has Jim's thickness planer.
I have all the accessories. The most important by far are the spare blades.
Regards, Keith
Keith, that didn't helped me at all.... :P
Respectfully
I just ordered one of Jim's saws a couple of weeks ago and it will be at my house on Monday. I can't wait to be able to mill my own stock. I ordered everything but the tilting table. Also got some spare blades, an extra belt and a zero clearance insert. Did I need it? No, but for a lifetime hobby it's a good investment for me. I hope to order the thickness sander in a few weeks.
The heart is happiest when the head and the hands work together.
Al
Current Builds:
HMS Halifax 1/48 POF Lumberyard Kit
Model Shipways Glad Tidings
Acoustic Guitar Build FINISHED
I want one of Jim's rope walks to complete  my Byrnes' ensemble. Ahhhhhhhhhhhhhhhhhh
I got my new saw this morning and it's a thing of beauty. Now I have to learn to use it. I tried to cut the keel sections for the Triton Cross Section project out of boxwood but I'm having problems. The cuts are uneven and pretty rough. I can't seem to get a nice straight cut. I did a little better with cherry. When I cut boxwood with my little Microlux saw the cuts are as smooth as glass and even. What am I doing wrong?
Al
Current Builds:
Al,
Are you using the right blade?   Can you post a picture?
Shihawk,
Harbor Freight has a 4" table saw for $ 37.00. I know the purists will scoff at the saw but its cheap enough to play with and you can upgrade later.
I bought a 2 inch cuttoff saw for $ 29.00 and it worked just fine for, nice clean cuts. At the time some said it wasn't precise enough.
Go cheap, upgrade later.
John
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
Al
The 24 tooth carbide is for roughing down thick stock.  Use one of the slitting blades on the thin boxwood
Jim
Jim,
Thank you for taking the time to answer my question personally. I only have the one slitting blade I ordered with the saw and will be ordering a couple more. Can you make any recommendations? Again, the saw is fantastic. If anybody is on the fence about getting one of these tools just know you are getting super quality and great customer service.
Al
Al
Current Builds:
Al,
Have a look here:  http://www.hobbymillusa.com/byrnes-saw-operation.php   Jeff has guidlines for teeth count for different thicknesses of wood.
I have used the Byrnes Saw for many years.  I use the 90 tooth slitting blade almost exclusively.  It gives a nice smooth cut for planking and fine cuts.  I will occasionally use the 24 tooth for larger stock.
I get my blades from Thurston Saw Blades out of Rhode Island (as recommended by Jim).  Primarily the .030 thickness bit occasionally .040 or .020.
http://thurstonmfg.com/
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
Al
I have 2 saws set up in my model shop and use the .03 slitting blade for most everything, probably 95% of the time.  The other saw is set up with the 36 tooth carbide that I use occasionally and rarely use the 24 tooth carbide at all. Only use the .02 slitting blade when cutting very thin stock like 1/16 or less or if you need it to make gratings but don't use it for general cutting.  The .04 slitting blade can be used as a general purpose blade but it will obviously waste more stock and I have not found it to be any better than the .03.  Good quality blades can be bought form me, Thurston, Martindale and Malco.  Stay away from the imports if you can.  Thurston and Martindale are probably the cheapest.  I only sell the Thurston blades but you probably can get them cheaper from them.  I have to buy about 400 blades at a time to get a small discount then they sit on the shelf for a year or so
regards
Jim
The quick answer to this question is, sure you can live without one of our saws. People have been building models for hundreds of years with just hand tools.  The reason why I built this saw?  Time and accuracy.  18 years ago I was working on a kit model from one of the Euro kit suppliers. The wood supplied with the kit was awful, not even good enough to burn.  This was long before quality wood and milled stock was available from Jeff Hayes at Hobbymill and Jason at Crown.  At first I bought 1/8 x 1/16 milled boxwood strips from one of the suppliers and they were all over the place.  They measured from .110 to .140 on the width.  When I called the supplier I was told that was within his cut tollerance.  Well I was used to working to slightly tighter tolerances so I didn't use the wood. I looked into buying a hobby size saw so I could cut my own and the only consideration was the Preac.  The Preac at $375.00 for the large table version looked good but didn't have the capability to cut thicker stock to more manageable sizes.   Having access to the machine shop which by day made parts for targeting lasers for the military I figured I'd build a better mouse trap.  Took me about a year between learning Autocad and designing it and I tossed a lot more parts into the scrap bin that I would like to admit but in the end I was happy with it and it's pretty much the same saw that is available today.  Now I could cut wood strips and hold + or - .001 all day long with a really good finish.
So, has it made me a better modeler?  Maybe, maybe not.  I guess it all depends on how you look at it.  I don't have to worry about the size and quality of my milled stock.  I can sit in front of the saw and rip off 1/8 inch strips all day long and hold a very tight tolerance without much effort.  I can get a finish that sanding would only make worse so it gives me more time to concentrate on the things that scare me like carving.
Am I quicker, you bet.  Do my planking jobs look better, sure do.  Could I have done it without the saw, sure.  Would have taken me considerable longer though and for me, modeling time is precious.
My 2 cents worth
Jim Byrnes
Model Machines
Jim
Thank you for your input.
I think the bottom line from many of us is digging into the check and credit book for the investment and knowing what you are getting.
I am fortunate and was able to buy a barely used thickness sander of yours from a friend.
I know the quality behind. And I won't go with anything else but your table saw, when I have the money.
How much I will use it?
I don't know!
Can I justify the investment?
Very likely.
So, here is my thoughts.
When the day comes for me to stop modelling (which will never happen, unless an accident prevents me), and I have several of Byrnes Machines, there will be a higher value than any other machines out there.
No wonder it is so hard to find a used Byrnes table saw.
My last cents, now I have to start saving them for a Byrnes table saw.
Respectfully
Dr.
Yeah, they don't come up used very often.  Every once in a while I see one on ebay but they always sell for close to retail price so they do hold there value.  I keep a running list for used machines but have only had 2 to sell in the last 6 or 7 years.  Granted they are expensive but they are also not cheap to build. They are fully machined on CNC equipment and when you compare them to what is on the market I think they are a pretty good deal.  No castings, no plastic no junk.  All the parts are made in my shop, by me with the exception of the belt guards.  They are made by a local sheet metal shop.  I do all the assembly and square them up with dial indicators.  We have no employees, except me, I work for Donna.  She lets me come home when I have finished my quota for the day. The CNC's are also not cheap to maintain either.  Right now my oldest cnc mill is down.  I'm looking at a new 15HP motor and inverter.  Between buying the parts and having my maintenance guy install them the bill is going to be around 7 grand. That's a lot of saws. And occasionally Donna writes me a paycheck too.
Jim
Jim,
After meeting you and Donna at a couple of shows, you should be writing her the checks!!!!!!!
Edited by Landlocked123
Member:
Connecticut Marine Model Society
Model Ship World
"So we beat on, boats against the current, bourne back ceaselessly into the past" F. Scott Fitzgerald - The Great Gatsby
"If at first you don’t succeed.......skydiving is probably not for you”
So turns out my big machine repair bill is only going to be e few hundred bucks. My electronics guy checked out my inverter and it checked ok so he brought it back to the shop and my maintenance guy reinstalled it but still nothing worked.  He rechecked the motor and that was also still checking bad so after scratching his head a bit he went around to the side cabinet and checked the spindle control board and it was loose.  Pushed it back in and everything worked just  fine.  Re checked the motor and inverter both checked good so its back up and making parts.  After I razzed the maintenance guy for misdiagnosing the problem he handed me a little bill instead of the huge one I was expecting.  Good that I have honest people around I can count on because you are at their mercy when it comes to this stuff.  For me anyway not being an electronics guy
Jim
That's great news Jim. At least now Donna want need to put you on half-pay to cover the costs!
Jim, that wss good a good call. Electronical problems are worse than mechanical. Glad to hear you are back up running the machines.
Respectfully
I waited for months to see if I could get my hands on a used Byrnes table saw, and had no luck.  I ended up buying them new from Jim, and haven't ever regretted the decision.  Too many things these days have more complicated and unnecessary configures with multiple parts that just raise the chances of the thing breaking down - Jim's tools on the other hand are built like tanks, and use a very simple yet effective design.
I don't get as much modeling time in with work, kids, beer, etc., but I would rather spend the money on good tools that will last a lifetime than buy tools for slightly less that don't have the same quality both in terms of precision and expected lifetime that will end up getting replaced down the road.
Edited by Landlubber Mike
