the learner
Everything posted by the learner
  1. I actucally see this pop up on a web search! Nice tools
  2. Thank you for reposting your work Blue! That will be a very heavy model at 1/32" its already a good size model at 1/4" approx 31" between perp's. Where will you display it when finished
  3. Greg, I have used paper between the joints before but find them weaker that using blackened glue, however I likd the fact that you punch pin holes in the paper to allow the glue to penetrate. Do you use a hard paper or just regular art paper?
  4. Egan, I went to the site and find that it is very much like Model Ship World but larger and more expanded. I did follow one Build on the "Black Pearl" ("Черная жемчужина"), it was only two pages. I see the kit he is building uses MDF....not here but if it works guess it is ok. I will go back! Thanks
  5. Нет, я просто использовать Google переводчик! мой русский ограничен привет, спасибо и такие, я думал, что вы appriciate! Однако я был там несколько раз.Красивая страна No I just use google translator! my Russian is limited to hello, thank you and the such, However I have been there several times. A beautiful country What is the URL for the Russian Forum? Translating with google is easy
  6. A set of Plans in DoubleCad 2D .... I am still learning Hoy in DoubleCAD(working copy).pdf
  7. I have a 3d program that works in Vista wth no problem and its free to down load! its called DoubleCad XT http://activate.imsisoft.com/doublecad.aspx?productpage=DoubleCAD_XT_v5 down load from this site I have an earlier version but this should work on your computers with out freezing it up. Has anyone contacted Google about your problems with SketchUp?
  8. The mast rings look great! I have never used cane but similarly I have used thinly cut hard wood and diagonally wrapped and glued two layers then when dry cut of the required thickness required for the mast ring. I did wrap the dowel with wax paper before wrapping the soaked wood on the dowel.
  9. A Great ship! Thank you for re-posting!
  10. Великий строить! Я буду следовать сейчас. У меня есть книги и планы на Euryalus и хотите, чтобы некоторые день, чтобы построить ее, так что вы будете моим вдохновением! Great build! I will follow now. I have the book and plans on the Euryalus and want some day to build her, so you will be my inspiration!
  11. Now that you have done such a fantastic job of constructing the stern section is there any plans on a complete build? Did you use G. Delacroix plans for your build
  12. Well developed build and you are using a great set of plans. When I first came across this build I thought this looks just like Chuck Passaro's build. A good build to follow
  13. A fantastic and very professional build, I love the carving detail......a new build log for me to follow!!
  14. Mark, I do not know if the plans were ever published, but I could follow up if you are interested.
  15. Fantastic build! Hard to believe it started life as a plastic kit. Great detail photos and explanations on your construction methods
  16. This will be a build I will enjoy following! when do you start? we can't wait
  17. I would think that when you are going to build something that takes sometimes 1000's of hours one would use a proven modeling wood! That being said I am always looking for locally grown wood that might be useful in model building!
  18. Jim, Fantastic build! Very precise, great detail and very clean work.
