clearway
Everything posted by clearway
  1. in this day and age of laser cutting this shouldn't happen- the occre hms terror i just started had frames and keel that went together tight and true with just one little 1mm slice needed taken out of the slots for the bulkheads in the deck. Keith
  2. Hi Emmet the decks will sweep in a gentle upwards curve towards the stern just keep checking and double checking against plans- now you know why we don't recommend victory as a first build🤨- at least you waited til build no.2. Keith
  3. after seeing the hms terror build logs on here especially keith s build i made a start. have always had a fascination with the story of the north west passage and when occre released this it was a must despite the compromises with the kit. frames glued in place but deck still loose. also glued in the filling pieces between frames at bow and stern building slip to help keep the keel straight while planking don't know when next update will be as Victory taking priority at the mo! Take care all keith
  4. check out the build log for "shihawk" billings victory- he finished his in varnished wood and had the same conundrum. Keith
  5. Ty for input guys and i am still deciding as left light in colour i can see them and less likely to poke my eyes out, though i must admit that does look nice jeff- hmmmm choices🤨. back in ye olde shipyard and the t'gallant yard is ready for lifts, clewlines and sheets. also rigged the t'gallant tye. also a while back invested in a set of victory lanterns from caldercraft via the model dockyard- one on left is replacement one on right is the generic billings fitting! take care all and thanks to all who pop in for a gander. Keith
  6. ouch- we had snow this time last year - supposed to be an arctic wind coming in tonight so going from 20 centigrade today to 10 centigrade tomorrow! - i use scraps of ply from frames to bolster bulkheads to strengthen them if ply is thinnish. Keith
  7. i just used what came with the kit and varnished it- no stain or paint used. Keith
  8. love these smaller type of vessels ( maybe because my dad is a fisherman and i grew up on 50 foot wooden boats when they still had lots of varnished wood and polished brass). Keith
  9. you didn't waste much time jeff😉- what a difference to the plastic bin full of fittings that take several hours to sort through you get from billing!
  10. way to go m8y- i have dug my terror out and started on her and hold you entirely responsible. will have to start a build log, but main focus will obviously be on victory with this as a side project. keep up the good work. Keith
  11. welcome aboard the billings victory club Matthew, you dived in at the deepend then!- hang on it is a bumpy ride😁. before you install the middle bulkheads see if you want to alter them to allow for the stairwells - i did it for one set of stairs, but wished i had cut out the others and made new strengtheners either side of the hole (see philg88 victory log) a bit of work involved but worth it. Keith
  12. well spotted- proves ye olde joiners phrase "measure twice cut once" Keith
  13. always obey the admiral emmet! when i glue frames in i dry fit the deck to keep the bulkheads inline
  14. ty emmet-the ones on her now are varnished with black paint each end- still trying to decide if i should do that, leave them all varnished or go all black- this is where having a ciggy and pondering your model came in handy- will have a cup of tea in the morning while scrutinising them🙂 Keith
  15. thanks as always for looking in everyone. work still progressing on main topgallant yard, but in the meantime gave the mainyard stuns'l booms a coat of light oak stain/ varnish - cant decide if they look o.k. or if i should sand back and paint them black like the yard? take care all Keith
  16. yep that is the one i meant- i dont think it will be noticable as most people will view her from the side but it is your build at the end of the day- i just gave mine a coat of dark oak stain internally. Keith
  17. hi Emmet- didn't notice new info added- best to put any new update pics in the reply to topic as opposed to editing existing entries as people wont realise there is anything new- looking good and well done with the fix- the poop deck will need held down as it curves in 2 planes (mine did). i usually use masking tape wrapped round the deck and frames 3-4 times then leave for a few days till the wood glue cures. Keith
  18. Like what your doing to 3D the stern up a bit- how about painting the stern facing edge of the middle frame black to tone it down? Keith
  19. Hi emmet- i would use packing like you are considering - use strip inserted into the slot that goes either side of keel and sand back a little then marry up in stages till it is a snug fit if that makes sense. Keith
  20. sometimes the research is more interesting than the build- i have the same problems with having to add more detail to my billings HMS Victory as they simplified a lot including the yards and rigging. Keith
  21. thanks for the comments, likes and views everyone- hope the piccies are helping gieb8688. bit more progress with the deadeyes for the main t'gallant mast attached to backstays using ye old mark 3 deadeye spacer (high tech precision engineering🤣) mk1 and 2 got lost years ago!, also got the card bands on the fore yard and fore topyard. take care all and keep up the good work everyone. Keith
  22. one of the reasons why i read destruction manuals till my brains dribble out of my ears before touching any wood🤪😁
