Posts posted by hornet
- GrandpaPhil and mtaylor
- 2
Perhaps you could experiment with Model Aircraft Dope which is used to seal and tighten the ‘skin’ on model aircraft. I’ve not tried it but it may be worth a try.
- thibaultron, mtaylor and Dziadeczek
- 3
- BETAQDAVE, mtaylor, thibaultron and 2 others
- 5
1 hour ago, PRS said:
Sweet!
A few years back I tried to do a sopwith from model airways but the cast pieces were really a turn off and it is all sitting in a box in the closet.
Cast pieces on the Artesania Latina kits are quite well done. My biggest issue was that gluing was done with cyanoacrylate glue which I am allergic to. I used 5 minute epoxy which was awkward at times.
- Danstream, modeller_masa, Diver and 17 others
- 20
13 hours ago, Danstream said:
I love this. I hope the A.L. kit lives up to expectations.
Was quite an enjoyable kit to build. Instructions on CD not printed but you could print them off if so desired. Great detail in kit. Gave me a chance to practise my airbrushing skills too😀
- AJohnson, Baker, BLACK VIKING and 14 others
- 17
If making your own rope, haunting antique and collectable shops is worthwhile. Apparently the old cotton reels are now collectable. I’ve managed to gather quite a collection of linen and cotton threads in a range of colours and diameters that are much better quality than modern thread.
- mtaylor and thibaultron
- 2
I used Admiralty paints on my Bounty. Excellent.
- French Blue- Red Ochre
- Yellow Ochre
I have an older model of this machine. I improved it by adding another length of threaded rod to the front to hold a reel of thread. It makes the job a lot easier. I simply drilled and bent up two right angled brackets in Perspex then drilled a hole in the front (base) of each of the legs on the serving machine. I bolted on the the brackets then threaded the rod through holes drilled in the top of the brackets. I can change thread reels simply but undoing one of the nuts on the threaded rod and changing reels.
I use 2 part epoxy designed for coating fishing rod guides. Mix together then add very small amount of enamel paint. Place oven bake paper under window frame and apply mix. When dry, peel off oven bake paper and you will get realistic looking glass - concave or convex shapes can be achieved depending on how you apply mix. I usually use a toothpick.
If you do a google image search for the Byrnes draw plate you can see the step down between hole sizes used. This drawplate is brilliant. As to cutting bamboo cleanly, I use a pair of cutters with very, very sharp, fine jaws.
- mtaylor, Canute and Keithbrad80
- 3
this is my ropewalk. Works a treat.
https://modelshipworld.com/topic/14464-inexpensive-powered-rope-walker/?tab=comments#comment-449106
I have spent quite a lot of time haunting antique shops. I have collected a lot of old cotton and linen thread - people actually collect cotton reels - which is (in my opinion) often better quality that the tread produced now. I calculate diameter then make up appropriate diameter ropes using various numbers of threads on my home made rope walker. It is now one of my favourite model related pastimes.
- Ryland Craze, thibaultron, Canute and 1 other
- 4
Block Tumbler Help
in Masting, rigging and sails
Mine is made of a piece of poly pipe with 2 end caps. It has a four bladed sandpaper impeller. Fitted with a motor that is hooked up to a variable speed switch box.
