ferarr
Posts posted by ferarr
- Ryland Craze, JeffT, ccoyle and 3 others
- 6
- Jolley Roger, bruce d, mtaylor and 5 others
- 8
- Mirabell61, Rudolf, G.L. and 7 others
- 10
Hello: With the Google translator, I don't know very well what you mean, I guess you want to know this. I attached a drawing of a partner, Leopoldo. Greetings
(Hola:
Con el traductor de Google, no se muy bien a que te refieres, supongo que quieres saber esto. Te adjunto un dibujo de un compañero, Leopoldo.Un saludo)
- mtaylor, GrandpaPhil and coxswain
- 3
Hello everyone: I've had a few days, and I've continued with the model. I have made the grooves to place the "barraganetes", I have cut all the "barraganetes", I have built the covers of the "trancaniles", which I will then paste, and I will make the grooves for the "barraganetes" (more carefully, and more tightly, as it will be seen), And I built the "apostles." From here, I will place the keel and start with the helmet lining. Greetings.
(Hola a todos: He tenido unos días, y he seguido con el modelo. He realizado las acanaladuras para colocar los "barraganetes", He cortado todos los "barraganetes", He construido las tapas de los "trancaniles", que luego pegare, y volveré a hacer las acanaladuras para los "barraganetes" (con mas cuidado, y mas ajustadas, ya que quedara visto), Y he construido los "apóstoles". A partir de aquí, ya colocare la quilla y empezare con el forro del casco. Un saludo)
- Rudolf, Tim Curtis, michael mott and 6 others
- 9
Well, I've finished with the deck of the deck, I had to rebuild part of the gunwales by a small accident to scrape the deck, but the truth is that you do not notice the arrangement.
A greeting
(Bueno, ya he terminado con la tablazón de la cubierta, he tenido que reconstruir parte del trancanil por un pequeño accidente al raspar la cubierta, pero la verdad es que no se nota el arreglo.
Un saludo)- mtaylor, hexnut, paulsutcliffe and 8 others
- 11
Congratulations, everything comes to an end. I'm glad you did not abandon the project. To the next, and improving! a greeting
(Enhorabuena, todo llega a su fin. Me alegro que no abandonases el proyecto. ¡¡¡a por el siguiente, y mejorando!!!
Un saludo) -
Try making a putty with white glue, water and cigarette ash, it is black. Once applied, with a damp cotton cloth remove the excess. Care that is very hard. When dry, scrape with a blade. If you do not have ash, dye the glue with some Chinese ink. Very important not to damage the model, do tests outside the boat. A greeting
(Prueba a hacer una masilla con cola blanca, agua y ceniza de cigarrillo, queda de color negro. Una vez aplicada, con un paño de algodon humedo retiras el sobrante. Cuidado que queda muy dura. Cuando este seca, raspa con una cuchilla. Si no tienes ceniza, tiñe la cola con un poco de tinta china. Muy importante para no dañar el modelo, haz pruebas fuera del barco.
Un saludo.) -
Hello, you have bought a nice kit. It is of the best time of Artesania Latina, later it has been getting worse. I put some pictures of the support that I use, made with a plywood and some boards, for the cover of the cover goes very well. If you do not like this, think about how to make a support that is useful, and comfortable. Cheer up. A greeting.
(Hola, has comprado un bonito kit. Es de la mejor época de Artesania Latina, posteriormente ha ido empeorando.
Te pongo unas fotos del soporte que yo utilizo, realizado con un contrachapado y unas tablas, para el forrado de la cubierta va muy bien. Si este no te gusta, piensa en como hacer un soporte que te resulte util, y comodo. Animo.
Un saludo.) -
- Mirabell61, tlevine, davyboy and 8 others
- 11
Hello everyone. Already placed the gunwales. I should have done the firing of the poles, but I do not have the drill column at hand, so I have advanced part of the covering of the deck and the cutting of the deck boards. a greeting (Hola a todos. Colocado ya el trancanil. Debería haber realizado la fogonadura de los palos, pero no tengo a mano la columna de taladro, así que he adelantado parte del forrado de la cubierta y el corte de las tablas de la cubierta. Un saludo)
- hexnut, GrandpaPhil, mtaylor and 3 others
- 6
Hello : I have assembled a plywood to start working on the deck planking and for the execution of the gunwales. I have marked some lines of reference, and I have cut the stem, which is pending to thicken, but which I needed for the separation of the apostles, (Sorry, I do not translate it into English). I also put a plan of the planking of the cover. I had my doubts about the arrangement of the deck tables, but it seems that Chapelle draws them like that. Where I have doubts is in the width of the gunwale when it runs through the transom, I do not know if it should have the width of the rudder trunk, or not. a greeting
(Hola a todos:
Ya he montado un contrachapado para comenzar a trabajar en le tablazón de la cubierta y para la ejecución de los trancaniles.
He marcado unas lineas de referencia, y he cortado la roda, que esta pendiente de regruesar, pero que necesitaba para la separación de los apóstoles.
Os pongo también un plano de la tablazón de la cubierta. Tenia mis dudas respecto a la disposición de las tablas de cubierta, pero parece que Chapelle las dibuja así.
Donde tengo dudas es en ancho del trancanil cuando discurre por el espejo de popa, no se si debe tener el ancho de la limera del timon, o no.
Un saludo)- GrantGoodale, kees de mol, dvm27 and 6 others
- 9
Hello: A partner convinced me to make the "top timbers" from the outside of the helmet, so I cut the frames, and proceed to mount them like that. A greeting.
(Hola:
Un compañero me convencio para realizar los "barraganetes" desde el exterior del casco, así que he cortado las cuadernas, y procederé a montarlos asi. Un saludo.)- davyboy, hexnut, michael mott and 3 others
- 6
- BETAQDAVE, AntonyUK, Tim Curtis and 8 others
- 11
- Siegfried, BETAQDAVE, aviaamator and 5 others
- 8
Nice work, I like it.
A greeting
(Bonito trabajo, me gusta.
Un saludo)- popeye the sailor, Mirabell61, Piet and 2 others
- 5
Hello: The paper helps me to mark and delimit areas, then it will be eliminated in those areas where it affects me for the gluing of other pieces. A greeting
(Hola:
El papel me sirve para marcar y delimitar zonas, luego se eliminara en aquellas zonas donde me afecte para el encolado de otras piezas.
Un saludo)- mtaylor, Mirabell61 and BETAQDAVE
- 3
Hello everyone:
I have finally started the "Dos Amigos".
I'm using the plans included in the book "The history of American Sailing Ships, Chapelle."
I have also found some documentation in the book "Global Schooner, Marquardz", and searching, the original plans of the "Fair Rosamund" in the museum of Greenwich (It is how they renamed the boat, once captured, and the plans of the house Assembly "Golden Kits" back in the 70s / 80s.
The differences between the first three planes is minimal, I believe that produced by deformations in the copies. Of the rooms the biggest difference is that the length is 2/3 cm. minor, otherwise they are quite similar.
The scale is 1:50.
Well, I put some photos.
A greeting
(Hola a todos:
Por fin he comenzado el "Dos Amigos".
Estoy utilizando los planos incluidos en el libro "The history of American Sailing Ships, de Chapelle".
También he encontrado algo de documentación en el libro "Global Schooner, de Marquardz", y rebuscando, los planos originales del "Fair Rosamund" en el museo de Greenwich (Es como renombraron al barco, una vez capturado, y los planos de la casa de montaje "Golden Kits" de allá por los años 70/80.
Las diferencias entre los tres primeros planos es mínima, considero que producida por deformaciones en las copias. De los cuartos la mayor diferencia es que la eslora es 2/3 cm. menor, por lo demás son bastante similares.
La escala es 1:50.
Bueno, os pongo algunas fotos.
Un saludo)
- prutser, Mirabell61, coxswain and 9 others
- 12
Hello Liberto, indeed, the wood has a very hard appearance, it must be difficult to work. It has an incredible finish, but for a teacher like you, that should not present any problem. Thank you for letting us enjoy your work
A greeting.
(Hola Liberto, efectivamente, la madera tiene una apariencia muy dura, debe ser difícil de trabajar. Queda con un acabado increíble, pero para un maestro como tu, eso no debería presentar ningún problema. Gracias por dejarnos disfrutar de tu trabajo.
Un saludo)
Dos Amigos by ferarr - per Chapelle drawings
in - Build logs for subjects built 1801 - 1850
Hello: At the moment I have it stopped. I had not thought about putting it, thanks for the comment. The slave ships that I know do not carry them, or do not represent them on the plans (L'Ouragan, Amistad), although I do know of their existence on other larger ships (L'Aurore). I see that you have finished your "Dos Amigos", put some more photos. A gretting.
(Hola:
De momento lo tengo parado.
No había pensado en ponerlo, gracias por el comentario.
Los bergantín goleta negreros que conozco, no los llevan, o no los representan en los planos (L'Ouragan, Amistad), aunque si conozco su existencia en otros barcos mayores (L'Aurore).
Ya veo que has terminado tu "Dos Amigos", pon alguna fotos mas.
Un saludo
