davyboy
Posts posted by davyboy
  1. Hi drtrap,
    They are the Topmast backstays,respectively from fore to aft.
    The first is the Shifting Backstay.
    The second is the Breast Backstay.
    The third is the Standing Backstay which is set up with deadeyes.
    I have checked Steels' dimensions of Standing and Running rigging,he quotes for a 6th rate ship
    such as HMS Snake :-
    4 1/2" rope for the Standing Topmast Backstay and the Shifting Backstay and 3" rope for the Breast Backstay
    hence the two different sizes quoted on your plan for A and B. They have nothing to do with yards or running rigging.
    I have just noticed that there is an almost identical arrangement on the Foremast except the Breast Backstay is further aft.
    I hope this helps with your problem.
    Kind regards,
    Dave :dancetl6:
  2. Good evening B.E. An excellent job of planking,I'm sure it will be as good as any planking to be seen on the forum when sanded and a finish applied. Best of luck with treenailing,I elected not to do this at the time due to poor eyesight. I'm currently making up all my rigging and bagging the finished articles then it's just a case of fitting it when I put the mast and spars in. The end of the tunnel is in sight after 3 years.:):)
    Keep up the good work,
    Dave :dancetl6:
  3. Rob 206,
    The Restoration Warship by Richard Endsor.
    The Warship Anne by Richard Endsor.
    Old Ships Figureheads and Sterns by L.G. Carr Laughton.
    First Rate by Rif Winfield.
    Two other books which may be of interest to you.
    The Rogers Collection of Dockyard Models 1st and 2nd rates by Grant H. Walker.
    17th and +18th Century Ship Models from the Kriegstein Collection by Arnold and Henry Kriegstein.
    These books are published by Seawatch Books who advertise on this forum main page.
    The Endsor titles are both available on Abe Books,didn't check the other two but they probably are too.
    These should hopefully cover some of your 17th century interests.
    Dave :dancetl6:
  4. Your planking is looking very good B.E. Top job if I may say so.
    I reached a milestone yesterday,all deck fittings,guns,cleats et al are now fitted on my Cheerful. I am now debating whether or not to make 4 dozen 1/8" hooked blocks for the training tackles. Masts,spars and sheaved blocks are already made so will have to decide soon methinks before starting masting and rigging. Enjoy your holiday in North Yorkshire,some lovely scenery there. Good ale too :D
    BTW,have you any idea whether or not there should be cut-outs in either the main or forward grating to pass the anchor cables below. Nothing shown on the plans.
    Dave :dancetl6:
  5. Hi Julie Mo,that is an impressive block. Your lower block does require a Becket at both ends. A suitable length of rope had the ends spliced together forming a ring with an iron thimble lashed in at each end of the block. One for the hook the other for the falls. Hope your good at splicing :D:D;). Also,these rings were served overall.
    FWIW,the largest vang blocks fitted were a 9" double and a 9" single.  This on 1st,2nd and 3rd rate English ships,can't speak for other lands.
    Looking forward to seeing the final result,I know you will make an excellent job of it.
    Dave :dancetl6:
  6. Hi Clare,
    It's nice to see a build of another unusual subject. A bit of a pain when you have problems trying to obtain information. One of our MSW members in Japan is Mitsuaki Kubota aka fake johnbull. Perhaps he might be able to help you out,may be worth sending him a PM. Just a thought,you could be lucky.
    Dave :dancetl6:
  7. Antony,a fun build it may be but it's also a build of an unusual vessel. Watching the video brought back memories of when the Wife and I lived in Thailand. Used to see these Long Tail Boats regularly on both the Mekong and Chao Phraya rivers. They are a common design in S.E. Asia I believe,will be following this build.
    Dave :dancetl6:
  8. Hi BE,
    Nice to see you back working on Cheerful,thought you had gone AWOL :D I cheated slightly when planking the square tuck,made the planks 7/32" wide which gave a nice 5 plank fit. When you come to fit the sternpost,to avoid trying to match it to the counter (ruddy nightmare,I couldn't do it to my satisfaction) you could do what I did. You have to cut a hole anyway for the rudderhead so why not carefully extend it fwd and make a full length sternpost. It's shown on the plan anyway next to the 2 part one,pretty sure there should be a big enough piece left from the lasered out part sheet to do this. Anyway,you're the shipwright so up to you,just saying how I did it.
    As usual,keep up the good work.
    Dave :dancetl6:
  9. I,m seriously thinking of buying this book now that I know the plans are 1:48. My Cheerful build should be finished by late autumn and I fancy doing a second scratch build of a small ship, Guess I'll just have to suck up the ludicrously expensive postage of 30$ US :angry: (over 40% of the book price)
    Dave :dancetl6:
  10. HI Sandor,
    Having enlarged the pic I notice that the two broadside cannon are not on gun carriages but on what appears to be pivoting slide carriages. Not much scope to stow these for transport as they are fixed to the deck pivot at the front. The stern chase guns could be stowed and lashed against the stern bulwarks I guess. You don't show a pic of the fwd cannon which I expect is a slide mounted or swiveling large bore cannon as this is a gunboat. No idea what would be done there i'm afraid.
    Dave :dancetl6:
  11. Hi Patrick,
    The Golden Hind would not have had Boomkins, they didn't appear on English ships until circa 1710. (Lees Masting and Rigging states the Foretacks were led through holes in the stem) Her Foretacks would have been led almost identically as shown in your last pic with the red pointing arrow,also as in the pic's Christian previously posted. The 1637 engraving of the Sovereign of the Seas also shows the same lead for the Foretacks.
    Regards,
    Dave :dancetl6:
  12. Hi Patrick,
    In Brian Laverys Book the Arming and Fitting of English Ships of War he writes this on page 37. According to Sir Walter Raleigh,the Capstan was first used for weighing anchor in the reign of Queen Elizabeth 1st in the second half of the 16th Century. Though there is evidence it was in use by 1546. No mention of double Capstans in English Ships until the latter part of the 17th Century.  Hope this is of some help to you.
    Dave :dancetl6:
  13. Jack,this is a really interesting build of an unusual subject and a good job you are making of it too. Hope you can easily repair the boom attachment,Murphy's Law strikes again :(  I imagine it's a pretty exhilarating experience sailing a full sized Ice Yacht at 40 - 50 MPH with your rump about a foot above the ice.
    Dave :dancetl6:
  14. Hi BE,there's nowt wrong with your planking,much better than some I've seen :cheers:  With regard to the square tuck it's pretty straight forward really,I just took the outer shapes from the plans and went from there. I had to have a couple of goes making the tiny outer planks however,fiddly little things. As you bought the kit likely the shapes are provided. I have made and am still making everything on my model excluding the windlass,didn't have a mill or table saw when I ordered the plans and it 3 years ago.
    Have fun,
    Dave :dancetl6:
  15. Hello Ed,absolutely superb work. I can well imagine that the air was blue when belaying in such a confined area. I had a similar problem belaying,what I did was pass the line through the pinhole then placed the pin in. This let me adjust the tension as necessary then leaving the line in place pushed the pin tight,belaying the line on the pin as normal. When the rope coil is hung on the pin this can't be seen. A fiddle of course but it saves a lot of cursing etc etc.
    Dave :dancetl6:
  16. Excellent work BE. You really can't go wrong  following Chucks' instructions. One question,are you going to stain the hull a darker colour ? Personally I find that South American "boxwood" far too pale for my taste. The hull of my model is mainly built with dark pear,much closer to the colour of oak but that's just my preference.
    Dave :dancetl6:
  17. Hi Siggi,
    I have 2 photographs of a contemporary model of the 60 gun ship HMS Achilles of 1757. I took these in the Science Museum in London 11 years ago,there are no Fish or Horseshoe plates shown on this model. It postdates HMS Tiger by a decade so it may be ok to assume they were not fitted on your ship. However,it could be that they were just omitted on this HMS Achilles model,who knows. Yet,all other hull fittings are shown as fitted. Hope this is of help to you. Perhaps one of the very knowledgeable forum members hopefully may be able to answer your question.
    Kind regards,
    Dave :dancetl6:
  18. Hi Karl,
    I have just been admiring your superb workmanship but one thing puzzles me. The large stern grating has the fore and aft planks raised higher than the thwartship planks. This seems to me to be rather dangerous and could cause a person to catch a foot in this gap and trip up (stolpern)
    Then,I see in a later photo taken below the stern and notice that the grating planks appear to be flush with each other. No criticism meant, just an observation but I would have thought this should be the top side of the grating giving a level area to walk upon.
    Kind regards,
    Dave :dancetl6:
  19. Hi John,it's very easy to blacken copper with a liver of sulphur solution. Takes seconds to do after cleaning the part then just rinse off with water,you can also blacken copper items in situ then rinse it off. It doesn't do any damage to nor discolours the wood. Check out Ed Tostis' Young America build log,he uses it for all his copper work.
    Is that very nice Tearoom still open in Harrogate ? I was in there several times many years ago,very nice pastries were enjoyed to be sure.
    Dave :dancetl6:
