Everything posted by ccoyle
Anna, Something for you to think about on future models -- in your fifth photo down, the planks make a hard bend where they meet a bulkhead near the bow. The planks should follow the curve of the hull, which you can see in the shape of the false deck. This requires that the bulkhead formers be beveled, which means that they are filed or sanded in a manner that allows the planks to make the desired curve without kinking. You can see how this is done in some of the other build logs. Cheers!
Jeff, it sounds like you have a good plan of action in place already. Just keep thinking ahead about whether any sub-assemblies will be first of all accessible as you add additional bits, and secondly will they be easily knocked off as you continue working. And with a model the size of Victory, you will have a lot of such thinking and planning to do!
- 49 replies
- victory
- billing boats
Sorry for your loss. The best way to deal with your husband's equipment is to donate it to a local modeling club. They can auction the items to raise funds for the group. If you would like to preserve some anonymity, you can contact any of the staff here by private message, let us know your whereabouts, and we can put you in touch with a club in your area. Condolences, Chris
I'm pretty certain that I would go insane if I attempted this kind of work, which partly explains why I have never attempted anything like it!
- 82 replies
- boat
- lak-design
I believe you are correct on items #2 and #3. The first item, though, are simply eyebolts. These can be used for a number of purposes but are generally used as anchoring points for blocks or for securing rigging. If you run out of them, don't worry, as additional ones can easily and inexpensively be made from blackened annealed wire.
Congratulations! A lovely model -- the glaze-like finish on the lower hull is amazing. Cheers!
- 70 replies
- pen duick
- artesania latina
New and need help to identify a mystery model? Read here first!
ccoyle replied to ccoyle's topic in New member Introductions
The Nautical General Discussion area (down towards the bottom of the topics list) would be a good spot. -
And it shows! Your CNC work is definitely an improvement on the kit materials.
- 120 replies
- mercury
- victory models
Unto All Who view these Presents: Greetings
ccoyle replied to Tom Matthews's topic in New member Introductions
Welcome! I can't speak to the availability of the plans that you are looking for, but early torpedo boats are a fairly common subject in card modeling. In particular, Orel, a Ukrainian publisher, have put out quite a number. You can browse their catalog here. -
Congratulations on your finished model!
- 131 replies
- finished
- artesania latina
Welcome, Bill. OcCre make a kit of Dos Amigos. https://www.occre.com/model-ship/dos-amigos.html?___store=en&___from_store=en
HMS Victory by Bazzg - Mantua - 1/200
ccoyle replied to Bazzg's topic in - Kit build logs for subjects built from 1751 - 1800
Okay, what I am about to tell you, you may not want to hear, but trust me that I'm telling you this so that you will have long-term success in this hobby. You are off to a bad start. You already have a couple of strikes against you because you are starting out on both a really difficult model to build and building it in a scale that is a real booger for beginners. To get an idea of what you are up against, please click on this link and read our cautionary tale for beginners. Next -- put this model aside, for now at least. It is an excellent example of a "hobby killer." What you need is a suitable beginner's kit that will give you a reasonable chance of success. For some ideas on beginner's kits, have a look at this topic. Essentially, you should start off with less of everything: less planking, less rigging, less guns, etc. Everything except scale -- you want more of that, i.e. larger scale. I suggest something on the order of 1/64 scale or larger. Third: read. An excellent book for beginners (I cut my modeling teeth on it) is Frank Mastini's Ship Modeling Simplified. You can probably get a copy through your local library. Finally, browse through the kit build logs and look for two things. First, look for build log titles that include verbiage like "first build." These are modelers who are in the same figurative boat as you. Second, from those logs, have a look at the ones that say "FINISHED" in the title. Those are logs for models that beginners have successfully completed. Most of them will be for fairly simple kits, but the important thing is that they finished. Again, I'm saying this because I have been in this hobby for 20 years and have witnessed many beginning modelers embark on their modeling adventure with a kit that is over their head. They usually get as far as planking the hull and then give up. You don't have to be one of them, but starting out with a simpler kit and a better idea of how to get started will go a long way towards making that happen. Kind regards, -
@mtaylor: Mark, so far I think this is a great kit. I do think that the MK folks could benefit from having a native English-speaker go over their translated instructions to iron out the occasionally confusing bits, but the plans and diagrams help alleviate that problem. I'm currently working on creating some impressionistic bolt heads, and the wire supplied for the job is the wrong gauge to fit the holes in the metal work, but I've really had very few problems to this point. @Katsumoto: I'm using paint -- cheap acrylic paint, in fact, but I like the results. Cheers!
- 117 replies
Small update. Decided to add a bit of color (technically, black = absence of color -- oh, well). Gave the hull a final sanding and going over with fine steel wool. Added the rear deck.
- 117 replies
Great to see an update! I had been wondering where you'd gone off to.
- 244 replies
- borodino
- dom bumagi
I had this same problem with some of the plywood supplied in the upgrade kit for my Victory Models (subsidiary of Amati) HMS Fly, and Amati is not known for poor materials. I can see where improperly glued-up plywood would be difficult for the quality control people to spot, but there's little excuse for bad strip wood. Warping, on the other hand, can occur anywhere post-production if the kit is not stored properly -- not pinning that on you, just saying it could have happened anywhere along the line of distribution.
Don't worry about the deadeyes being loose, because the shrouds will hold them in place once you attach them. What you will need to be careful about, though, is that your wire strop is sufficiently long enough to form the little hooks at either end; you'll need those to keep the strops firmly attached to their chainplates.
Wow, look who's back! Just in time for Christmas! Great to see back at work on this project. Cheers!
Shopping on eBay: A Primer for Newbie Ship Modelers (Parts 1 and 2)
ccoyle replied to ccoyle's topic in Wood ship model kits
Oops! Yes, you are correct on that point. -
Oliver, I would think that if you are successful with your Santa Maria build, then Terror should be something you could expect to pull off. Perhaps a bit challenging here and there, but it wouldn't be much fun otherwise, would it?
Certainly, and I know that there are a lot of people who will agree with you on that point. On the other hand, I have made about 20 or so purchases (not a lot, I know) on eBay and have never had any trouble. My intention in publishing this post was not to discuss the perils of online auctions, which are real and not to be taken lightly, but rather to show what can be had for those who feel comfortable using the medium. Cheers! -
PART 2: How to Spot a Good Deal Okay, despite what some people believe, there are still good deals to be had on eBay, if you know what to look for. In Part 2, we'll look at some potentially good deals. CAVEAT: As some comments have pointed out in this thread, there are inherent dangers in shopping at online auction sites. I should have written in my lead-off post that I was writing under the assumption that you, dear reader, already knew about those dangers. But if you didn't, now you do. Back to the shopping! Potential Good Deal #1 Here's a potentially great deal, especially for a new modeler. There's a number of reasons why this could be a great deal. First, it's Artesania Latina's Swift pilot boat. It's not a particularly sexy model, but it is a great beginner's model, and there are a bazillion build logs of finished examples here at MSW. It's a model the average beginner has a high probability of completing. Second, the seller posted a lot of photos showing that the kit contents are all there and in good shape, plus a beginner's book is included. Third, the starting bid is only $20. Granted, shipping is also $20, but still -- $40 all together is a good deal. The point worth emphasizing with this example is that pretty much any beginner's model is going to set you back at least $50 if you were to buy it from a dealer, so getting it for less than that is good. If a bidding war were to develop over this kit, and the price were to go over $50, I'd probably let it go, because the Swift is one of the most common models sold on eBay, and sooner or later another deeply discounted example will turn up (in fact, I found several better deals on this same model while researching for this post). Potential Good Deal #2 This next potential good deal is a candidate for essentially two reasons. First, it's a Midwest Products kit. Midwest is now out of business, but their kits still turn up frequently on eBay, and Midwest made the closest thing to fool-proof model kits as one could wish for. The first two wooden models I ever built were from Midwest, and there are literally dozens of examples in our build logs and galleries. Second, the starting bid on this kit is cheap, cheap, cheap. Assuming that the seller doesn't ream you on the calculated shipping charge, this could be a great bargain that will provide any newbie with valuable experience in working with wood. Midwest kits are good examples of kits whose prices are low simply because there are a lot of them still in circulation. They're good kits regardless of the low price. Remember my warning from Part 1: the fact that a kit is claimed to be "rare" doesn't mean that the kit is inherently valuable. Potential Good Deal #3 This next example is potentially a steal for a modeler who is feeling a little more ambitious and has a hankering for riverboats. Amati is a quality kit manufacturer, and the seller has set the starting bid at $150, with free shipping. Here's where doing the homework pays off: the MSRP on this kit is $439, so a buyer could potentially acquire this kit for up to 66% off the MSRP. That, my friends, is a deep discount. Whereas most sellers seem inclined to set their starting bids too high, occasionally a seller, like this one, will set the starting bid quite low. Knowing what the kit retails for is the key to spotting the deal. Potential Deal #4 -- or Not (Toss-Up) Whether this next deal is a good deal or not depends on how badly you want to save $5.00. This example happens to be from an eBay store. No bidding is necessary -- you can simply snap this kit up for $168 plus $29 shipping, for a total of $197. Your model will be shipped from Russia, which means it ain't gonna arrive tomorrow. However, you can order the same kit from Model Expo using their current 25% off promo (as of 22 Dec 2018) and free shipping -- for $202. It's pretty much a toss-up. I mainly included this example because it shows that there are legitimate sellers on eBay who are not trying to bilk you. They're selling their wares at prices that are competitive with more familiar retailers. So that's basically it. If you do your homework, know what to expect to pay in advance (and don't allow yourself to over-bid), and check listings over thoroughly, you can find some good deals on eBay. I found others besides the ones shown here, but they were essentially further examples of the scenarios already illustrated. Have fun shopping! -
To drive this particular point home, I received an email from Model Expo this morning featuring a new promotion -- 25% off any order with no minimum. That makes the $419.99 Constitution kit now only $314.99, plus free shipping. In this instance, it really pays to have an idea beforehand of what you should reasonably expect to pay. -
PART 1: How to Spot a Bad Deal Hey, there! It's Christmas time, and I am off work for two weeks. Hooray! I'm also out of town, so I don't have lots of time for modeling. What I do have time for is knocking around on the Internet, including doing some window shopping at eBay. Ah, eBay ... once upon a time, not so very long ago, eBay (the Internet auction site) used to actually be a place where people disposed of unwanted stuff. It was like a gigantic yard sale. Back then, a person could find some real deals. But then someone discovered that they could make a lucrative career out of selling stuff on eBay, and now most sellers are either bona fide retailers or folks seemingly hell-bent on extracting retail prices (or higher) on yard sale merchandise. To borrow a line from Obi-Wan Kenobi, eBay has become a "wretched hive of scum and villainy." Which brings me to the topic of this post. There are still a few good deals to be had on eBay, but you have to wade through a bunch of garbage to find them. Sadly, if you're new to this hobby, you may not know how to separate the true deals from the crazy efforts to simply part you from unjustifiable gobs of your money. So, I thought I would take some time and show you some real examples of the good, the bad, and the ugly of Internet auction site ship model kits. Are you game? Then let's get started! 1. First Things First: AVOID PIRATES LIKE THE PLAGUE! Regrettably, eBay has become a haven for unscrupulous retailers with no regard for intellectual property rights. MSW considers these folks to be beyond the ship modeling pale (see topic here). The first thing to look for is the words "From China." If you see that phrase, then speedily move on! 2. Clueless Sellers eBay is just chock-full of clueless sellers, i.e. people who are deeply ignorant of their kit's real value, as opposed to its imagined value. Have a look at the following example: This seller is asking for a jaw-dropping US $1098.00 for a Constructo HMS Pandora. I happened to read elsewhere why this seller thinks that this kit is worth so much. They think that this kit demands a premium price because it is rare and out-of-production (OOP). They are wrong. If you're a newbie and interested in buying a kit off of eBay (or any online auction site, for that matter), you really need to do your homework beforehand. This seller didn't do his homework, and that's why he has attached a ridiculous price tag to this model. Here's some things you need to think about before hitting the bid button: Is this a reputable kit manufacturer? In this case, the answer is yes. BUT ... that doesn't necessarily mean that this is a good kit. Constructo makes kits, this is true, but they've never been considered one of the premier kit makers, and they're certainly not one of the innovators in our hobby, either. WHY is this kit OOP? If it's such a great kit, why did Constructo stop making it? Consider this analogy: Chevrolet made over 2 million Vegas between 1970 and 1977. The Vega is now both OOP and (thankfully) rare. Chevy Vegas don't command premium prices because they are rare and out of production. Neither do Constructo kits. 3. Why Buy Used When You Can Get It New for the Same Price?? Some clueless sellers are easy to spot (like in the previous example) because they are asking way, waaaay more than what the kit is worth. Other sellers are clueless because they are asking the unwary buyer to pay as much for a used and possibly OOP or "new old stock" (NOS) kit as that same kit would cost new, like this one: The first thing you need to know about this kit is that it is a Mamoli kit. Mamoli is out of business. The Mamoli line of kits, including Blue Shadow, is now being made and sold by Dusek. Word on the street is that the new Dusek versions are better than the old Mamoli versions. Worse still, this seller is asking for a starting bid of $175, which is about what a new Blue Shadow will cost you straight from Dusek (taking into account exchange rates and VAT), so why would anyone want to buy an older, lesser-quality version for the same price? Caveat emptor! 4. Yeah, It's "Vintage," But So What? What do sellers really mean when they say that something is "vintage"? Vintage just means that something is old, but the word "vintage" has less of a pejorative connotation. Check out this example: There's a reason why you don't see new Scientific wood model kits anymore: they're bad kits, comparatively speaking. Sure, they were okay back in the day, but kit design has progressed far, far beyond carved balsa hulls and printed or die-cut parts. Another reason to avoid "vintage" kits is that wooden kits don't age well like fine wines. Old kit wood gets dry and brittle. Old kits also usually have inferior fittings and instructions. Best to leave the vintage kits to the collectors. 5. Too Close for Comfort Lastly, here's a sneaky example. This one looks good at first glance. It's a current, well-designed kit from a reputable manufacturer. The "Buy It Now" price is $69 less than what the manufacturer, Model Expo, is asking for the same kit at their website. BUT ... Model Expo offers free shipping on orders over $150, and this seller doesn't. So the real difference in price (ignoring for now any promotions that Model Expo might be running -- they usually always have something going) is only $22.20. For that slight bit extra you'll get the peace of mind of buying direct from the manufacturer PLUS getting their iron-clad replacement guarantee for any missing or damaged parts. Suddenly that $350 price doesn't look quite so attractive. So those are some examples of pitfalls awaiting unwary newbie modelers at eBay -- it's a dangerous e-commerce world out there! But fear not! In Part 2, I will show that there are still a few good deals to be found, even if they are now fewer and farther between. Until then!
