Everything posted by amateur
4 pieces as in: 30mm x 2mm x 2mm ? Sometimes I wonder why kit-sellers just don't include enough strip of the size they need...... Assuming my assumption is coorect. Wallnut is pretty tough and can have quite some grain, and 4mm is too thick to use a knife. My guess is that using a knife will lead to splitting and splintering of the wood. recommendation 1: Is the piece going to be painted? if so: try finding some strip in a size that matches the 2x2mm thickness you need. recommendation 2: I have some small (thin, and rather sharp) X-acto saw blades that can be put in a knife-holder. These are much finer than normal fretsaws, etc. Couldn't find an X-acto pic, so I took an other one. Jan
I'll have to seriously remove some dust, and do some minor restoration Jan
Thanks, and yes, 1:200 is half the size of 1:100, I know, but still, seeing the size of the model in your hand make you realize that it is really small (although, with 42 centimeters, it is still a model of some size) I started cutting the V108 bottom, and the positve news was that the card could be bent flat quite easily when the parts were cut out. The problem is that in this thickness (just under 1mm) my artshop only had this rather coarse greyboard. The nice ones start at thickness of around 1.5 mm, which is too thick for this model. Dutch shops in my area tend to have large amounts of rather glossy coloured thin cardboards, but not so much in the thicker stuff, also the assortment of printable thick paper is small: 80, 120 and 160 grams. 160 grams is around .25 mm thick. For the larger parts, I would have liked paper of around 200 grams, but that was only available in postcard-size. Jan
But I did something I perhaps shouldn't have done: As I was a bit interested in the size of the model, I put together the laser-cut framing. (still without glue). And What I "feared" is true: 1:200 in paper is far, far smaller than in wood scale 1:100 The midd-frame is in tow parts, as are the "false decks' to get the frames in the correct position. I guess that this is where this log stops now, I will try to find some time to start on V108, and open a log for that one. I glued the frame-parts to a piece of cardboard, which - as expected - went 'non-flat' in all posiible directions at once (and yes, this pic was taken after the piece of cardboard rested under a couple of heavy books overnight ) To be continued (some time in the future) Jan
The funny thing was that it was build upside down, and that planking consisted of dive planks only. I wonder wheteher or not your wood will still take bending strain, or that it has become brittle over the last 20-something years. Jan
Not tpp strange that you can not find a log: the model was pretty well out of production when internet started. it was my first larger wooden kit. So yes, I did this ship, and it is still in my room (somewhere under a large pile of dust ) at leats, i think you mean this one Jan
I decided to give myself a bit of practice, by trying V108 first. I am nit that practised in paperwork, and as Eversten is a full-hull, I want to have some trial and error possibilities Jan
Thanks, I did find that one. As far as I know the onlu buildlog inthe internet... I do hope that log will continue, as it is always helpfull to have someone ahead of you. Jan
Sorry, that's what was mentioned on the site of one of the shops i visited... I'll change my text. jan
Actually, the number of pages diagrams is largee than the number of pages with parts. Jan
To give you some idea on the original, a couple of pics, there isn't many more, as the ship led a rather quiet, not to say dull life.... the pic with the three white ships is taken in Amsterdam, and Evertsen is the middle one. The ships had higher masts in this pic, as they were wired for radio-receiving equipment that was used for communication with the far east.
Today I received a new modelkit, a paper one, by the Polish firm Answer. It is a paper model ofa Dutch protected cruiser from 1894, named Evertsen. I checked the internet, and I can notfind any completed models. I can't promise that I start soon with the build, as I recently moved, have a garden to do, still have a paid job, and a couple of models in various stages of completion. But who knows..... I can't figure out why Answer chose this protected cruiser, there were more that were larger, more elegant, and were more famous (check protected cruiser Gelderland, that was the most famous of all). Evertsen had around 20 years of coastal duty, but never fired a gun 'for real', and ended on the breakers yard just before the first wold war. secondly, I van't figure out why Answer chose this livery: almost all Dutch ships of that era had three colourscheme's over their life span. Blach hull, white hull, yellowfunnels, both with gilded scrollwork onbow and stern, and finally a dull light gray, that was used for hull, superstructure and scrollwork. Guess what colourscheme Answer used. Yep, you guessed it to get some idea on my task ahead, some pics of the model, which came together with lasercutted frames, some PE-details, and a couple of brass guns.
That is correct: the inside structure of Dutch ships was comparable, as their hull-form was comparable: broad, bluff bow.\ Jan
- 305 replies
- utrecht
- statenjacht
Btw did cutty ever had 6 yards to her fore mast? I only can find pics with 5 at the fore, and 6 to the main. this ship has 6 on both jan
This thread is completely dead. Don't think you'll get much response here .... the pic is not in the list suggested by Carl, and the details in the pic are too vague to check whether it could be cutty. Jan
120 is fast enough. Regarding most people combine driving with phoning, playing internetgamnes, checking whattsapp, facebook etc, you can eve argue that it is too fast Jan
- 305 replies
- utrecht
- statenjacht
The one in the background also deserves a couple of close-ups! Jan
- 28 replies
- cutter
- lady nelson
(and 3 more)
Like sailor said it above: it is the background that tells you it is a model!
- 3,618 replies
- young america
- clipper
As a birthday-present, its value can't be overestimated Jan
Looks good. I actually expected a rather even coat of grey.... this looks a lot livelier Jan
silly question: what type/thickness of cardboard do you use for the outer skin? Jan
- 38 replies
- digital navy
- v108
Goed nieuws, daar houden we van! Hopelijk lukt het een mooie baan te vinden! Jan
- 434 replies
- pelikaan
- beamtrawler
