paulsutcliffe
Everything posted by paulsutcliffe
  1. Very nice Michael must be great to work at that scale and show all the lovely joints etc Regards Paul
  2. What a great looking model, tempts me to have a go at this one myself, Nice work love the old dreadnoughts Regards Paul
  3. Thanks Michael, that was the effect I was aiming for after umpteen layers of sanding sealer Regards Paul
  4. Looking great on the stand Michael, I'm getting Confused which is the model and which is the real boat😀😀 Regards Paul
  5. Beautiful work as usual Ed and thanks for the arrow 😀😀
  6. Hi Mike I find polishing the Liberon sanding sealer with wire wool removes the shine, makes very smooth and imparts a sort of satin finish that is very acceptable, and can be polished even further with a light rubbing of oil Regards Paul
  7. Started working on the waterways for the forecastle another nice curved hook scarph
  8. Unfortunately no work in the Sirius this weekend as had orders from above to make handles for the wife's sewing machine screwdriver and her unpicker thingymagig, First try at turning with the screwdriver and then went mad with some glued together strips for the unpicker, the small one in the middle is a piece of naturally two coloured ebony The machine is a 1932 Jones in beautiful condition so I thought I had better put some effort into the handles to match the workmanship on the machine, she chose three so that means I get to keep the bottom right for one of my xacto saws bargain!!
  9. Hi Alan I'm not sure the planks would be nibbled into the waterway as Mark suggested, this was a later arrangement with the advent of power saw mills etc, Druxey mentions this in his comet book If you have twenty planks amidships you would need to taper them to fit at stem and stern where they come down the side if their width would be less than half the plank they were scarfed into the next plank, hope that makes sense see below at the right of the windlass And here in the bow Hope that helps Regards Paul
  10. Skid beams being test fitted and a couple of holly planks being used to check the flatness of the forecastle deck
  11. The forecastle is completed apart from some lodging knees, I have also cut the skid beams ready for cambering, brodie stove finally hidden under the beams after all this time Foremast partner is in the process of being test fitted, I also added some chocks on either side of the fore bitts as seemed very weak area, the two iron knees can just be seen in the photos Regards Paul
  12. Thanks recording now
  13. Awesome work ed as usual, please keep adding the arrows on your pictures sometimes I can't work the lines out and it was a great help thankyou Regards Paul
  14. Looking good mick, Nice work Regards Paul
  15. Hi Johann Beautiful work as usual and great video Regards Paul
  16. First hanging knees attached, an iron curved knee will go around the gunport
  17. Windows 10 and edge, no problems at all
  18. Fantastic work as usual Ed, ,lovely to watch Regards Paul
  19. Thankyou Albert and every one for all the likes, not quite on a par with your naiad but I'm getting there Regards Paul
  20. So back to the Sirius as promised, very productive day in the shipyard, forecastle and quarterdeck beams cut, cambered and foremast partner beams started The red light is a laser level that I'm using to make sure everything is centred properly
