Everything posted by JeffT
Your Wasa looks great. I'm curious about the bolted on piece at the bow though. Whats that?
Wipe-on Poly
JeffT replied to Stuntflyer's topic in Painting, finishing and weathering products and techniques
I haven't used primer over the poly. I just paint over the poly. Usually two coats is enough with badger paint. -
Wipe-on Poly
Yes, paint colors. Once the wood is prepped I apply the poly and paint after. It makes a nice smooth finish. I don't think its possible to stain after applying poly as it would prevent the wood from absorbing the stain. -
They look expensive
Wipe-on Poly
Wipe-on poly is a protective finish that would be applied after staining. On the other hand, its nice to paint over so I apply it to unfinished wood and then paint. -
My fingers have been the clamp. The blocks are so small that clamping them is difficult. However, I might be able to find a way. Maybe clamping them in the end of a hemostat might work. The blocks get ruined because I end up chewing up the end of the block trying to drill them. Maybe I'll post a topic and see how others have approached this little task.
Its a little detail really. I'm in the process of rigging the guns and I chose to drill holes in the ends of the 3/32" blocks to install the hook. After destroying a dozen blocks and successfully completing only one, I gave up for now...I'm building up the courage to try again. If there is a easy way to drill that hole, I would like to know what it is.
This is the best picture I have of the area. You can see how the wooden deck fits around the structures. I can't remember which wooden deck it was. I want to say Pontos but I'm not 100%% sure. It was self-adhesive and also sprayed it with a white glue water mixture an it worked great. No peeling at all to date.
I built this model last year and used a wooden deck. I didn't have a gap like that so you might need to do a little trimming.
Interesting build. I look forward to seeing it.
- 187 replies
- new jersey
- trumpeter
I've never seen a resin ship kit. Interesting.
- 382 replies
- stadacona
- sylvan scale models
Thanks Jerry. That answers my question. It looks like you might need two sets of hands to attach one of those patterns.
- 900 replies
- victory
- caldercraft
Hey Jerry, you're Vic looks great. I'm curious about the long gun port patterns used on the model. Did you have to glue those down a couple of bulkheads at a time to keep the glue from drying before the whole thing was secure?
- 900 replies
- victory
- caldercraft
Where Do You Keep Your Working Plans
JeffT replied to BubbleHead's topic in Modeling tools and Workshop Equipment
Good idea TJ. I have lots of wall space so I just hang them with office clips and Command wall hangers. -
I have the kit but haven't built it yet. Its a nice little kit with decent instructions and good materials. Its a nice kit to start out with.
