dgbot
Gone, but not forgotten
Everything posted by dgbot
  1. Interesting, a solid hull to start with. How about other parts? David B
  2. Well done bravo on a great looking model. David B
  3. Beautiful work. But I would have gone pin happy long before this. You patience and dedication still astounds me. David B
  4. Years ago a friend of mine owned a model shop that specialized in ship models may he R.I.P The swift was the kit that he would sell to a beginner. It makes into a real beauty and the wood can be easily replaced. Even though not fancy, I have seen several of them in many different places. David B
  5. Several members of my clubs have been doing the Longboat and have had the same problems. It was discovered that if you only use white glue you can redo a frame or part. One member had to redo most of his frames. By saturating the part in iso alcohol and wrapping it the glue dissolved after a couple of hours. In your case it might no take as long. Do one frame at a time. David B
  6. I prefer using white glue. As for CA you can use a debonder or acetone. David B
  7. Popeye, I just finished going through your build log and I found your build very enlightening. I have always had a fondness for working vessels. The way you are building your Syborn has taught me many new things. David B
  8. You have a ton of patience. This latest do over is a test in getting things right. My hat is off to you. Spyglass, spot gluing is usually a small drop to have a temporary bond that is used for placement or alignment. When you need to remove the part that little drop is easier to remove. David B
  9. Try isopropyl alcohol regular strength. If you can get 99% that would be better. Just keep the joint wet or wrap it in plastic wrap. After a while the glue will disolve. David B
  10. Take good care of her. Good job on your ponce wheel. David B
  11. I also have a fee of them, From Hobby Lobby. David B
  12. One of the things I have learned using acrylics. I have a Badger 360 a real nice one with no complaints. I have found that no matter what acrylic paint you use it will dry out. There for I keep a bottle of cleaner by my side. When using the gravity feed which is most of the time I would fill it with cleaner and rinse it out. This might seem silly. But several artist I know recommend doing this. It helps keep the your airbrush clean. When an internal mix gets clogged it can be a nightmare. I normally use Badgers Modelflex paint because it is already for airbrushing no thinning. For brush work it use to be Floquil. Now Tamya or Model Master Acrylic. David B
  13. After looking everything over I followed the same as before and assmbled the hull starting out with the backbone and then and then after assembling the turret I installed the gun deck.
  14. Your capstain looks good. How far off are you? David B
  15. You are doing fine work Dan. As for the color on th waincoting go with what you think best. David B
  16. It helps to break up the molecules making it easier for them to move around. David B
  17. You are making me jealous. Calm down oh green monster!. Great looking rails. David B
  18. A nice way to keep track of your test samples. David B
  19. We have people from all over drop by for the sheer fun of shooting and trading ideas and having fun. I missed it this year because my illness but I know that a fun guy from NJ showed up with a large model of the Bismark. David B
