Everything posted by dgbot
3D Printing - Not Just Yet!
dgbot replied to dvm27's topic in CAD and 3D Modelling/Drafting Plans with Software
Interesting, a solid hull to start with. How about other parts? David B -
Beautiful work. But I would have gone pin happy long before this. You patience and dedication still astounds me. David B
- 3,618 replies
- young america
- clipper
You have better eye than I do David B
- 803 replies
- colonial cutter
- modellers shipyard
Years ago a friend of mine owned a model shop that specialized in ship models may he R.I.P The swift was the kit that he would sell to a beginner. It makes into a real beauty and the wood can be easily replaced. Even though not fancy, I have seen several of them in many different places. David B
Several members of my clubs have been doing the Longboat and have had the same problems. It was discovered that if you only use white glue you can redo a frame or part. One member had to redo most of his frames. By saturating the part in iso alcohol and wrapping it the glue dissolved after a couple of hours. In your case it might no take as long. Do one frame at a time. David B
Popeye, I just finished going through your build log and I found your build very enlightening. I have always had a fondness for working vessels. The way you are building your Syborn has taught me many new things. David B
You have a ton of patience. This latest do over is a test in getting things right. My hat is off to you. Spyglass, spot gluing is usually a small drop to have a temporary bond that is used for placement or alignment. When you need to remove the part that little drop is easier to remove. David B
Take good care of her. Good job on your ponce wheel. David B
- 4,152 replies
- cutty sark
- tehnodidakta
I also have a fee of them, From Hobby Lobby. David B
May you find treasure and have a good time. David B
- 1,756 replies
- constitution
- constructo
One of the things I have learned using acrylics. I have a Badger 360 a real nice one with no complaints. I have found that no matter what acrylic paint you use it will dry out. There for I keep a bottle of cleaner by my side. When using the gravity feed which is most of the time I would fill it with cleaner and rinse it out. This might seem silly. But several artist I know recommend doing this. It helps keep the your airbrush clean. When an internal mix gets clogged it can be a nightmare. I normally use Badgers Modelflex paint because it is already for airbrushing no thinning. For brush work it use to be Floquil. Now Tamya or Model Master Acrylic. David B
After looking everything over I followed the same as before and assmbled the hull starting out with the backbone and then and then after assembling the turret I installed the gun deck.
- 39 replies
- lehigh
- papercraft square
(and 3 more)
You are making good progress. The end result should prove interesting. David B
- 150 replies
- TRAJTA
- fishing and cargo boat
Harriet McGregor by Boccherini
dgbot replied to Boccherini's topic in - Build logs for subjects built 1851 - 1900
Your capstain looks good. How far off are you? David B -
You are doing fine work Dan. As for the color on th waincoting go with what you think best. David B
- 241 replies
- queen annes revenge
- pirate
A nice way to keep track of your test samples. David B
- 4,152 replies
- cutty sark
- tehnodidakta
HMS Druid by Krug - FINISHED - 1:48 - Hahn
dgbot replied to kruginmi's topic in - Build logs for subjects built 1751 - 1800
We have people from all over drop by for the sheer fun of shooting and trading ideas and having fun. I missed it this year because my illness but I know that a fun guy from NJ showed up with a large model of the Bismark. David B
