AntonyUK
Everything posted by AntonyUK
  1. Hello Lee. Just Wonderful workmanship. I take my hat off to you. I could not work to the detail that you are putting into this model. Outstanding. Regards Antony.
  2. Hi Juergen. It would be interesting if possible to share it here, as it has sent me on a quest to get the answer to this question. Regards Antony.
  3. Hello Christian. Sorry I have no idea. I have looked through all the books and drawings I have. Nothing Very impressed with your frames drawing. Very nice curves. Regards Antony.
  4. Hello Lee. Exelent joinery with the keel components Please keep these wonderful pictures coming. Top notch. Regards Antony.
  5. Hi Greg. Nice to see your still building her. Nothing gets wasted is a good tip to tell your flat mate. EVERYTHING is wanted. NOTHING is scrap. Regards Antony.
  6. Hi Gaetan. WOW. This is one amazing build with joinery that just is just amazing. With the scale you are showing perfect details. Outstanding . Regards Antony.
  7. Hi. Just for interest. Not sutable for modeling parts. A local food Shoping store here in the UK has a 3D scanning service. They print in colour as well. http://your.asda.com/news-and-blogs/new-3d-printing-service Regards Antony.
  8. Hi. Welcome to MSW. Nice to have you aboard. The alert is quite a nice ship to model. Not a lot on the alert on the forum at the moment. But I'me sure you have already looked. More information on your build please. I.E. timbers you are planning to use. Fulley framed. Planking Curvel or Clinker. Looking forward to your build. Regards Antony.
  9. Hi I think I have got this right.. 4 is the thickness of your rudder. 15 is the length over all .pivot to end of strap 2.5 is the height of the brass. I.E. This is made from a strip of brass 2.5 mm Please correct me if I am wrong. Regards Antony.
  10. Hi. This is why I like this forum soooo much. Little details get questioned and then debated with outcomes that even the designer would be proud of It just goes to show the extent of knowledge that modellers have. Regards Antony.
  11. Hi. Having read through this topic.. 3D printing in my humble opinion will not replace wooden modeling. There is nothing able to duplicate timber/wood. The smell,the dust, the feel and the cleaning up. On the same subject.. Haw many model ship builders are willing to spend the many many hours studying a CAD program and then producing the image to use in the 3D printer. I had a go with Solidworks. To deep for me at my age. A service that could have cannon's and various fitting that can be scaled to a custamer size would be very helpfull. Or files that could be used to produce fittings. That's enough of my ranting.. For today. Regards Antony.
  12. Hi Cornwall model boats have a set for the Victory. http://www.cornwallmodelboats.co.uk/acatalog/admiralty_paint_sets.html http://www.cornwallmodelboats.co.uk/acatalog/admiralty_paints_water.html This is also the compleat list. Regards Antony.
  13. Hi Christian. Would not allow the DXF file. Yes Illustrator will allow me to save it Attached 1 PDF file. Deck and Side.pdf Regards Antony.
  14. Hi Christian. There is nothing wrong in going slow. Wait till you my age.. You have no choice I have done some drawings of the Alert using the anatomy in Illustrater format that can be exported to PDF .. Did you want me to post them here. Might be of some use to you. Have done the Deck, side view and a few small details. Regards Antony.
  15. Hi Chuck. Making very good progress and the stern looks spot on. I have a few issues with the stern on my cutter. I vote for natural. Never liked paint on my models. Regards Antony.
  16. Hi Mark. It will be nice to have a Druid cross section on the forum. Will follow this with interest. So much detail can be added to a cross section that is not visible with full length builds. Regards Antony.
  17. Hi Udo. Any updates on this amazing build. I am getting withdrawal symptoms Regards Antony.
  18. Hi. They send my planks in 1 mtr lengths in a strong tube as Mike discribed. If you live in the UK it's always full length. If its a export they will cut it into half mtr lengths to cut postage costs ...Unless you pay the extra for large item shipping. That's the way I understand it. Regards Antony.
  19. Hi John. Just found this while browsing In AbeBooks.co.uk. http://www.abebooks.co.uk/?cm_sp=TopNav-_-Results-_-Logo Modelling Tudor Ships R K Battson Published by Model & Allied Publications, 1979 ISBN 10: 0852426925 / ISBN 13: 9780852426920 It might be of some use to you. I have no idea on the contents. Regards Antony.
  20. Hello Cristiano. I have just read your build log through start to finish. You have a big undertaking that requires a lot of different skills.. And you have them all Your approach is very through and precise. You give the name "Kitbashing" a whole new meaning Will follow the rest of the build with great interest. Regards Antony.
  21. Hi Richard. I would not recommend using the film on a curved hull. Very little stretch. You can spray on a film. Link below. http://www.ipmsstockholm.org/magazine/2002/11/stuff_eng_tech_sea_water.htm I have NOT tested this but it should be fine. Regards Antony.
  22. Hi Divarty. Thanks for your kind comments I must finish this soon as I now have two ships in dry dock. Just got to cast the rest of the cannons. And install all the bits onto the different decks. Make a stand and case and it's done.. Sounds easy in words doesn't it Starting after the half term break. Thanks for looking in. Antony.
  23. Hi Kevin. Have you closer to home ? Timbersource Ltd, Marston Park, Tytherington, Frome, Somerset BA11 5BS http://www.timbersource.co.uk/ Hint.. Go there and have a chat to them. They will cut timber down to size and there range is quite good. Regards Antony.
  24. Hi ChristIan Lookin very good. In your first post " . Next step was the keel. Goodwin shows for the pass between keel and lower apron a solution which I could not find on any original cutter drawings." This had me looking into why Goodwin drew it like this... A local shipwright informed me that it use is " a part of the bow/keel joint that was phrone to being damaged while in shallow waters. This area is easy replaced. Antony.
  25. Hi. Found this while looking at sanders. http://www.axminster.co.uk/axminster-large-drum-sanders?sel=500185 It's made by Jet tools. Should be available throughout the globe. Going to order one to look at the quality and uses. Regards Antony.
