Trussben
Everything posted by Trussben
  1. Moving along nicely Sjors, look forward to seeing much more of her. Ben
  2. Nice Maury, well executed and very clean. Ben
  3. Hi As Augie said, there's always plenty of other things to prepare for, ships boats if you intend to do them, making and rigging all the cannons would be a great one to get out of the way, just be sure to make a mockup and test on the model to make sure the heights are correct to your gunports before the production line starts cranking them out! Ben
  4. Sweet!!!!!!! How did you do the framing around the cutaway section, single fancy cut like I did or 3 planks like Chuck? Ben
  5. Sorry to hear about your decision but understand why you have come to it! I will watch v2.0 along with everyone else and greatly enjoy seeing what you come up with. Ben
  6. Work has started on the lower apron, this is one complicated piece to make, I started by cutting the pattern out on 18" stock and trying at the moment to refine its shape to fit the stem pieces. I actually cut two out and I will use one to practice cutting the steps for the cant frames. This could take a while! Ben
  7. Very nice start to the lower planking Augie, any chance of seeing shots of the stem and stern? Spiling jig in use yet? Ben
  8. A Small Update, Keel has been completed and false keel added, I like the contrast between the swiss pear and the boxwood, now I have started on the stem pieces. ben EDIT - Added missing picture back that was lost. 4-2-14
  9. Looks really good to me Rusty, scale looks correct and not too big. And modifying chucks 12 pounders is a nice touch. Ben
  10. Wow ED, that is some tricky work to cut those mortises like that - don't think I could even attempt that, well done! Ben
  11. Very nicely painted upper works Augie! But now the real test begins! Just remember to trim your prespiled planks to fit your hull, it won't be the same as chucks, you have to adjust every plank! Keep your garboard low at the last bulkhead before the stem or your planking will ride up. Ben
  12. Piece of advice when you start again Iran, make your own keel clamp that holds the ENTIRE keel, not a few points or half the keel, the entire keel! I used some scrap wood screwed to a 2x4 which worked great for me, and don't take it out of there for more than a few minutes. I look forward to seeing you start up again. Ben
  13. Hi Iran, sorry to hear the twist/warping has not abated, can you try and get a head on pic so we can see where and how bad it is if possible???? Is it down the long length of the hull or one bulkhead just twisted? If it's down the long length you may be able to correct it with some stragically placed fillers, but if ME will send you new parts then I would agree with Chuck to restart. Nothing more important than having that skeleton perfect, even if it takes a month to get it that way! Good luck man! Ben
  14. Well done on the repair Grant, these things do happen unfortunately, but nice recovery. Ben
  15. Great to see you off and running again Maurey! Ben
  16. Thanks Chuck. Albert - I got the plans from Admiraltymodels.com and the TFFM books from Seawatch books, the other plans were from the National Maritime Meusem in Grenwich. For some of the parts I have scanned in the plans to acad 2006 so I can manipulate and print out specific parts as I need to. Ben
  17. Really well executed mast partners Toni, very neat indeed. Ben
  18. Thank you all for the interest you have shown in my Pegasus build. I am currently pulling bamboo treenails though the Byrnes plate for the keel bolts, down to the smallest hole in the plate to match a #77 drill for a scale 7/8 bolt - tedious work but I don't need many at the moment. Ben
  19. Nice to hear it was just one bulkhead! You really don't want any twist anywhere on the hull because you WILL see it later on, just ask ChrisLBren. Photos would be nice of your progress. Ben
  20. And Druxey drops the challenge on Remco again, this should be great to watch!!
  21. Hi, I will be starting my second scratch build and I chose HMS Pegasus 1776, Swan Class sloop, using the plans from Admiralty models and all four volumes of the TFFM books by David & Greg. Also a full set of plans was bought from NMM and the wood package from Hobbymill in Swiss Pear wood with some highlighting in Boxwood. I intend to leave her mainly in frame with a small amount of external planking - maybe from wales up, and will be using fully chocked joints and correct framing using the Disposition of frames plan. Internally I'm thinking of only framing Upper Decks with some planking, possibly the lower deck but just framing. Depending on how I feel when I get to that point will be the decision on Rigging her. I include pictures of the main keel parts completed, halving joints were used and cut on the JimSaw, the forward keel piece with the boxing joint was cut from larger stock on the scrollsaw and the joint was chiseled out with care. This will be slow starting as I am in the middle of rebuilding my workshop and I am also going to be working on my Confederacy when I need a rest from Pegasus. Here begins another journey. ben
