Everything posted by Trussben
That's cool Gaetan, never seen that before! Normal pharmacy chain? Walgreens/rite aid type of place? Ben
- 728 replies
- le fleuron
- 64 gun
Back home for 2 weeks so progress on Pegasus will continue. Well the tricky bollard timbers have been completed and installed, making the notches for the bowsprit chock was fun, also the first cant frames have now been properly installed in preparation for the hawse timbers. And a small matter of the bowsprit chock! Ben
- 889 replies
Agree with all the others Toni, stunning as always. Ben
- 1,449 replies
The Foibles of POF building, nice recovery. ben
- 372 replies
Hi Alan, Looks like your having fun! 1. I normally use a #3 or #5 Ultra reverse blade cutting stock less that 9 scale inches thick depending on material and how tight the curves are. 2. Chocks are a lot of fun, just keep practicing and you will find a way that works for you. 3. Druxey recommends 1/64, I actually left them a little fuller at 1/32 to give myself a little insurance. 4. The more frames you make, the faster it will become. By the time you get to the last frame and have mastered your own technique you will be less than 1 hour!! Its a steep learning curve! 5. HAHA - yeh, its good to have a handhold while cutting and keeping the fingers away from the blade! Just keep on going Alan - its not a mountain your climbing but sometimes it will feel like it ben
Looking good Augie, The brick hearth is actually pretty easy to make, it's the painting of it to look realistic that's tricky but I'm sure you will do fine. I installed the cabin floor before the rest of the deck planking to ensure a good tight fit, the joint gets hidden under the aft most bulkhead if you do get some gaps, that is if your are going to do the chequed floor of course. Ben
- 2,191 replies
- confederacy
- Model Shipways
Moving along well there Michael, I can wait to get home after this trip and get some modeling time in. Did you soak the deck clamps before clamping in position? Did you get some spring back? You can always use some card to make a template of the curve you need, and then cut a scrap wooden block to match the template and use this to clamp your wood to to get the correct curve instead of on the model where it's a lot more difficult to get your clamps in a good position. Ben
- 372 replies
Hi Grant, I like the case, its exactly the same as I did with my ECHO, although yours is a hell of a lot bigger :P and more expensive :o , I liked the black base as well as a contrast against the boxwood. Not far to the finish line now! ben
Hi and thanks for all the likes I will be working up in PA for several days and then to Niagara NY before finally getting home on the 20th I hope. Mark - Im thinking about taking a few pieces with me, just not sure what yet, maybe a couple of cant frames to assemble but I would need to do it all with hand tools. Remco - I agree, the bowsprit chock looks like its going to be a lot of fun to make! and yes it is good to have a mentor to keep his eyes on what I'am doing. ben
- 889 replies
Thanks Druxey, the pins seemed like a good idea at the time instead of using tape to keep them in place. More work was done to the bollard timbers, the 3/4" air space was marked and the waste chiseled out and then refined with sanding sticks. Also the knightheads were carved in using a small chisel point exacto blade and some needle files. Next step will be to reattach them temporally to mark the bowsprit curves to be sanded into them and mark for and make the bowsprit chock. Going to be working away for pretty much 2 weeks so progress will come to a halt. Ben
- 889 replies
Hi Mark, Looks great and you are motoring along nicely, I'm stalled on the bollard/hawse timbers at the moment. Just a question but I notice in the pics that the frame heels are not all the way into their slots on the rising wood, is the keel there just for looks at the moment? No frames glued to anything yet? Ben
SWEET! Love Swiss pear!! You going to do all deck planking in it? That will look superb! So great cabin in pear/ebony or holly/ebony?? Watch out for the laser cut gratings if you are going to use them as my kit had 2 different thicknesses included, don't use the wrong ones!! Ben
- 2,191 replies
- confederacy
- Model Shipways
Hi Michael, That's the first time I seen a design with the keelson like that, interesting. Thanks for taking my comments the way they were intended. Nice work of the deck beams so far! Ben
- 372 replies
Sorry but after looking at that fame pic again it looks like all of your frame pairs are sat about 1/16" too high on the rising wood, above the rabbit by that much. That may also be causing the keelson to be further away from the top of the keel if you catch my drift. Ben
- 372 replies
