Everything posted by Trussben
A Small Update, Keel has been completed and false keel added, I like the contrast between the swiss pear and the boxwood, now I have started on the stem pieces. ben EDIT - Added missing picture back that was lost. 4-2-14
- 889 replies
Looks really good to me Rusty, scale looks correct and not too big. And modifying chucks 12 pounders is a nice touch. Ben
- 421 replies
- granado
- bomb ketch
Wow ED, that is some tricky work to cut those mortises like that - don't think I could even attempt that, well done! Ben
- 3,618 replies
- young america
- clipper
Very nicely painted upper works Augie! But now the real test begins! Just remember to trim your prespiled planks to fit your hull, it won't be the same as chucks, you have to adjust every plank! Keep your garboard low at the last bulkhead before the stem or your planking will ride up. Ben
- 2,191 replies
- confederacy
- Model Shipways
Piece of advice when you start again Iran, make your own keel clamp that holds the ENTIRE keel, not a few points or half the keel, the entire keel! I used some scrap wood screwed to a 2x4 which worked great for me, and don't take it out of there for more than a few minutes. I look forward to seeing you start up again. Ben
Hi Iran, sorry to hear the twist/warping has not abated, can you try and get a head on pic so we can see where and how bad it is if possible???? Is it down the long length of the hull or one bulkhead just twisted? If it's down the long length you may be able to correct it with some stragically placed fillers, but if ME will send you new parts then I would agree with Chuck to restart. Nothing more important than having that skeleton perfect, even if it takes a month to get it that way! Good luck man! Ben
Well done on the repair Grant, these things do happen unfortunately, but nice recovery. Ben
Echo by Maury S - FINISHED - Cross-Section
Trussben replied to Maury S's topic in - Build logs for subjects built 1751 - 1800
Great to see you off and running again Maurey! Ben- 324 replies
Thanks Chuck. Albert - I got the plans from Admiraltymodels.com and the TFFM books from Seawatch books, the other plans were from the National Maritime Meusem in Grenwich. For some of the parts I have scanned in the plans to acad 2006 so I can manipulate and print out specific parts as I need to. Ben
- 889 replies
Really well executed mast partners Toni, very neat indeed. Ben
- 1,449 replies
Thank you all for the interest you have shown in my Pegasus build. I am currently pulling bamboo treenails though the Byrnes plate for the keel bolts, down to the smallest hole in the plate to match a #77 drill for a scale 7/8 bolt - tedious work but I don't need many at the moment. Ben
- 889 replies
And Druxey drops the challenge on Remco again, this should be great to watch!!
- 1,215 replies
- sloop
- kingfisher
Hi, I will be starting my second scratch build and I chose HMS Pegasus 1776, Swan Class sloop, using the plans from Admiralty models and all four volumes of the TFFM books by David & Greg. Also a full set of plans was bought from NMM and the wood package from Hobbymill in Swiss Pear wood with some highlighting in Boxwood. I intend to leave her mainly in frame with a small amount of external planking - maybe from wales up, and will be using fully chocked joints and correct framing using the Disposition of frames plan. Internally I'm thinking of only framing Upper Decks with some planking, possibly the lower deck but just framing. Depending on how I feel when I get to that point will be the decision on Rigging her. I include pictures of the main keel parts completed, halving joints were used and cut on the JimSaw, the forward keel piece with the boxing joint was cut from larger stock on the scrollsaw and the joint was chiseled out with care. This will be slow starting as I am in the middle of rebuilding my workshop and I am also going to be working on my Confederacy when I need a rest from Pegasus. Here begins another journey. ben
- 889 replies
As always Gary, your work and attention to detail is great. I will remember the tip about the sensitive drill attachment. Ben
Ahhhh Rusty!!!! As sherline lathe is in my future at some point I will consider it a good omen that you will take the first plunge, I haven't used a metal lathe in 20 years but I have a lot of experience with my wood turning lathe and there are just some things, especially small items that are very difficult to do which is where the metal lathe come in. Don't forget a four jaw chuck if you plan on doing proper masts on it. Ben
- 421 replies
- granado
- bomb ketch
Will be watching you and this build Sjors, it's been brewing for a while and I'm sure you will do a great job. Ben
- 1,616 replies
- caldercraft
- agamemnon
Hi Ir3, Glad to see that you are using a longer keel clamp, the hull is so long on this kit that she is Very prone to warping, it's happened to a few people so be aware, every now and again take her out and check that your keel is perfectly strait, but whatever you do don't leave her out of the clamp for long until all the port sills/lintels and upper hull planking is complete, this way there is almost no chance of it warping. Ben
Looks perfect to me Augie, I can't see any sheen in the paintwork, did you try buffing the paintwork with a rag, that gave me a really flat effect when mine were a bit shiny. Happy new year, and yes, I will be picking back up with my build in a couple of weeks
- 2,191 replies
- confederacy
- Model Shipways
Hi ir3, If you are going to use boxwood you shouldn't have to stain it at all, I used boxwood for some parts and the color matched the stained 30/70 golden oak basswood very well, but do some testing before you commit it to your model. As for staining basswood you have to be very careful not to go too dark as it causes a blotchy effect, that's what I have found anyway and believe me I've done quite a few experiments with different stains, I even tried a ebony stain for the wales but it just didn't take it well and I ended up painting them. Please think of doing updates as you go, it's great for us people watching and will help somebody else doing the build in the future - I just love to see progress like that and how different people tackle the problems that arise. Ben
