Everything posted by Baker
Thanks GL Mostly the cannons on armed merchantman (and probably also on some warships) came from different sources. They used what was available. That is why most cannonbarrels below deck are different. And these 4 are certainly different. At the time, the barrels were forged one by one and then placed on large costum made heavy beams. Let us say that 3 pieces were already painted when they came on board. The 4th was not painted, and the budget was too low to buy extra paint Errors (not vissible on the picture) 2 Nails (bolts) come through the wood on the inside and it is now impossible to remove them.
- 756 replies
- galleon
- golden hind
The 4 cannons are ready. Together with a part of the necessary extra parts and tools. Make hooks. Drilling holes The installation of the parts has started.(the cannons are not yet glued to the deck) Here and there I made some errors on the inside of the hull, the intention is to hide these errors with various items. These cannons look really medieval and inappropriate on a ship from this time. But historically they are correct. One cannon is placed in the front castle. I still have two small cannons to make. Thanks for following.
- 756 replies
- galleon
- golden hind
Thanks Carl The sprues have been drilled approximately 3.5 mm deep. Caution is required during drilling. The bore is 3 mm and the outside diameter of the barrel is only 4 mm. I used 4 drills. 1 mm, 1.5 mm, 2 mm, and 3 mm. all drilled by hand. This is how I make plastic strips. A "photo cutter" is ideal for doing this. I have the desired thicknesses and widths always in stock this way. Bore unpainted Painted. Interior in matte black. The "top of the barrel" is then accented with pencil (also possible with matt silver)
- 756 replies
- galleon
- golden hind
A nice paint job and nice wheatering Congrats
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Thank you everyone for following and the nice comments. The construction of the guns continues slowly. I build each cannon as a separate model, something like my military model building on a 1/72 scale. progress of the cannons, and i made metal rings of different diameters. Top left in the photo are a few (low quality) purchased cannon barrels that I wanted to use first. to be continued.
- 756 replies
- galleon
- golden hind
It is always a pleasure to come and visit here. And enjoy your beautiful and realistic paintings. Great work!!
Thanks Lawrence, Started making 4 "wrouth iron" cannons. This type of cannon was still in use during this period. The base: 4 blocks of cherry wood. A hole is drilled and a piece is cut out. The block is cut to shape and sanded. The cannon barrel. the first piece is a test, Made from a piece of plastic sprue and various pieces of plastic strip. Bolts are made from stretched sprue. No stress Ready to paint. Painted and weathered and ready. 1 done 3 more to go. Thanks for following
- 756 replies
- galleon
- golden hind
Hello Michael, They do indeed seem quite thick. maybe make them a little narrower at the top. On the drawing it also looks as if the outside is bending inwards. This way you go from the "wide" bottom to a "narrower" top. Hopefully my "Google English" is clear
- 371 replies
I agree with Keith.
Battle tactics from the time of the galleons
La Toulonnaise 1823 by ward - FINISHED - 1/50
Baker replied to ward's topic in - Build logs for subjects built 1801 - 1850
Mooi gedaan. Nicely done.- 26 replies
- schooner
- la toulonnaise
Greetings, patrick
The wreck is said to have been well preserved. And is approximately 25 meters long and 7 meters wide Some pictures of the cargo. Text is in Dutch. https://www.rtvnoord.nl/nieuws/206844/Spectaculaire-ontdekking-bij-berging-containers-MSC-Zoe
Thanks Michael, The maps are really easy to do. 1 Download the images and save to a folder 2 Select what you want to print 3 Choose format 4 print I use the printer at work (don't tell my boss ) Go pro single frame ?? No no, a cheap Huawei smart phone
- 756 replies
- galleon
- golden hind
Hello, After the historical info about Verrebroek. And what can be found in "my backyard" when you start digging A small update about the model. Because the doors of the main cabin are open. Some furniture and other items must be provided. Drawing a small sketch in advance is always handy. A table and a few beds. Made from scrap wood and paper tissue. Suitcases of the people who are allowed to "live" and work in this cabin. And some old maps downloaded with google and printed. If the visibility in the cabin remains good with the ledlights , additional items will be provided. Thanks for following
- 756 replies
- galleon
- golden hind
Welcome to MSW, and I wish you a speedy recovery.
