Posts posted by RGL
I’m Going to use a lot of masking tape as it’s so bloody big!
I see what you mean but I won't bother as the camouflage on the starboard side will be a very dark blue over this section and not really noticeable. More importantly they completely left out the anchor on the bow (Which I only just noticed today). Simple fix to drill a hole though.
- Old Collingwood, Canute, hexnut and 8 others
11
- Canute, Beef Wellington, Tom E and 7 others
10
When the GZ was being built, they had to replace the bow as it was rubbish in rough weather and placed a large cap on top of the funnel as the smoke obscured the island. By adding the cap it became top heavy thus the bulges added on the hull for stability.
I have etched in the panels which are’nt too obvious on the existing photos, but I think after some time at sea it would beat it up a bit and oilcan it.
Next are the gantries that will have spotlights and guns. These will all need gusssets which are after after market.
It’s like Gaffa tape for modellers
I used Zap on my Endeavour for everything
- Old Collingwood, Piet, Canute and 3 others
6
I use Zap which has always been great, just the recent batches haven’t been very medium or thin.
- popeye the sailor, Canute, mtaylor and 3 others
6
I’m of the opinion sone bottles just go off. I just got a ‘new’ bottle of medium CA which is thicker than off cream. I think it has just sat around in the heat for too long so going to get some from a new source as the thin stuff I also bought is just as thick.
- Old Collingwood, lmagna, Canute and 2 others
5
So the panel lines are done. I can now etch in the vertical lines and try and understand the engineering as there are platform that run alongside the deck for guns and spotlights that will need a heap of gussets added. Once I’ve gotten my head around that I can give her another primer coat to cover up all the raw areas.
I’m going to do it a bit different this time as I want the hull plates to be a bit more defined. It will more or less just give me a guide when I airbrush and weather.
- mtaylor, Canute, Old Collingwood and 3 others
6
So that’s how @cog threw his back out then....
Then you throw your back out....
- mtaylor, popeye the sailor and Canute
3
Well you know what happens if you don’t eat....
- mtaylor, Old Collingwood, Canute and 1 other
4
The platforms on the sides need lots of triangular gussets to be added (which are not included) and I think I’ll have to add the deck first as it will never align properly unless I do it then BUT! The lattice support wort under the deck at the bow and stern will have to be pre painted and weathered. So many chickens and so many eggs.
- Canute, popeye the sailor, mtaylor and 1 other
4
I’m not sure yet, I need to consider scribing the plates in first.
- popeye the sailor, hexnut, BANYAN and 10 others
13
DKM Graf Zeppelin by RGL - FINISHED - Trumpeter - 1/350 - PLASTIC
Other side done. I need another coat of primer before I go any further
