svein erik
Posts posted by svein erik
Grait build, Its Soon for the mast and rigging 😲
take care!
Svein.erik
Thanks for the likes, keeps me going😊
So what did I do this time?
The dekk planks is now finished and I started to sand the dekk,
I also aply one cote of oil yust so I can see where I need to sand more
after this I have to make more copper plates 🙈
Svein.erik
I want to get everything you offer😆
its exelent kit with a master on board 😊
but I am still building the syren and I have to diside if am doing this prodjekt or the cheerful first?
Svein.erik
- thibaultron, Canute, EJ_L and 2 others
- 5
Thanks for the liks
I yust started making plates , 15 in one strip and I make 500 for the portside
and I got to say its inspitational to make this when it going so good😀
I think I used about 30 min to make ca 100 plates
I did also make a guillotine to cut the plates using a small hammer .
Svein.erik
I finaly got the stamp to work, a little rebuild did the work.
so I made some sample to try on a boxvood sheet
but it Seems to me that wen I take of the copper plates from the teip
it kind of roll inn, so wen I put it on you can see its not Strait on the sheet,
Maby this like this or it wil be better wen tones down?
Svein. Erik
- Peter Bloemendaal, JpR62, smarra and 2 others
- 5
Hi again and thanks for the likes 😊
I did start the dekk planks. But the nibbing I started after 3 plank (4)
in the practicum its starts after 5 plank (same same but different 🙊
I use boxvood and its hard to nibb this if the margin plank is glue to the ship,
So the margin plank on both side is loose so I can do this off ship.
And I try also the ropewalk, making rope for the first time
I havent nails it yet but its a good start 😊
Svein.erik
4 hours ago, Dziadeczek said:
Aren't you supposed to allow one end of yout ropewalk to slide on the table (perhaps weighted with a ballast?) to allow your rope to shrink somewhat?
Twisted rope is typically shorter than individual strands for about 25%.
Perhaps that's the reason you broke your first rope...
Yes, I did that, but went a little to far of the braking point ......
So I try again but not so far this time and it works. I do have to work on the skils her so the rope
Is more like a rope . I have some rope from chuck so I can look at and adjust mine as good I can get it, until am a master🙊haha ha, wl in time I hope my rope is exelent 😊
Svein.erik
- Canute, Azzoun, Ryland Craze and 2 others
- 5
- JeffT, ccoyle, Ryland Craze and 2 others
- 5
Hi, look at chuck 's syrenscompany (rope)
Its the best on the market (I do think so)
Svein.erik
- Chuck, Fernando E, mtaylor and 1 other
- 4
- Jim Rogers, Fernando E, smarra and 4 others
- 7
- J11, zappto, Peter Bloemendaal and 1 other
- 4
- Jim Rogers, jablackwell, egkb and 2 others
- 5
3 hours ago, Chuck said:
But what is the thickness? Not of the wales but even the general planking topsides. Every Hahn model I see seems so heavy and "thick". It makes the thickness of the bulwarks very wide with a huge cap rail that would probably end up being like two feet wide on the real ship. If I were building the halifax, I would probably use 3/64" thick planking and that would be sanded even thinner once in place. For the wales I would build it up in layers by adding another 3/64" strip on top of it and maybe a thinner one for the black strake. Once the model is done and if done neatly.....who would ever know. I realize that the real ships werent planked like this but its an odd thing to keep trying for "traditions" sake when maybe taking a different approach might be so much less painful and yield better results. If it doesnt effect the final appearance why not give that a try?
Chuck
So this meens that I need to use 3/64 general planking for the cheerful hull ?
Svein.erik
- mtaylor, Elijah, thibaultron and 2 others
- 5
If I cant do the task of plating the hull I May have to paint the hull 😨
Svein.erik
- Peter Bloemendaal, JpR62, Gahm and 2 others
- 5
- Gahm, egkb, Peter Bloemendaal and 1 other
- 4
The stern photo in not a good one or .......
I did se it wen the ship is turnd (not upside)
The plank where the ship name is going on has to be ripped of , New and thinner plank has to go in.
OMG😬 I diddent se it .........
Svein.erik
US Brig Syren by svein erik - Model Shipways - 1:64 - 18 gun brig
Thanks for the liks and comments
I yust finish the treenail on the dekk, I need some more later wen the hatches is in place
I used #77 drill bit for this and some wood filler (darker one) and I used 2 hull in one plank
Soon I starts on the copper plates 😶 yeee. ....
Svein.erik
