svein erik
Posts posted by svein erik
- Old Collingwood, Canute, mtaylor and 2 others
5
- mtaylor, Ryland Craze and MEDDO
3
yeeee.... well almost dunn (98%) som paint here and there, decals , some wheatering , fix the flag (no wind in here😉)
i used black rope from syren on the model.
and am waiting for the schnellboot crew , so i have some painting to do here also.
this is photo taking from the shop, when finish i wil take som nice photo with some background.
- lmagna, Old Collingwood, wemattson and 6 others
9
thanks for the likes and coments 😊
its almost finish , i got all the parts painted , so the nex thing to do is to glue them on etc
and i almost forgot... i did order the schnellboot crew and i have to make a displey case also..
it seems to me i do have alot to go ..LOL
new photos of some parts etc (not glued yet)
- lmagna, Old Collingwood, PeteB and 6 others
9
- G.L., coxswain, FriedClams and 4 others
7
- KeithAug, Mirabell61, G.L. and 3 others
6
- GrandpaPhil, KeithAug, Ryland Craze and 4 others
7
Am back...... wel i started on the huge build again
in most of the photo i have seen you cant see the dekk clear , i can see there is a wood dekking , but is this for the hole dekk or
some of it ? so i desided to yust plank the hole dekk an leave it with that.
am starting at the rear end , working my way to the bow .
the planks wil have a curve its going to be alot of edge bending here, i hope it wil work out in the end😊
- JohnB40, mtaylor, GrandpaPhil and 7 others
10
Hi, Thanks for the coments and likes, its slow going but am getting there.
i have paintet some new parts ... or likly many parts , some i dry fitt but most of them i have to glu,
so my next task is to finish the windows etc and glu all part so i can start the countdown twards finish line😊
and a photo of a side prodjekt😉
thanks for now and stay helty and safe.
svein.erik
- Egilman, Old Collingwood, Canute and 6 others
9
hi again..
some update on my schnellboot s.38 .... after i got my new aibrush i can move forward on this build ,
startad to paint all the parts and dry fitt then on the boat ,all the detail paint wil come after all is glued on .
am not happy with some of the paint fore the wood dekk , so this has to be re painted in the right wood paints .
i wil do some weathering also before i can say its finish😊.
svein erik
- Canute, lmagna, popeye the sailor and 7 others
10
- mtaylor, Ryland Craze, GrandpaPhil and 1 other
3
1
- reilly, Blue Ensign, archjofo and 6 others
9
21 hours ago, glbarlow said:
Aren't you using 3/16th for hull planking? My planking fan downloaded as part of the monograph only has a pre-defined line for 3/16th.
yes a do use 3/16 .... i yust some time ago take some messurment from this why.. i do not know..LOL,
in the future i need to check wat i have is correct.... but its to late now so i just has to go with wat i have.😊
Hi again, and tanks for the likes ...
i have just discover something on my plank sheet spreder,
the provided marker for 5/32 plank does not match the 5/32 sheet (ca 4mm wide) is more betwin 3/16 to 7/32 (5mm)
i think also this my had some impact om my planking since i have used this marker in the prosess ,
se the photo.
- GrandpaPhil, mtbediz and mtaylor
3
- glbarlow, mtaylor, GrandpaPhil and 2 others
5
some new photo , my eyes diddent want to see wats going on ..... so i have to lay out some tape strips to see the run for the plank
at the bow , i do have tick marks but it seem wrong , the tape helps me on that.
the are 10 planks to the keel inkl. the garboard plank, i can know see were it goes , and it seems i have to place it up wards in the bow to get it
right for my planks , i may have dunn something wrong with my other planks so i have this problem know...
in chucks photo the garboard plank sitts more aft then mine, maby it dosent matter at this point.....
in one of the photo i mark the garboad plank in red so you can see were it goes.
svein erik
11 minutes ago, Chuck said:
The curve is too severe on those planks already on the hull. They should be straighter at the bow....it should follow your lining off if that was correct.
Chuck
thats wat i was afraid of.... lol i need to ripp of te 2 plank and re do it so it flows strait and follows the marking i made..
- GrandpaPhil, mtaylor, mtbediz and 1 other
4
Schnellboot Type 38 by svein erik - FINISHED - Italeri - 1/35 - PLASTIC - German WW2 torpedo boat
some better photos
