aliluke
Everything posted by aliluke
  1. A very fine lantern there. As a diversion I'm going to have crack at my Syren Models lantern kit this week. We'll see how I go. I'll be very happy if it ends up as good as yours. Your whole model looks fantastic and getting these little parts right makes it sparkle. Cheers Alistair
  2. Well Bob looks like we finished our second layer at the exactly the same time. Like you I'm glad it is behind me. You have done a great job there - nice and tight (much tighter than my efforts). One issue I have had is a slight discolouration of the boxwood where the planks butt together. I'm guessing this is because the glue (I use CA) is soaking into the end grain of the plank. It is not too bad but will not sand out. You don't appear to have this problem. Any tricks there that you could share? I think next time I will lacquer the cut ends before gluing - do you do that? Cheers Alistair
  3. Hi Larry I agree get that garboard plank in now. I usually install that plank and several rows above it much earlier than you have. Perhaps also shorten it at the bow so that it is parallel to the keel and doesn't rise up the stem at all. That will increase the space for subsequent planks. Definitely you'll need stealers, maybe more than are shown on your plans, and if you make them and the adjoining planks full width the gap at the stern should close quite quickly. The only other choice - which is harder - is to take off a few rows of planks at the bow and taper them further back along the hull to increase the rise of the planks at the stem. From the photos it appears the lowest rows of your planks are parallel to the keel or even turning down slightly when they should still be rising. Although the above may not be heartening, I hope it helps. Cheers Alistair
  4. Good to see another AVS underway. It is a great kit and makes a very nice finished piece. I would recommend that you fair the bulkheads after you have fixed them to the false keel. I found with my AVS that I had to add material to some bulkheads rather than removing it and it is impossible to tell which requires what until they are all in place and you test the flow of the planking. That said your kit may be more accurate than mine was. I'll follow your log. Cheers Alistair
  5. As Capt. Haddock might say - "Great snakes" (Snake) that is really good work. You are on the finishing straight to a fantastic model. I'll be looking and learning here for my next rig. Hats off to you. Cheers Alistair
  6. I'm still following Glenn! Your work is great and I really liked your planking tutorial. Having nearly finished planking the Fly I can't imagine doing a hull this size - in fact I probably won't. Doesn't mean I'm going to stop following your progress though. Please keep posting. Small question - an opinion? - you paint the trucks on your cannons black. Many leave them natural. Is there a right way from a historical point of view? Cheers Alistair
  7. Hi Ron The lower deck looks good. I agree with Steve - ignore the bulkheads when nailing. May I also suggest a lighter touch with the caulking and treenails on the upper deck? At the scale you working caulking and nails would be very faint. I use wood paste for the nails and a pencil for the caulking. It is all personal preference of course... Cheers Alistair
  8. Hi Ken Don't look for Uhu, just look for a universal glue. Uhu is the brand we can get here but I'm sure there are much better brands where you are. The trick is to find a glue that sticks to non-absorbent surfaces, cleans up easily and doesn't fog acetate. Maybe some one else here knows the right stuff in the USA???? Cheers Alistair
  9. Jason - I reckon you are well on your way to exceeding my first go at rigging ten times. Your work looks great - perfect in fact. I don't know about Hypo glue but suggest a toothpick is the gentlest way to remove any excess glue. The toothpick doesn't sand or gouge but can remove stuff you don't want . I've found that little tidy ups are a constant and a constant battle. The further you get on in the build the more gentle you need to be with the fix. That said - you are making a model that I'd aspire to. Brilliant work! Cheers Alistair
  10. Ken You should be able to get a clear, thin acetate sheet from an art supply shop. It is quite rigid even when very thin. Also very easy to cut. The next trick is to find a glue to fix it in place as CA glue will make it go foggy (in fact even using CA close to it can make it fog so it pays to mask off the windows after glazing if you are using CA nearby for other pieces). I use a universal glue called Uhu Glue in NZ. It sticks quite well and is easy to get any excess off with a toothpick. No idea what name it will have in the USA... The other choice is a liquid glaze like Microglaze. Comes out of the tube like a white glue but dries completely clear. Difficult to apply evenly though and sits between the window frames rather than behind them. Them's my thoughts. Cheers Alistair
  11. Hi Ron I think 65mm is much too short. The AOTS for Endeavour at 1/96 has them at about 88mm which translates to 150mm, more or less, at 1:54. The rule of thumb is about 26 feet which equals about 145mm at 1:54. Somewhere in that region - 140mm to 150mm is right for your scale. I also reckon a 3 butt shift is better than a 4. The deck layout is actually really complex so given that the deck is a simulation a more intense shift suits better in my opinion. However the short plank lengths are much too intense. Just my thoughts - looks good and I'll keep up with your build. Cheers Alistair
  12. I just had a look at my AVS Jason. As the lashing is on the underside of the bowsprit it is impossible to see it without a dental mirror. You'd also need a magnifying glass and that is at 1:48 scale. Not that I didn't try to get it right but I wouldn't die in a ditch over it. Another little tip from that model - I found that using the Amati keel clamp (if you have one) to lock the masts and spars while working on them was a brilliant tool. I think there is a picture of that on my AVS log. Good luck and I look forward to your results. Cheers Alistair P.S. Yes the Amati keel clamp for working masts + bowsprit + the same type of lashing as you are doing is on my AVS log.
  13. I'd vote for A as well - more by intuition than knowledge. I would have thought the lashing would only go between the eyes and not over the bowsprit (I can't even figure how that would work). Intuition again though but that is how I did it on my AVS. Cheers Alistair
  14. Look forward to this Ron. It is great ship but a challenge to plank from what I've seen here. From your work to date I'm sure that won't be a problem for you though. I see from the box the scale is 1:54 - that seems an unusual scale. Do you have the AOTS book for Endeavour? Well worth it I'd suggest and easy to get. Cheers Alistair
  15. Your progress is great Dave and the base board jig is a very cool. For the mounting pedestals there is a simpler way... - Recess the raised base of the pedestal into the mounting board and epoxy glue it in there. I got a wood joiner to do the recess in the base for me. The flare at the base of the pedestal ends up flush with the base board but you could set it higher. - The recessed pedestal when epoxy glued in place on the base is very rigid - immovable. - Epoxy glue the keel into the pedestal and then, when it is dry, reinforce the connection with a wood screw or just a nail (I used a nail with some more epoxy for luck). Your ship can never, ever be removed from the base after this but it saves a whole lot of fussing around early on and it is extremely rigid. It also means you don't have to predict mounting positions. Plus I think the recessed pedestal is more elegant than a placed pedestal. I lost all of my pictures of this method but here is one from my AVS log. You can see that the pedestal is recessed into the base board. I'm looking forward to your future work on Granado - I'm tossing up whether this will be my next ship model but that is years away! Cheers Alistair
  16. Looks really good Ken. A trick for aligning the nails is to lay masking tape across the deck (port/starboard)along the beam lines/nailing lines and use an awl or pin to make a pilot hole before drilling. Dirk showed this to me at about the same time that I figured it out for myself - see my Fly log. Once you get going with the method and trust it, it is very quick. I keep my treenail drill bit in a special place, stuck to the wall with masking tape, so that I always get the same size hole. I look forward to seeing the results when it is all drilled, filled and cleaned up. Cheers Alistair
  17. Hi You have obviously had some struggles with the hull but your deck work and fittings look good. If I was you I'd look to paint the hull between the waterline and the wale, there are plenty of examples here of that. I'd also re-fill and re-paint the hull below the waterline. I'd focus all my attention on getting those two bits right and the let the rest be as easy as it can be. To me the lower hull is letting the model down and it is very fixable. Everything above the wale looks great. Hope that doesn't sound too harsh, it is just an opinion and with so much more work to go, a hull you feel bad about at the finish will irritate you. I'm not sure how you are gluing your planks. I use CA for the second planking but apply it in small increments. I glue down each plank at its most stressed points - bow/stern - in very small measures - maybe 5 to 10mm glued length. Then I work away from the stressed points in longer glued lengths but always in increments. There is no way to work a plank with CA along its full length by a continuous strip of glue. It also useful to bevel the plank to the one above or below it. This makes for a tighter joint. Another method is to cut the planks into shorter lengths and butt those together - I'm just learning this. Anyway these are thoughts for your next model. In planking techniques Greg has recently posted a good guide on his Vanguard - worth reading. Your Granado looks good and I look forward to your progress - your upper works look great and I think your model will pan out well when all the other detail is added. Cheers Alistair
  18. Hi Bob Even with the qualities of boxwood the accuracy of your planking is amazing. I'd like to sit alongside you and see how you do that so neatly. Great work, masterful. Cheers Alistair
  19. Hi Jason Beautiful work - very crisp, clean and precise. Nice to see hand tools can do this - inspires me to keep my credit card away from milling machines and the like. Base of mast - round in my opinion. Have had a look at some of the great models and all are round (this includes the models in the FFM series which are hard to dispute). The mast was chocked, as you say, and then clad in leather? or tarred canvas?. The number of chocks would tend towards round at scale where an octagon would be too few chocks to do the job. I also wrapped the mast to base junction with thin rope on my AVS to hide some gaps but that look is consistent with a tied wrapping to the chocks. I'm no expert though! Cheers Alistair
  20. Holly is great for a deck and boxwood for a hull. I'm using both on Fly and can testify for their qualities. Rafine's stunning builds here also use that combo - have a look at his Fair American and, more recently, his Essex. I have also heard that ebony is very difficult to use and has very nasty dust. Cheers Alistair
  21. Congratulations Ron!!! A great model - the patina of being already aged really sets it off. Your furled sails are a great addition. Brilliant work and hats off to you! Interested too, to hear what's next? Seems to me you are up for anything! Great stuff! Cheers Alistair
  22. Best wishes Andy, I'm blessed with a family who have not yet had such a difficult surprise. My condolences. Take care and get home safely. Alistair
  23. Thanks Gerty, Rowan has dragged my log back from the sludge of former things. I must say your Willie L. Bennett looks very fine, so a good link arises from Rowan's dredging! Cheers Alistair
  24. $80!!!! That is incredibly cheap. The MS paints might not be so good...I used Admiralty Paints, Floquil and Testors. $80!!! I'm spitting. Good deal Rowan - I just might make another AVS! Even if the paint is dodgy that is still an amazing bargain. Look forward to your log and there are plenty of AVS veterans here to help - me included. Cheers Alistair
  25. I'm not worried that my Fly may be a Pegasus/Fly hybrid with respect to the quarter badge but absolute historical accuracy is not my thing. If you look at the TFFM volumes you will see many variations from the kit, some I'll adopt, some I'll ignore. Andy is correct, one central opening only and the TFFM indicates it was rectangular without an arch at the head. I've arched my opening as it feels better to me. Your carving so far looks great and I'm sure you are up to detailing it further. Cheers Alistair
