Timmo
Everything posted by Timmo
  1. No response to email orders and phone calls to westbourne and after some online research there's a disturbing number in the same boat. Can't even get hold of them to confirm the presumably undispatched order is cancelled.
  2. Nice work. Great start to a mouth-watering kit.
  3. Glad you got that brass sorted Julian. Those sheer rails are looking good. Nice work with the Lego for the ladder jig. I'll have to steal that idea.
  4. That would be a salute to the modeller from the gun crew, Doris.
  5. Thanks Jack, Dominic, there were a couple of victory/amiti Granadoes on the old MSW and I'm sure many would be interested to see the differences. How about a build log?
  6. Top work Ray. I think I'll be making some similar blocks with hooks now.
  7. Brilliant work as ever Doris. The flags are spectacular while your skill with sculpting and construction is unbelievable.
  8. I'd laminated some profiled strip to the front face of the cheeks below the head rails in a burst of activity a few months back. The lamination lines were still visible and not that flash so some new upper and lower cheeks were knocked up from offcuts of the kit walnut cut and shaped to fit. The upper cheeks were made in two pieces with the join on one side. The profile was made with a file as per the others on a ship. The timber was varnished and the blue painted in and tidied up with a blade. The join between the upper cheeks and the head rail will be hidden by the gammoning holding the bowsprit down.
  9. Start and end points marked with dividers and drilled and the rest filled in, or cut out in this case, by eye. It's a short distance so you can get away with it,
  10. Thanks John. The Granado is a nice kit and a good second build. Be sure to post a build log of your first kit. Plenty of encouragement and advice from the fine people on this site.
  11. Yep, reasons why I went with timber were half aesthetics and half because I didn't like the thought of fitting that heavy brass to the right curve and then relying on ithe bond holding it to the timber. But many others have made it work
  12. The head rails depend on the cathead for positioning so they have to be knocked out and fitted first. The slots were cut with a jewellers saw. Sheaves were cut from styrene tube and an axle from brass rod. Painting, fitting and the cathead cleat next up.
  13. Wow slog, I haven't seen so much photo etch since my plastic modelling days nicely done.
  14. To make a pattern for the knees and head rails a rubbing of the chase port and sheer rail etc was made with a pencil. This was then used to draw in the correct shape for the knee and beginning of the upper head rail. The resulting shape was traced and cut to check it works for the other side. I've laminated some leftover 4mm kit walnut to make some pieces large enough to hopefully cut the knee and entire head rail in one piece, that's it for today. For our northern hemisphere friends it's too hot working in my garage even with a fan on and a refreshing beer close to hand, especially after a morning watching my daughters compete in a triathlon. Great stuff.
  15. Thanks for the suggestions Kester. I was fairly set on just moving the timber head but I can see now shaping the cathead knee and head rail properly will overcome the problem. I made some mock ups of the kit supplied cathead and head rails to get some idea of how it all should look. As can be seen there's no natural curve to them. It's pretty square.
  16. I'd be interested too Mick. The more people contributing the more opportunities to solve issues like this and help each other out.
  17. Top work Dan. Hard to believe it's the same ship. You're a man of your word sticking with this project.
  18. Always room for more sanding. Did you fit the foaming with the chimney in place? It'll help get a nice fit.
  19. Nice smooth first planking you've got there Eamonn. A great base for the next step. Keep it up.
  20. The head rails really take their starting point from the cat heads. Their positioning determines where the cathead knees run down vertically to the top head rail which runs out to the bow. Hence here's an issue which I spotted prior to packing Granado away a few months back - I chose to wilfully ignore it and hope it would sort itself out in the meantime. Unsurprisingly it's been waiting for me ever since. The chase port needs to be positioned far enough back to allow the cathead knee and head rail extension under it to run down from the cathead and clear the chase port like so on the instructions. On my Granado the chase port is too far forward by about 3-4mm it means the timber forming the knee and start of the head rail fouls the port. The port is yet to receive a door which means we need even more room. Here's what it would look like with the stock kit pieces. Clearly not enough room there. Craig and other builders beware and check those ports and shuffle the top rail with their timber head positions if needed. The port side has a little more room but options are: moving chase port ( all but impossible) Shaping cathead knees and head rails for each side so that they follow a natural line away from the port. (Possible but would not do well with symmetry when the hull and head rails are viewed from front. Remove one timber head from the top rail on each side to allow the cathead to move forward to clear the port. (looking the best option so far as there is nothing belayed to the timberhead which would go and few would notice, I'm for the simplest and best looking fix here as this kit was never going to be 100% accurate given my lack of info and skills for many bits.
  21. It's very good and highly recommended. The Granado is a fine model out of the box but I'm lucky enough that my local public library has a copy of AOTS so it's worth adding a few additions.
  22. Hi Bob, Just found your build. Great work you've done on a fine looking vessel. Keep it up.
  23. Thanks for the comments Kester. I like your Sherbourne, especially the gaff sail. I battled a long while with sails for mine before giving up as i could never get them o look right for the scale. with the head rails, those are next up once i get back into building. here's what the kit suggests: and here's what the anatomy of the ship has: the kit parts are from walnut ply and might take a bit of bending and shaping to ease a third dimension bend into them but i suspect remaking them will be the best option as i also want the profiled groove running through the centre of the rails as per AOTS and the previous rails I've done on Granado. As for the colour, yes the kit suggests blue but I'll keep it consistant with what i've done so far with a blue strip on the varnished timber. less is more.
