GrandpaPhil
Everything posted by GrandpaPhil
  1. I like to use the clear plastic off store boxes to make windows. Anytime anyone in the family buys something that comes in a box with a clear plastic front, I always scavenge the plastic for model building.
  2. Welcome!
  3. Thank you very much for the vote of confidence. Well done on the carronade. I like the modifications and the added detail. It looks good.
  4. I coppered both my Victory and Prince de Neufchatel with copper tape. The only thing that I wish I had done different with the Victory is that I should have bought new tape and not secondhand tape. It didn’t stick particularly well. It was much easier to copper the Prince de Neufchatel.
  5. I did not use the figurehead out of the kit. I made my own out of basswood and card. I cut off the bow section and traced the one out of the AOTS which is why mine has a notch. I ended up filling it in with a filler block after I made the figurehead. It looks like you wouldn’t need to notch the beakhead if you use the figurehead out of the kit.
  6. Welcome!
  7. Thanks, OC! The detailing and the rigging are my favorite parts of ship modeling.
  8. Nicely done! The notch is to mount the figurehead.
  9. Thank you both for the comments! Thank you everyone for all the likes! All guns now have eyebolts, complete with double blocks. They are complete. It is now time to resume work on the ship herself. I drilled all holes for the eyebolts yesterday. I am doing the same thing by preattaching blocks to eyebolts prior to installation. The eyebolts for the breech ropes will be made from that annealed wire. The eyebolts located beneath the quarterdeck and spar deck will have their breech ropes pre-tied to them.
  10. Yes, white. I used a faux metallic technique with two shades of gray and finished by highlighting with white.
  11. Thank you very much! The first set of eyebolts with double blocks are on! The long 12’s are done!
  12. John McKay’s The 100 Gun Ship Victory (The Anatomy of the Ship series) is an excellent resource for building the Victory.
  13. Welcome! Schooners make great first scratch builds. Mine was the Prince de Neufchatel (Baltimore Clipper) made from Chapelle plans. Model Shipways sells their plan sets reasonably, too.
  14. Correction, I forgot about the carronades. Make that 88 double blocks tied to eyebolts.
  15. I’m pre-tying rigging blocks to eyebolts to make installing easier. I need to make 72 of them. These are Tichy HO scale eyebolts with 3mm double blocks from Model Shipways. For those having difficulty with rigging thread fuzzing out, I use a block of beeswax to prevent this.
  16. I’m glad that you liked the cannons! Thank you very much. Daliab, you will most likely see a very close twin of the keel clamp when I build my next ship. Thank you very much. I am making eyebolts and putting them on the breech of Victory’s guns. My method for making them is simple because of where they are going. I just make a curly Q and cut then off. For an eyebolt anywhere else, I do the same and bend the loop back to make the traditional eyebolt shape. They are a bit large for the scale, but that cannot be helped due to the wire I have and the scale to of the model.
  17. Welcome!
