GrandpaPhil
Posts posted by GrandpaPhil
I photocopied the plan sheet for the brass photo etched sheets onto thin cardstock.
I sealed both sides of the cardstock sheets at the parts I am going to use.
The pieces that would have been thin brass, I will most likely just cut out and adjust as needed, like the lanterns above.
The pieces that go to door frame mouldings, the quarter badges and other trim pieces, will be fully glued to wood and be carved as appropriate.
The cardstock should reinforce the wood pieces so they don’t split out as they are being carved.
Check out Grainger. They have good stuff and their prices are usually decent.
- Peanut6 and Knocklouder
- 2
The lower part of the hull is mostly complete now:
The pintles and gudgeons on the rudder needs some minor paintwork:
I need to paint the ones below the waterline that dingy white.
There are a couple places that need touched up in the same fashion, from where the green on the base came in contact with places it should not have, while the paint was still wet.
Then it will be time to complete the gundeck.- Baker, davyboy, Glen McGuire and 1 other
- 4
Thank you, Allan.
That’s what I figured.
I made the pintles and gudgeons from card and the pins from pieces of toothpicks.
I embossed the bolt heads with my pounce wheel.
I’ll repaint those pintles and gudgeons below the waterline with the dingy white after this round of gluing dries.
- mtaylor, Thukydides, Glen McGuire and 2 others
- 5
- John Fox III, mtaylor, Thukydides and 2 others
- 5
Very good idea!
That looks amazing!
I will have to pick up a roll of that foil tape the next time I go to the hardware store!
I have several armored warships coming up.
Thank you very much!
The painting progresses:
And I’ve been working on the rudder:
Now I just need to decide if all the banding is being painted black or the parts below the waterline will be painted white:
And because I do not like moving parts on a model, I glued the whipstaff in place:
Also, edge sealing when masking off for painting works really well for preventing bleed through.And I discovered that most of my pieces are under thickness with my new calipers.
But, since this has been the same throughout the build, I am not worried about it.
- Baker, John Fox III, catopower and 4 others
- 7
Grumman F4F-4 Wildcat by ccoyle - FINISHED - WAK - 1/33 - CARD
in Non-ship/categorised builds
Looking good!
