Everything posted by cog
You like living on the edge ... So what happens after you've depleted your sick hours? It's an unknown system to us. We have no limitation on sickness, we get checked and a physician decides whether you get back to work or if the sickness period gets extended, and for what period, before you need to get back at the doc's office.
I wonder why ... I would expect the bands with such a big yacht ... maybe those have been left off after an overhaul ...
The only thing you need to take into account is that the handle can't be fixed on a round shaft, but at the scale you are working and the fact it won't be used, that doesn't matter. You have the side ways pivotting motion of steering, and the up and downwards motion to keep the scate flat on the ice, Pass a brass tube through the wood, trhough which you can pass a solid brass rod on which you solder the "claw" which holds the skate. You can make the bulbous shape either by adding solder, or by using multiple tubes one over the the other, soldering them together and file them into shape ... The brass bands to keep the backbone from splitting are a nice piece of work from this part of the build too, I might add. A bit like the " Young America's yards" from EdT ... a nice challenge
Lovely job, Jesse. Why take the easy way out ...! You are doing very well
- 1,306 replies
- syren
- model shipways
Sorry to hear about the broken finger ... you shouldn't have given the finger, though You could try the simple things - are you a right hander (as we say)? little things like prepping for the next part of your build ... or get ready for that next build ... read yourself in etc. Hope your finger heals quickly
great minds think a like ... looking good mate cheers
- 504 replies
- washington
- galley
You did get value for money ... kept you busy for a while, you tried nearly every feasible option, you got more airbrush training, and you know what decals to select when in doubt ... On top of that, a very good result in the end. The only remaining question: Is it what you intended, knowing full well your attitude towards your expected perfection ...
Good save, and lucky you got the one which is covered. Stange they didn't have 4 hawse holes though
Fokker Dr.I by Mike Dowling - FINISHED - Artesania Latina
cog replied to Mike Dowling's topic in Non-ship/categorised builds
Nice!!! Looks pretty sturdy too -
A small marvel Piet, and big accomplishment!! Take your time on the diorama. Better do it right the first time of
- 378 replies
- java
- pacific crossroads
He, ho ... he, ho ... Couldn't you make a baseboard with a cross cutout so you can slide the rotary table in different positions ... just a thought popping up ...
- 504 replies
- washington
- galley
The more impressive the result. Pumps are looking good too
- 504 replies
- washington
- galley
Impressive Mike. Very nice rigging ... looks like you've done it before -
Lovely job. What are those dark spacers made of? When I look at the original, I don't see hexagonal nuts, so you could shape them down, filing them to scale ... at least the "top" ...
How are your bonsai skills ...? Oh golly, another kit impatiently waiting for some TLC (knifes, glue, and paint) ... already looking forward to the next one. But first things first ... Dr 1 (could be a 007 film title ) -
" I've done some final trimming etc in readiness for the upper skins. I've also fitted the "teak" sections of the main decks. These fitted perfectly : " What did you expect else, with your wood skills - as show in Vulture Those hull pieces do fit quite well ... you can always say the paint cans were from different batches when someone starts on the "50 shades red"
Ah, well we from Dutch stock seem to have found your build log first Wouldn't miss this one for the world ...
Actually, since you mention it ... -
Which doesn't mean those should remain static (can always try to persuade you ...)
