cog
Everything posted by cog
  1. It seems Grandad is doing fine, even with the minor set backs he has now and again
  2. Still magnificent photography, on al your builds I have seen.
  3. Some of your photographs look like M.C. Escher drawings ... so complex
  4. Superglue won't hold Steven. You can take it apart again without to much force. Dick is right, you need a glue which fuses the polycarbonate. Not certain if MEK works, but there are a few glues which are specially used for this material
  5. EZ Line has a rust colour, they have a number of colours actually.
  6. Having a sabbatical, Jan ... or a coronacal
  7. Adding AK paints I see. Getting a mix like I do. Turrets look real good, mate, wouldn't bother 'bout the purists to much
  8. You wanted it to match your dillpress!!! Love the way it turned out
  9. Used pastels, or paint? Looks like pastels from here, bery, bery nice sahib
  10. Well done so far. Your airbrushing looks very good. Put her on either a styrofoam or towel from now on, any hard surface will damage the bottom and you will have to repaint. Besides a towel gives you the advantage to slant her when working on her. Looking good mate
  11. Superbe, a very beautiful build Yves magnefique, you can't hide anymore your prowess in plastic builds, not with this result
  12. What's left for me to say, than: Outstanding work, Steven. I did not expect such a fast finish. You took me by surprise this time, well most of the times anyway. I am curious as to what you next build will be. Hat of to you!
  13. You've gone quite a ways, Steven. Your helmsmen look good, and have the fitting and typical "Steven Dromond's Hair cut"
  14. I would suggest something lower like th e pavesade you mention. You actually only need a fixed point around which the cable can be directed in a (more or less) straight line to you windgirl. I stopped driving blunt nails into my brain when I found out I didn't have one
  15. A wee bit late in the conversation but couldn't a block and tackle have been used on the anchor in combination with the windlass?
  16. That, mate, is quite a pitty as all your ships are well worth to be seen!
  17. "AK" has paint sets for the Eastern and Western approaches which are very close, so does "Lifecolor". BNA modelworld has both of them e.g. RN Eastern Approaches doing great cheers mate
