Mirabell61
Everything posted by Mirabell61
  1. Denis, thank you for your nice compliment, ... I just received the smallest bagfeet with 9,5 mm bowl OD, and 4 mm vent tube, am removing the clips and shall probably solder 20 of them tomorrow Nils
  2. awsome modeling Alexandru !! Your rigging looks top..... Nils
  3. lovely work Albert, will you keep up the possibility later on to view into the model, right down to the lower decks ? That looks fantastic, also the wood tones composition is superb Nils
  4. Thank you so much for your kind appreciations and compliments - Bob - Albert -Nenad - Bill - Steve - and Pete, and all those that expressed their "Likes" recently... Bob, I`m pleased you like the vents... Albert, a nice compliment, thanks very much.. Nenad, much appreciated, thanks very much... Bill, sorry for the wrong term in this relation, and thanks for putting me on track again, much appreciated.. Steve, the learn curve sets in at an early stage, this evening I made a few more bowls, and am pleased how fast they can be done now, Am still looking for some with only 10 mm diam. (found some and ordered at Ebay already, hopefuly the turn out right) Pete, thanks very much for your words...
  5. Hi Nenad, always busy as usual,...... nice progress with the decks fitting out do`nt forget a paperroll hanger inside the WC, and a water bucket ready outside for flushing Nils
  6. full elegant hull Patrick !!, I`m amazed how swift you are modeling, you sure know what you are doing there...... Nils
  7. Update making vents have been producing vents in different sizes these days, the pics show only 39 and there are 39 more to do (total 78) The time consuming part is to get the radial hole to size of a close fit around the tube for good soldering with a gas torch I`ve never used my Dremel (and different diameter grinding bits) so much before Nils
  8. Wonderful 12 1/2 footer Pete, this reminds me so well for sailing many years with my Cornish Cormorant dinghi day sailor, about the same size at the Baltic sea.... Nils
  9. Mihai, your "Pegasus" build looks very nice, I also like your color giving scheme.... Nils
  10. Hi Piet, ref. "bag feet" https://www.google.de/search?q=bag+feet&noj=1&site=webhp&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwixkPWFponPAhVGBBoKHboaCysQsAQIHQ&biw=1583&bih=965 Cheers Nils
  11. Good progress Patrick, looks like you had a sigh of relief when the hull came off the mould in good condition..... Nils
  12. Thanks Bob, I found these so called "bag feet" on a web site of an Italian source. The benefit was the elegant rounded rear side of the bowl, also giving a little more depth, so larger vent tubes could be used, than with ordinary flat reared bowels. I was initialy looking for "acorn nuts" in appropriate thread sizes, the ones with brazed on domes made from sheet, but was`nt able to find any at all (used to cut off the domes), that what I did for my "Heinrich Kayser" steamer Nils
  13. Hi Ed, right, I remember when member Lee posted his progress steps on his lovely Cutter "Alert" he gave me the tip to use a black cloth or black blanket as background for those full view pics, and I follow his advice now and then with good results. Your approach with the cut-aways on "Young America" is superb just like is.... Nils
  14. Hello Ed, love that model, the way you make the outcuts in decks deck-houses, and even one of the boats is only half planked. The last pic with the black hull, the golden ornamenting and the partial sheeting look great, Beautiful work, what a pleasure to look at. Nils
  15. Patrick, new innovative ways of making a hull, interesting to follow wish you that all works out the way you planed it to be.... Nils
  16. Thank you for your compliment Albert, I chose the vent tubes acc. to the max possible tube diam. that can fit neatly and radial into the bowls for soldering Nils
  17. Hi Piet, yes sorry, I should have explained a bit better....... The pic now should be self explaining. The sample bag foot button in the middle still has the fastening device.. Nils
  18. Build log part 40 (update, making the vents) starting with the various number of bowl vents to begin with..... Here bowels for the 3 smallest sizes with holes in them to solder the appropriate vent-tubes in. The bowls are made from steel sheet bag-feet buttons, after removing the bag- fastening clip devices.... Nils
  19. Good work Jim, you`ve sure been busy and the results look beautiful.... Nils
  20. Congrats to the recent keellaying party Patrick, I`ll be watching "Shadow`s " ride, hope all is ready and well organized for the larger sister of "Majellan" wish you all the best with the new build Nils
  21. Figurines for use as 18th century scale 1:48 Naval soldiers on models of that period, some months ago I was considering the build of the British Naval cutter "Alert" of 1777 after Peter Goodwin`s book and plan. Looking for 1:48 scale deck soldiers I found these.... and would like to share the find with fellow builders here on MSW. http://scenearama.woodlandscenics.com/show/Item/SP4454/page/1 the kit comes with good looking, fully painted soldiers, 3 American and 2 British, in appropriate period coat of arms Nils
  22. Thanks Bob, it looks great, I use the same technique for my ships decks and it also worked well every time, even if the planks are only 0,8 mm thick there is enough "flesh" on them for sanding over prior to varishing...and the "caulking" remains visible... Nils
