Keithbrad80
Posts posted by Keithbrad80
This looks awesome! Nice work scratch building a few things your lobster trap looks great! What did you use for the net?
Very nice work, it looks great!
I’m sorry to hear about your father... It looks to me though that he had fun building these ships, which like Chris said, is probably the most important part. Good luck in finding a new owner and take care.
Bradley
- Cathead, Canute, mtdoramike and 1 other
- 4
Nice work getting those planks in, it’s coming along nicely!
Bradley
Hello everyone!
I have been working on two Grand Banks Dorys recently so I haven’t had much time for the flying fish, that changes today! My two dorys are pretty much both finished, I finish those in the next week or so.
Now about the flying fish, I have finished planking the port side, I think it looks pretty good. I wanted to use as little wood filler as possible on this one and it only seems I need it in two or three spots. This ship has been no joke, I would say I cut at least 300 planks for this side alone.
Here are a few pics, at this point I have just sanded it to 220 and wiped it down with some mineral oil.
this line where my first planking (garboard and belt f) and the second phase of planking meet looks pretty bad to me, shouldn’t be to much of an issue because I’m platting it with copper later. Now on to the starboard side!
Thanks everyone!
Bradley
5 hours ago, Danstream said:
Very good! An airbrush is a wonderful tool, but let me tell you a last piece of advice, if I may. It requires some practicing and experimenting before obtaining satisfactorily results. Please note that the cumulative time you will spend using it on your model is very short and surely not enough to learn how to use it at best. Make some free trials before on pieces of cardboard experimenting the effects of varying parameters (mainly thinner/paint mix ratio and pressure) and later on try to simulate the desired effect that you are going to obtain on the model. In this way, you can accumulate a sensible number of training hours before you feel ready to attack your model. You might feel wasting your time doing so, but believe me, you will not. You might enjoy also this learning steps.
Good luck and best regards,
Dan.
Thanks for the help dan, when ever I get one I’ll make sure to spend a good amount of time practicing and learning the machine before it touches my model. Thanks!
Bradley
Hello everyone,
So I’m an absolute novice with an airbrush, I have never owned one but am looking to buy one. I’m wondering if any one has some advise on how to get into airbrushes? The start up costs of a generator, cleaning material, and the airbrush seem a little steep for knowing little to nothing about it. I have paints, I typically use acrylic on wood, I’m not sure if that matters. I have found some stuff on using an airbrush and personally I think I’m pretty good with a regular can of spray paint so I’m looking more for suggestions on air brush systems that you would recommend for a total novice. Thanks!
Bradley
Contact cement can be tricky stuff, assuming you are talking about a different glue than CA glue. With contact cement it works best if you apply a little to both sides of your joint then letting them sit for a second and then joining the two pieces together. This should stop it from being stringy, a blow dryer works well with contact cement as well. The build is coming along very nice! With that bent plank, it could have been because your clamps were too strong for that application. Shouldn’t be a big deal though, you can probably hide it or fix it later. nice work!
Bradley
3 hours ago, ScottRC said:
That is a repair I have gotten quite skilled at. I broke the bowsprite off my 1/96 scale Constitution and Alabama, and then my Mother did the same on her Thermopylae. Because of the frequency of breakage on the 1/96 scale ships, with hollow booms, I put a steel rod in the bowsprit boom to make if stiff enough to endure the casual bump while being moved.
that’s some good advise, I haven’t had any thing break on previous builds but I could see how this could happen all the time, honestly I might start doing this just because -
You could try remaking this piece... if you have enough space on the same sheet of laser cut wood that those pieces came from you can trace the piece on a space that will be big enough to create a new one and cut that out, basically starting over.
it’s a tough choice just because I’m not sure how visible this piece will be. For any small gaps you can add a bit of wood filler or a shim if it’s larger.
here’s what I would do though, read through the instruction booklet and go on other build logs and understand what this pieces is and what role it plays in the overall structure of the ship. If you discover that this piece doesn’t play a big role in the structure of the ship then I would just make it look good, if it is super important then I would make sure it’s in the correct spot if not then it may cause more problems later. Regardless of how it looks I would make sure it’s in the right spot before continuing.
your making good progress, good luck and have fun!
Bradley
3 hours ago, druxey said:
Nice and messy looking! She sure looks well used.
Thanks! Next time I try this I probably won’t go as far with the weathering, I may have over done it in some spots.
Thanks every one for the suggestions! I ended up leaving the net off, maybe I could add it in later but I don’t have the urge to do it now.
So I’m pretty much done with the first one and I’m happy with the results! I started by trying to create a weathering look on the dory before installing the seat risers, I gave it ten coats of hair spray followed by a semi gloss white spray paint. Once every thing was dry I used several different wire brushes and some water to create the look I was after. Here is the first coat of paint:
I wasn’t very happy with the results, by the time I achieved the textural lines in the wood I was wanting the paint was almost entirely gone.
I mixed some grey paint and water at a ration about 1:15 and painted it on there. I practiced a few times before applying this wash but the results were great, again. I gave it a light sanding with extra fine steel wool and painted it white again, here it is after the second coat:
I was pretty happy with the overall result of my paint job, the inside I only painted once and thought it was pretty good, here it is:
I installed the seat risers next, but from this point forward I stained and weather any laser cut pieces before glueing them in place. Here are the risers:
A small notch is to be cut into the tip of the frames and side cleats to make way for the gunwale, I measured this notch to be .06 inches so I cut those out and got the gunwale installed:
The breast hook was next, I didn’t get a picture of it but there was a small gap around the back of the breast hook. This gap was covered by the cap rail so it didn’t end up being an issue. Here is the cap rail:
The seats were next, before I glued them down I made sure to weather these more than the rest, I don’t think it made much of a difference in the end, but getting the seats in there really brought it all together. Here is where we are at:
I still have a few things to clean up on this model and then I’ll mount it, and move on to the next one. Thanks again for the support.
Bradley
The lettering looks excellent! I think this method is going to look cleaner than trying to get the letters on the transom directly.
Bradley
- Overworked724 and Justin P.
- 2
Hello everyone,
so not a ton of work on the ship so far but thought I would share what else I’m building for the dory.
I saw this painting in another build log, and I decided I wanted to try to make the things you would typically see in a fishing dory in the 1850s.
this is the bailer, I’m not certain, but I think these would have been used to scoop water out of your boat. I had a hard time finding dimensions for one of these so I just tried to estimate. below is my attempt at a bailer.
The lobster trap was another thing I wanted to make as well. I read through a couple build logs and saw what other did as well as photos and I think mine turned out ok.
so I want to add a net to my lobster trap but am not sure how to make it. I tried setting up a jig to make a net with some fine fishing line, but it didn’t go my way. If any one knows how to make a small net that would be great! Thanks again.
Bradley
Providence by Fentone - Artesania Latina - 1:25 - New England whaleboat
in - Kit build logs for subjects built from 1851 - 1900
Some times the effort that goes into fixing something is more than just remaking it. Personally I would try to recut these pieces from a fresh sheet of wood but if I can’t because it would cause damage then I just use a little wood filler. There are a lot of different wood fillers out there, just find one that dries hard and can be sanded and only apply what you need. Once it dries it can be sanded and shaped just like wood, so you may want to try that. Looks good so far!
Bradley
