Everything posted by Gregory
You can use a tumbler like the Block Buster. I have my own little version that works better for me.. I have a pretty good stash of Chuck's blocks so I wouldn't go to the trouble of making the kit blocks work these days. But there was a time when it was all the kit builder had. Of course there are some kits like Vanguard, that come with pretty decent blocks.
I've stained those 'bargain' blocks with Fiebing's Leather Dye.. I'm satisfied with results.. You can see I ended up with some variation, but i think that image is light overall, because my rope is darker than seen in the image. Just a note, based on another user's experience. If you use shellac on the rope and block after it is in place, the dye can leach out into the rope..
Just to keep the discussion going. Here is a draught of " 'Dorsetshire' (1757) Scale: 1:48. Plan showing the capstans, lanterns, turned columns, A snip from that drawing. Did someone not follow the 1750 establishments? 😁 Medea 1778 One More: Prudent 1768 . The shading would seem to indicate the centers are turned. P.S. I realize, without further evidence, we cannot assume the ship was built as drawn.
Chamfering the corners would not reduce the square diameter from 16" to 13". Besides, you would now have an octagon and not a square. Are octagonal pillars described anywhere for these ships? Are "square" pillars found in any contemporary drawings? This is an illustration from " Navy Board Ship models". Of course it doesn't prove anything about Victory during the time in question, however in the absence of contemporary drawings to the contrary, I think McKay's opinion is as good as any. P.S. Here is an illustration from Lavery of " Early 19th Century First Rate " .. I guess those pillars could be square, but they don't give that impression.
The AOTS Blandford also shows double + single for 6 pounders. I guess Goodwin didn't read Caruana.😁 Lavery in " The Arming and Fitting, etc... " .. without regard to caliber. Takakjian in AOTS 'Essex' shows double + single for 12 pounder. Was Caruana's data part of the establishments? Did armorers always follow this practice? Double + single has become a modeling convention, particularly with kits, and most builders will never be shown anything to the contrary until after they have done all the work. ( ....hours of fiddly work. ) I agree with Thukydides that the aesthetics come into play with ship models, in many areas that are contrary to contemporary full size practice. With that said, Thukydides, your Alert sets a high standard in ship modeling. I apologize if I have cluttered up your log with this distraction.
- 562 replies
- vanguard models
- alert
Construction of Masts for 18th Century 'Ships of the Line'
Gregory replied to tmj's topic in Nautical/Naval History
When you say " how", do you mean tools and methods, or just design? Lees shows a lower mast from 1773 to 1800. Note the sections. Mondfeld shows the cross section of a made mast, but there would be little point and somewhat challenging, in trying trying to model this type of construction, unless you wanted to score some lines along the mast to to represent the pieces used. For more details you could get a copy of James Lees The Masting and Rigging of English Ships of War, 1625-1860 or Historic Ship Models by Wolfram zu Mondfeld. The Anatomy of Nelson's Ships by Longridge is also a good modeling reference for Victory. -
Timber-framed outdoor kitchen - Cathead - 1:1 scale
Gregory replied to Cathead's topic in Non-ship/categorised builds
How long does that cedar stay aromatic? One of my favorite scents... -
Books to learn Fusion 360
Gregory replied to allanyed's topic in CAD and 3D Modelling/Drafting Plans with Software
Do you have any links for the YouTube tutorials for Fusion360 based on the drawings in this book. I could not find any. All the videos I see are for AutoCAD The book says: In fact, it provides no instructions at all for using the interface of Fusion360 It is just a collection of CAD drawings with the dimensions. It really does not look very useful for learning Fusion 360. -
Interesting knot tying gizmo.
Gregory replied to Bob Cleek's topic in Modeling tools and Workshop Equipment
Good find.. looks interesting. Here is a three pack at Amazon for $8.99 I saw one for as little as $2.99 , but delivery takes a bit longer. -
This is interesting in that the trucks are often depicted with bolts, which wouldn't be necessary if there was only one piece. Here is a truck from Victory with two pieces bolted together. However I have seen other carriages from Victory with the trucks being one piece and no bolts. I realize the current Victory carriages are probably mostly modern reconstructions.
Hello from Switzerland! Mystery model identification
Gregory replied to Nix's topic in New member Introductions
The shields on the side depicts simplified Coats of Arms. Google tells me they may have been derived from any number of countries. The flags may just be whimsical creations of the artist. -
My laser cut planks
Gregory replied to modeller_masa's topic in Building, Framing, Planking and plating a ships hull and deck
Terry, My tutorials would be more of a " what not to do " when developing laser patterns.. My experience has been real hit and miss before there was much expertise available. I enjoy making the stuff I do, and my tools and workflow have improved, but I don't want to compete with the pros. The logistics are a bit challenging, and it needs to remain fun for me. I am always open to helping a fellow MSW member with a 1-off project if my skills and their needs can find a common ground. Gregory -
Hi Rob B, FWIW, Mamoli kits do not come with a separate parts list. All the information is documented on the plan sheets. Sometimes there is a color chart for the wood on the inside of the box, but as you can imagine it may not be much help. Your best guide is the measurement of the wood, and the quantity, which can be loosely matched to the amount called for. It is a bit of a challenge, particularly with a large kit like Victory.
- 395 replies
