Everything posted by Gregory
Le Coureur by PC52 - Mamoli - 1:54
Gregory replied to PC52's topic in - Kit build logs for subjects built from 1751 - 1800
Something else to consider, depending on the thickness, you can see how far you can sand down the backside of these pieces and make them as thin as possible without losing the detail.. I have done this with Dusek/Mamoli kits before.. -
Why do some manufacturers make single plank kits?
Gregory replied to Meriadoc Brandybuck's topic in Wood ship model kits
Another consideration with double planking, is that you have the option to use a wide variety of veneers, that may not be easily/cheaply obtainable in planking strips suitable for single layer planking.. Of course there are those who might ask " Why would you want to use anything besides AYC ? " 😁 -
Technically this is true.. However, many ships were built with the frame spacing so close, as to provide almost a solid surface for planking. I don't see why there should anything inferior about creating a solid surface on which to lay your final planking and make the best model you can. Doing a a great job on the so called 2nd planking of a double planked kit, can take as much skill as doing a good single planked kit, and end up with a better looking model. If the goal is to do it the way real ship building was done, then most of your masts and yards should be built up also. And then there is rope. How about smelting your own cannon? The list goes on and on.. -
If you can't easily remove the stem, keel and sternpost pieces ( ... considering creating the rabbet is easier done with those pieces out of the picture ) you might consider covering them with masking tape while you do your trimming. After trimming with chisel or whatever, you can fine tune with course sanding paper..
Vanda-Lay treenail maker
Gregory replied to JerryC's topic in Building, Framing, Planking and plating a ships hull and deck
I have had success with bass, cherry and whatever toothpicks are made of. I have also used boxwood and pear, but I'm not talking about thousands of pieces. When I said soft, I was thinking in terms of softer, as opposed to stuff like ebony or mahogany.. -
How do you file the teeth inside a hole that is 1mm or smaller? The corners on the collets I showed are plenty sharp for turning soft wood. -
I don't do much treenailing, but a method I use for making small round parts might do the trick. I have this set of brass collets for dremel that I use for rounding off small parts like the axels on my cannon. Should be just as fast as any other method if you are making them one at a time.. -
If you have McKay's book, the drawings for the 23 ft launch would be an excellent basis for plans. You can find several plans for long boats at Wiki Commons Here is a 21 foot boat that you could scale accordingly. There are many plans at this location and they all would be pretty accurate..
I doubt there are any pictures available. This was a pretty unique situation for a ship but making sense considering the Bounty's mission. I assume it was similar to copper sheathing but without the nails. Some kind of tiles that were hammered out thin and overlapped at the seams.. Lead was cast in thin sheets and used for water proofing in a lot of situations back then. I doubt that the appearance would be smooth at full scale, but at modeling scales, a lead colored paint would be a good representation.
Wipe On Poly Techniques
Gregory replied to Freebird's topic in Painting, finishing and weathering products and techniques
Takes me a while to use up a can also. I usually thin the " Wipe on Poly " even further, at least for the first coat or two.. -
Blocks and rigging size for Olympia 1:232
Gregory replied to The_Full_Broadside's topic in Masting, rigging and sails
I seem to remember that there was someone who posted here with their excellent very tiny models, but didn't really share any technique that I recall. Does anyone remember who that might have been? -
I don't believe you will find anything for sale at that scale. There are miniature model makers working at those smaller scales, and there are some books out there about making such things. They pretty much use tiny bits of whatever, and fine wire.. I will be trying to find some books for you, but meanwhile someone else may jump in with suggestions. I know this has been discussed before, but I'm at a loss as to how to search for those topics. There are a couple of books by Lloyd McCaffery, but they can be kind of pricey.. -
Here is a nice story without having to click through the slide show. USS Nevada
This is the transom design I had been working on, but the longer I worked on it the more I felt like it wasn't in keeping with the boat as a whole. I decided I wanted something a little more simple. So I settled on this. I hung the rudder. Made a bowsprit so that I could set the gammoning before installing the head rails.. Masting and rigging shouldn't be too far in the future.. I'm mostly working on the guns, and fiddling with some other details. Should have an update on them soon. Thanks for looking in..
