Gregory
Posts posted by Gregory
  1. I see you answered your question, but keep in mind, you can do as much or little as you see fit.
    While my decking would not survive a test of realistic accuracy, I got everything as close as I could within a mm or so, then used the waterway to fill any gap.
    P.S.
    Let me add one more thing.
    When I glued my off the deck planking onto the false deck, I used yellow glue.  I had to take few minutes of smoothing and pressure with my fingers until the glue started setting up,
    which it did pretty fast - 5-10 minutes
  2. 1 hour ago, shipman said:
    Makes $0.99 for 20 look pathetic.
    Not sure why you say that.. 920 hooks for 47 euro.  & $56 US..   What is shipping?
    This is a snip from Dafi.  Largest size is 2mm
    These from Crafty Sailor ( Falkonet )
    The ones from Crafty Sailor look better IMO and are available in six sizes from 2mm to 5mm..
    You can get 1,120 for $56..
    I'm sure Dafi's are good stuff, and a better price if you count the  eyebolts  and don't need anything larger than 2mm, but maybe not the best option for the US.
  3. On 8/19/2020 at 8:16 PM, Sheerline said:
    Would it be better to buy sheet and spile them or would that make them look a bit wide compared to the rest?
    Very nice work so far!
    Spiling might be something to consider at this point if you feel up to it..
    Have you looked at Chuck's bending techniques?
    For the stern just a small increase in width at the stern post for most of the planks is hardly noticeable, as seen here for Chuck's Cheerful. It would only require slightly wider strips, tapered from the stern forward to midship.
     For the bow, you might consider a drop plank.  There is only one on Cheerful.
    Whatever you decide, it will be good experience for you.
  4. 46 minutes ago, Edwardkenway said:
    Unfortunately I don't have a Byrnes saw, but will be using a Proxxon fe
    Edward,
    I recently replaced my old microlux with an FET.
    I'm still getting familiar with it, but all of Glenn's tips work as well with the FET.
    I haven't determined if there is increased clearance at the rear of the fence, but it should be easy to make that happen.
    The micrometer-like fence adjustment on the FET is very precise and allows for making fractional mm adjustments.
    Hopefully you will be able to get a fine tooth .030 or 0.20 kerf blade for plank ripping.  The included carbide blade is good, but wasteful..
