Theodosius
Posts posted by Theodosius
I think I should give this O'Brian books a go. Long time lover of the Hornblower epos. Dunno, how often I read this :-).
Like it very much, that you bring one of the vessels of the books to life and also in such a good manner!
Beeing proud to be referenced here, even though I can't full agree with you. Not, that you don't go with my color scheme, but that I followed the colours of the prototype build and you don't.
Well, you differ in TWO points from the instructions: you don't have painted the inlays in the hair brackets and the vertical bow rails (or frames).
My build differ in FOUR points from the instructions: I paint inlays on the bow main rails, I have the bow cheeks(?) in wood not black, I have the hawse bolsters in wood not black, and I don't have painted the stem under the hair brackest to the waterline black.
In the end I would say, that you are much more in line with the colours of the prototype build than I am :-).
But that is all fine, would be realy boring, if we all would do the same with our models :-). Hope it is ok for you, to point this out, in the end it does nothing to both our builds, and I like your bow-colour cheme also! 🙂
I was thinking the whole time, what is it, that makes this build so good? For me, I think it's this: you make it look so easy, where we all know that it is not easy at all, but that is a quality in intself! I like!
- Blue Ensign, Kingspoke and mtaylor
- 2
- 1
"Upper and Middle Stern Counter Inner Patterns
This is key aspect of the build " - to quote you!
This! I can't agree more! Especialy also the quarter galleries! If they not fell into the lines of the hull, it votes the whole ship down, even if the rest is top notch! And you did a great job there!
Thank you all for the likes! 🙂
@mugje, thanks dude, but there is still a lot of room for improvement 😉
I was not sold on the white oars:So I repainted them, even if it was not so easy as the first time, when they were still on the sprue. Nevertheless, like the brown a little bit more, fit out the rest and but it on the boat for a photo shooting:
Because I did'nt paint the hull, I could not use the photetchparts for the rudder. Instead I faked the hinges with paper strips. Only the macro shows the shrotcommings of this:
Some final views before the launch will be get stored to prevent damage during the rigging:
Perhaps the both securing-lines are too thick (0-6mm). If there are more lines on board from the rigging, eventually I will use some thinner one here.
And its very possible, that I will tune down the bright yellow, if I look closer at the photos...
- aliluke, Blue Ensign, mort stoll and 12 others
- 14
- 1
Thank's for all the likes! 🙂
The wonderful transition a sanding does:
I had my problems to remove the bulkheads. Because of my CA-mess and the switch back to wood glue I managed to loosen the sheerline-plank. Glued it back on, but now I don't had the currage to remove the most forward bulkhead. I was afraid of, to completly open it up again. So it stayed inside. Perhaps some lines will cover it later. We'll see. Forgot to take a pikture, but I had so much excess glue inside, was not fun to try to remove the bulk of it.
All the rest was without any problems:
And a test fit on the ship:
Next is then to fit out the launch with all the pe parts and the rudder is also left to do.
This became a pice of art!
- Paul Le Wol, Katsumoto and Cathead
- 3
Run out of superlatives, so just a thumbs up! 🙂
- mtaylor, Keith Black and Siggi52
- 3
I like your detailed explanations of your rigging-process!
- aydingocer and mtaylor
- 2
What chemicals do you use for the blackening process? With my, I got healthy problems and switched back emidiatly to paint 😕
Wow! I never thought that different sizes of ringbolds would add so much to a modell! Great idear and great execution! I like! 🙂
- mtaylor and Blue Ensign
- 1
- 1
Congrats for your fine model!
Impressive build! And btw: I once had a cocker spaniel too! A red-white girl! When it will be possible again, we will also get another for ourselves :-).
- Kevin, mtaylor and Old Collingwood
- 3
your painting is incredible! Love it!
- Glen McGuire and Thukydides
- 1
- 1
Great start on this elegant model!
Thank you all so much for your thumbs up and the 'wow's. Much appreciated! 🙂
@Thukydides: thank's a lot! Just used your painting advises on the guns :-). And: the paintig on your cutter is top notch!
@TBlack: thank you too for your encurregement! Well, I wonce realy had steady hands, now I have a little tremor. It all depends on the point of view :-). But I will not argue. At least I can build again on my model, and this is a victory in itself! 🙂
@Katsumoto: thank you, this from such a highly skilled modell builder and carver(!) means a lot to me!
Ok, back to topic: launch is next!
Run out of 3mm strips, but I had a larger pice of wood in my stock and sawed some 3mm strips for the launch. Was the first time I did this, and this requires some skill to developp! I was not able to cut these strips with a consistent with. No problem here, because the launch only need rel. short strips.
'can't work with CA, after the first strake I switched back to my normal white wood glue:
I managed to break the transom in two, so I will get a little bit of a roundet butt:
This one requires some fancy shaping:
Quite some gaps, have to wait how it looks after sanding. In the worstcase, I will just use filler and paint it, it's ok for the launch, IMO.
Not 100% satisfiyed, but it will work one way or the other (to paint or not to paint and fill, *g). It was quite challenging to plank. I did'nt taper enough, take not enough time, so I needet some very pointy gap fillers. Next one will be better, I'm sure of :-).Well, thats all for it for now!
- CiscoH, Thukydides, allanyed and 2 others
- 5
HMS Sophie by TBlack - kit-bashing Jack Aubrey's first command from the Vanguard Models HMS Speedy
What I have read about Cochrane is, that he did very successfull a lot of raids at land, so I'm very sure that he was able to not only his whole crew, but also some soldiers, to transfer them to/of/from-to land/ship in one go. I have no Idear how many boats of what size he had used for that. But that was Speedy and perhaps not during her whole career. But while your Ship is more based on a novel, I would just go with 'what looks best' and not what might have been. I'm sure you will find a good solution 🙂
