Posts posted by Rustyj
Here I’ve completed the decorative rail on top of the quarter galleries. My rail, Chucks has 3, has
4 decorative pieces in it
. My curve was a little bolder so it ended up too long for three so I modified it to make four fit. I’ve decided to leave well enough alone with the windows. They won’t
be installed until much later as there is a lot of sanding and they will just trap dust and debris.
The only thing left to do for now on the galleries is to make the decorative columns. I am waiting
on a .016 kerf saw blade so I can cut flutes down the face of each column.
That will complete chapter 6.
That will also catch me up to where Chuck is at right now. That will leave me time to work on
some other models I’ve shoved to the side. Also my daughter is moving to another house next
month and I have a looooooooong “Daddy do” list that will keep me quite busy for the foreseeable
future.
I just have to remember how to work at full scale again!
- ChrisLBren, coxswain, Wishmaster and 26 others
29
Hi Bob.
I agree that the figurehead is fantastic and Janos was very generous. It compliments all the great work
you have done on the bow and the rest of the ship.
- janos and CaptainSteve
2
Thanks Augie and Chuck, also thanks for the offer to re-cut the windows. You are right the angle was
off and now makes this an oh crap moment. I adjusted the rear most upright and that corrected the
angle for the rest of the windows.
Here is the new angle.
For the roof I had to make shingles and as Chuck described slicing them from a strip of 1/8” boxwood instead of
cutting from a 1/32” sheet was much easier. The pieces are cut a little thinner than 1/32” and then sanded to clean
them up and make them even thinner. The shingles were placed one row at a time. Once dry the tops of the shingles
were sanded smooth to match the roof angle so the next row would sit flat.
This catches me up on the work I had done while my pc was down. Now I have to decide do I rip it all out and get the
new windows at a different angle or continue on and make the columns for between the windows. Hmmmmmm.
- Dubz, KenW, Model Mariner and 25 others
28
Hi All. Sorry for the delay in posting but between pc problems, the holiday and general family stuff I’ve been a
little busy. That’s not to say I haven’t gotten any modeling done. Well now that I have a new pc and I’m not using
the Admirals laptop and the backup files have been transferred I’ll start getting caught up.
I have completed the moldings on the transom and while doing so I noticed a minor problem. Self induced I must say.
The upper counter is supposed to be uniform from port to starboard. Mine wasn’t! It was easy to correct this but in doing
so it threw off the height of the bottom of the quarter galleries. They are supposed to set on top of the black strake. Mine
will be into the black strake. It was the only way I could correct my error without tearing out the transom and wales. It just
goes to show the relationships between so many portions of the build. Miss on the wales placement and it alters the counter
which alters the quarter galleries.
Here you see a set of laser cut lights and trim on laser board that I got from Chuck. This is really nice
stuff. Very thin and delicate but durable. I don’t the gentlest touch but the outer lights survived my
handling.
More to come in a bit.
- Elia, realworkingsailor, Archi and 23 others
26
Thanks Jason,
I made my scraper from a leftover Confederacy scrapper.
I just used small files to form my desired profile as Chuck describes.
I’ve started working on the fancy molding on the transom. The molding is cut from 1/32” thick
stock and is 1/16” wide. The shapes were traced and then rough cut out with a scroll saw.
I then sanded them to their final shape. I then used a scraper to obtain the profile I wanted.
Here is where I’m at so far.
- realworkingsailor, dvm27, Elia and 22 others
25
I noticed your files do you use cheapo ones like me and replace them often or are they nice ones that stay sharp?
Thanks ASAT and Joe,
They are relatively inexpensive ones. I only use them on wood and I’ve had them for 5-6 years now. They are
still in an acceptable condition but once they head south I won’t feel bad about chucking them.
Thanks Ben. Of course!
Oh yeah I see major potential for an oops moment!
Thank you all for the kind words and all of the likes. It is very much appreciated.
Well I’ve started chapter 6 now and started working on the stern. To start I have to cut the transom out of
some 1/32” plywood. I pasted the plans on and then cut it out with the scroll saw getting it close. I then
used various sanding tools to get it close to shape.
The windows were cut out using an x-acto and finished with files too.
Then the assembly was glued to the frame work.
That's it for now!
- gjdale, Elia, Elmer Cornish and 17 others
20
Hello all,
Well I’m happy to say I’ve completed the planking on the portside too. No stealers or drop planks this
side either. All that is needed now is a good deal of sanding and then some wipe on poly. I have to say
planking this way is more time consuming but it works so much better and the run of the planks is much
easier to maintain. Definitely the way I will plank from here on out!
One thing I want to point out is that I handle a model a lot when I’m working on it.
Because of this I would inadvertently rub off some of the pencil marks. To make sure
I didn’t lose the main belt line mark I used a sharpie to mark them. Then if I accidently
rubbed off any markings I could go back to the main mark and redo them.
After I check the hull over and make sure it’s all set I will move on to the stern.
- Beef Wellington, BANYAN, ASAT and 31 others
34
Oh that is so sweet! Well done Chris.
Hi Greg and Ben,
Oh I've used the white glue sanding trick many times. There were only a couple of spots where I needed to do that. The joints that bother me the most were ones that weren't a tight as they should be but were filled with glue and dry before I saw them so there was no sand n fill possible. Oh well trying harder on the port side.
Chris, I could see where doing that with tung oil would work. Not so with the poly as it dries real fast.
Thanks everyone for stopping by and the like. Continuing to make progress.
Hi Chris,
I can't wait to see you finish her up. I doesn't seem like it's been five years either.
HMS Winchelsea 1764 by Rustyj - 1/64 - POB - 32-Gun Frigate
Hi George, Thank you and welcome aboard!
Thanks Pat, Yes now that the hull is planked it will be fun adding more detail to her.
Thank you all for stopping by and all of the likes.
