Everything posted by yvesvidal
Small progress, as I started the "B" belt. That one is comprised of 7 planks on each side. So far, two planks have been added to each side, allowing me to close the fish well. Ten more planks to go..... I also started drilling the holes allowing the flooding of the well, with salt water. The prototype calls for 130 holes on each side.... I don't think I will reach that number but will drill a significant amount. Below, is what it would have looked from the inside of the well: Once everything is painted and primed, the holes will look more defined. Yves
I believe it is coming to no surprise for the members of this forum, but I am starting to like planking that hull. Very refreshing and relatively easy. Alsmot meditative in essence. Eight planks down and four more to go, for the "C" belt: The planks are glued on the frames, with CA glue. Later on, I brush a mixture of white wood glue thinned in warm water to penetrate the basswood and allow some kind of adhesion between the planks. After some light sanding, the planks regain their soft and smooth surface. Yves
After many years of hiatus, I have decided to resurrect this Build log. I must confess that I have never planked a hull on frames (or bulkheads for that matter) and that prospect was blocking me from making any progress. But like many enthusiasts, until you try planking you will never know the ultimate satisfaction of wood ship building. So, there we go, working on the "C" belt, as recommended by the instructions: 4 down.... 8 to go on the "C" belt. Yves
Interesting thread. Welcome to the Giant models!!! Yves
- 11 replies
- president cleveland
- ocean liner
That water is just gorgeous. The ship is perfectly displayed and it makes for a wonderful ensemble. Yves
- 211 replies
- prince of wales
- tamiya
I do not dress at Big and Tall 😀. I am only 5 feet 10 inches, 61 years old and 177 pounds. The model is quite large, on the other hand as you can see.... and heavy too! Yves
Still waiting for my professional photographer to show up.... I think it will not happen, as he is probably hiding in his basement.... Anyway, I wanted to look quickly and very superficially at the cost of building such a model. We will assume you already are in possession of a bunch of tools, including a Dremel hand machine with a nice set of bits. The kit itself is around $450, the RCSubs PE sets add another $270-300 depending on how far you are going, $50 in glues of all kinds, $100 in paints (The Humbrol paints coming from Europe to paint the hull and deck cost me close to $50), LEDs (close to 50), electric motors and many yards of very thin electric wires, the stand made of wood and brass tubes, switches and many little things here and there. We are probably not far or slightly above one grand. Even more if you start buying books and DVDs on that subject..... But when you look at the time it takes to build such model, it is no more than $3 per day which is less expensive than beer or tobacco. We all know that the cost of our passion is no object and as such should be disregarded. I have immensely enjoyed building this model and being able to present it to you readers and enthusiasts. I have to confess that your support and encouragements have been my fuel to continue through that, at times, difficult endeavor. In retrospect, I just cannot believe that this thread was visited close to 80,000 times over a period of 16 months. Thus, to conclude that Build Log, let me offer you some last pictures of the model and of the real thing. I simply hope the model will not terminate like the real submersible.... Although it is not completely clear how U-552 finished its days, I think it was scuttled before the Allies could take possession of it in one of the Brittany ports in 1945. Yves
Delahaye 135 by CDW - FINISHED - Heller - 1:24 - PLASTIC
yvesvidal replied to CDW's topic in Non-ship/categorised builds
You did the best that could be done. I can't believe Heller would have screwed up so well, the distance between the axles. My gosh, what a bunch of amateurs. Yves -
You did a beautiful model out of a difficult kit. Congratulations. Yves
- 54 replies
- norwegian sailing pram
- model shipways
You should be a jeweler. Great work. Yves
- 261 replies
- muirneag
- vanguard models
Superb paint job. Maybe a tad too shinny for such an old model, as clear coat did not exist. Yves -
Yes, it is true that having one side with ceilings and the other side without, can be very misleading and will offset all your hard work at lining up. I agree with your approach of building in the hull directly, and perhaps simplifying some of the inner decks. Yves
- 312 replies
- enterprise
- caf
Yes, you need some medications. I suggest Tamiya and Ambroid liquid glue, inhaled with moderation. Do not forget an ointment of Tamiya anti-fouling red paint on your forehead, before going to bed. Great display. I cannot wait to see them built in the Forum. Yves
Well, it looks like Takom will be releasing two interesting kits in the scale of 1/72nd: https://www.themodellingnews.com/2020/07/previewtakoms-72nd-scale-battleship.html Yves
Fantastic work on the torpedo tubes. Your model is coming along nicely and is very impressive. Yves
This is going to be another masterpiece. Yves
- 49 replies
- Lusitania
- Gunze Sangyo
SardonicMeow, You should offer a special add-on kit to the Model Shipways kit, with all the parts printed in 3D. The original kit would benefit greatly, from these very nice improvements that you are adding to your model. Yves
- 222 replies
- sultana
- model shipways
