Everything posted by yvesvidal
Great base. Quite realistic, with maybe a little bit more white foam around the bow.... Yves
- 211 replies
- prince of wales
- tamiya
Getting better and better.... Congratulations. Yves
- 64 replies
- yamato
- deagostini
Superb Kevin !! The Man and his ship! That model is massive and the 1/48th scale is the ideal scale (in my biased opinion...) to model Period ships. Yves
- 312 replies
- enterprise
- caf
Absolutely incredible. This Russian submarine is obviously Museum quality, made by a seasoned team of experts. Thank you for sending that link. Yves
How timely.... I was considering purchasing that kit. I will be following your progress with a lot of interests. Yves
- 30 replies
- grand banks dory
- model shipways
Kevin, if we could not see your tools all around, I would swear it is a real boat!! Yves
- 72 replies
- fishing boat
- artisanal fishing boat
Great work Kevin. You are experimenting and I like the solutions you are coming with. It is not a simple kit, between the charred wood to remove and the large number of parts, all looking the same. I cannot wait to see you holding the fully framed hull !!! Yves
- 312 replies
- enterprise
- caf
Now, you need to place a small propeller inside that tubing. Yves
- 70 replies
- calypso
- billing boats
This is so realistic and beautiful. You are so lucky to live in such paradise and go fishing at your leisure with your Perseverance boat. Yves
- 72 replies
- fishing boat
Exciting kits. I am glad that multiple threads of these CAF models, will be started. In the old days, certain kits were pre-cut with water jets, which does not leave any charcoal marks on the parts. It is unfortunate that this technology is not used more or no longer used in the kit industry. I suspect that the water cutting machines are a lot more expensive and bulky than the laser cutting machines. Yves
If you are not satisfied with the coiled brass wire that they gave you, you could use N-Scale tracks (1/160) or perhaps better Z-Scale tracks (1/220) made by Marklin. You can easily remove the rails from the plastic ties or even buy the rails from Micro-Mark which sells them individually. Use code 55 rails or even smaller if you can find them. I believe real rails will look better than round wires. https://www.micromark.com/N-Scale-Code-55-Flex-Track-Bundle-of-6-Pieces https://www.ebay.com/itm/Marklin-Z-Mini-Club-Straight-Section-9-Length-8505-LN/174408520737?hash=item289b8ed421:g:m-MAAOSwu0BfRSm2 Yves
- 64 replies
- yamato
- deagostini
I am starting to really like that kit. Very nice assembly so far. You also need some Italian beverage on your shelf, a Chianti or some Asti Spumante to replace that beer. Yves
- 54 replies
Well, both guns are now complete and I still do not know for sure, which one to mount permanently on the U-Boot..... Ideally, If I had known earlier that Eduard was offering this kit, I should have mixed parts of the Trumpeter, RCSubs and Eduard gun kits, to make the most realistic model possible. The Eduard kit is definitely more precise in the casting and offers some details that the Trumpeter parts miss completely. On the other hand, the Trumpeter/RCSubs kit offers a gun which can pivot and swivel. It is also more solid because of the flexibility inherent to the polystyrene. By comparison, the Eduard resin parts are very brittle and are just asking to fall apart if poorly handled. It is also completely static which may not be a bad thing. Maybe I should design the gun bases so that they can be interchangeable, based on my mood..... 😉 I think I am going to retain the Trumpeter/RCSubs version but it is truly a tough choice. I have agonized long enough and must keep moving if I ever want to finish this model. To end that presentation, a couple of pictures for a 3D rendering of the gun and the real stuff: Yves
Thank you for publishing this picture. It really gives us a sense of how large the model is and how complicated. This is going to be a great model, no doubt. Yves
- 312 replies
- enterprise
- caf
