dvm27
Everything posted by dvm27
  1. I think silk rigging looks beautiful and I know many of the Navy Board models were rigged this way. I have also seen silken robes from previous centuries and they look fine (perhaps because they are preserved in a museum). But I now read that while silk can survive decades they start to deteriorate through a process called "shattering" (the short cross threads become unwoven) at around 60 years. Perhaps this appears in garments only and not laid up rope? But I am fairly certain that no restorer in 2300 will be able to replicate Johann's magnificent work here if the rigging starts to deteriorate.
  2. Spot on Chris. The rabbet transition is particularly well executed!
  3. What a delight it was for David Antscherl and myself to stumble upon this model after the NE Ship Modelers Conference. I have his books but the model in person is even more impressive. I wonder what Ed is up to now?
  4. I had a similar problem with the decade long build of my Swan class model. My earlier work was not as good as later on and some of those came rookie inaccuracies came back to haunt me as the project progressed. Have a great holiday. Oh, to be 60 again!
  5. Nice video on blackening Kevin. Some random thoughts - I use either alcohol or acetone as a degreaser. Also, keep in mind that brass is an alloy and, depending on the composition, some brass is much more difficult to blacken. For large groups of pieces I find that pickling first makes a difference in the blackening and uniformity of the finish. For small pieces you can use a paint brush to polish them in a deep tupperware piece so they don't fly away. Polishing prevents the finish from transfering to surrounding pieces and evens out the finish. Finally, while it's easier to blacken the Swan PE sheet whole don't you find that you still have to blacken the cut edges after removal from the sheet?
  6. In our office pharmacy we use a pill counting app on our cell phones. It works great for similar sized pills (or objects). You obviously wouldn't use it for small groups but for packages of >10 it might be a useful app.
  7. Here's a jig that can be made out of heavy card or aircraft ply. It's not my design but solves the spacing problem between the deadeyes.
  8. Now that’s a Pegasus! Very impressive Giampiero. I note on the Swan plan and other contemporary figureheads the presence of stippling on the small uncarved section under the belly and legs. I think it adds texture and visual interest. Did you notice this feature?
  9. These belaying pins are fabulous! The 1/4" ones are perfectly proportioned and fit a #66 hole. Note - most commercially available belaying pins have very fat handles. Chuck has just saved me hours of work. And adding thimbles to his store would be equally amazing as the commercially made brass ones are no longer available (Crafty Sailor).
  10. Your model is very lovely so far. Your concept of rigging the lower yards only with the top masts lowered and mostly derigged is reminiscent of illustrations I’ve seen off these ships in their winter configurations. Perhaps consider not gluing in the masts. Once you’ve added the shrouds, stays and back stays they are almost impossible to move but minor adjustments may be made by adjusting the standing rigging (just like the real vessel).
  11. Mine goes from 23" to 50". You can set the high and low with a memory button. This will prevent me from impailing my mainmast into a ceiling tile.
  12. Very sorry to hear of your recent losses Ab. If we live long enough this becomes inevitable I suppose. Your model is quite lovely. You have a very discernable style which produces simple elegant models.
  13. I just bought this FlexiSpot E7 and it's phenomenol. I bought the cheaper version and applied my own top. It is motorized and smooth as silk.
  14. I'm happy that you've created a new view of Doris's work. Though I suspect shee is done with ship model making her work deserves to be preserved gere forever as a resource. I would hate to lose it if some sort of crash occured.
  15. Your work is truely inspirational Johann. Could you have worked the thimbles into the pendants prior to installing them under the shrouds?
  16. The problem with such meticulous work is that the joint is barely visible when completed. Lovely work!
  17. While watching your video and your bowsprit problem I was going to suggest checking the stieve of your bowsprit vs. the plan. But you came up with this on your own. Your solution worked out well though. You could have worked in a set of beams on either side afore beam #1 but it will be hidden so not really an issue. You mentioned the "as built home plan" vs the architect's original plan. I'm sure you're aware that many ships plans were labelled "as built" and differed from the original plans as well, likrly for the same reasons.
  18. Hemostats, by nature, are designed to securely hold and crush tissue for hemostasis. The box section is rivited and there is no way to modify it for a looser grip (that would defeat their purpose). While I've not used them for ship model making you may want to try Doyen intestinal forceps. They have longitudinal groves designed to hold tissue but not damage it. As an example https://universalsurgical.com/product/doyen-forceps/. I think the 7" version might work well for your needs.
  19. Love Leo's build and yours as well. I'll bet if you e-mailed Leo he would send you a piece of timber you could incorporate into the hull. I have corresponded with him in the past and he is indeed as nice as he seems
  20. I look forward to your new build, Chris. Had to laugh at your "smaller scale of 1:48" comment. I'm currently rigging a French warship of that era and the masts and spars are massive! Boudriot's rigging plans are superb though.
  21. Lovely work, Denis. Do you have a copy of "Building the Wooden Fighting Ship" by james Dodds & James Moore? It gives some very detailed illustrations about the workings of the shipyard at each phase of the constuction
  22. What a treat to find this Denis! Very much looking forward to this build. Pandora is a great choice and the Anatomy series, though not always 100% accurate, should give you lots of details. Any way you could insert Pegasus into the building slip?
