Posts posted by wefalck
  1. Coming back to the subject of modelling as such, I think I found a good solution for simulating blank cast-iron parts, such as the surfaces of pulleys, and also the steel tyres on cast-iron wheels : I first run them slowly on the lathe (or a hand-held drill) and smooth the surface of the plastic part with very find wet-and-dry sandpaper. For cast-iron I then spray the part in black and for steel I spray in some silver or 'steel' paint. The next step is to rub a soft pencil on the surface and burnish this with either a cotton-stick or one of those paper 'smudging' sticks artists use. I think the results are quite convincing:
    This is a Fowler Z7 ploughing engine in 1/72 scale on the basis of an old KeilKraft kit that I made some 35 years ago.
  2. Today in Europe combine-harvesters are usually owned by contractors or by a cooperative of farmers. You need quite a few hectares to amortise one. In pre-War Eastern Europe there were often large land-owners (landed gentry) that farmed almost at industrial scale and had their own machinery, sometimes even narrow-gauge field-railways to transport the produce.
  3. I suppose this depends on the circumstances: would it be full load or only a few barrels, how long would the trip be and in what kind of waters? Stowing barrels horizontally would almost certainly a better use of the space and safer on longer trips. The barrels would be wedged in place. It also depends on the size of the barrels and how many crew would be there to man-handle them.
    On the other hand, shipping a few barrels from one port to another in reasonable weather conditions may not require a lot of stowage effort.
    Turning over barrels from vertical to horizontal may be quite an effort, depending on their size. There are different techniques for getting barrels in and out of a ship, depending on the availability of loading equipment. Cranes were not very common in small Mediterranean ports, I think. In addition, a fee would be due for their use. A classical method for getting a barrel out of a hold and onto a quay would be with the aid of two ropes that are fastened on the quay at a distance a bit less than the length of the barrel; the rope would be then taken around the barrel and several men would pull on the ropes, effectively rolling the barrel out of the hold and up to the quay. A plank could be used to aid this process. If there was a crane or one could use the ship's boom, the drum would be attached either vertically with a drum-sling or horizontally with two griping hooks.
  4. By coincidence, I was writing a journal review for the German LOGBUCH of SKYLLIS no. 23 (http://www.deguwa.org) and there is an article on how one can conclude from the type of barrel used in 17th century Netherlands: Oosterbaan, J. (2023): Identifying Content through Casks.- SKYLLIS, 23: 103-116.
    It seems that the Dutch guilds of coopers had gauges for each type of barrel and these gauges have been preserved in museums. The author focused on trade barrels for herring and beer.
  5. Apologies for slightly disagreeing with the last suggestion. It seems tempting to use a tool to pull rigging line through a block. However, if a folded line can pass through the hole, the hole is too big for the line. If you look at prototype blocks, you will see that the sheave is only a fraction thicker than the rope it is meant for. There is very little clearance betwen the rope and the block.
    Thus, not really a tool but rather a material is some fast-drying solvent-based varnish with which one can stiffen the end of lines to fiddle them through blocks. The same varnish can also be used to secure splices and knots. Some people use CA cement for that, but I would advice against it, because it is messy and you cannot dissolve, if needed, afterwards. Knots secured with varnish can be unravelled with a drop of varnish, which you may find helpful.
  6. Of course, there were different types and shapes of barrels for different purposes.
    The barrel shown, however, is not for storing meat in the hold, but for dispensing meat on a daily basis. Meat barrels would be periodically retrieved from the hold, opened and their content distributed to several of such casks. Each bench would collect their daily ration, put it into a net with their identification mark attached and then hand it over to the cook.
  7. Yes and no - as always. There are acrylics and acrylics. I have no practical experience with Tamiya paints, but indeed understand that they contain inter alia alcohol as solvent. I know from experience with pieces of furniture that I built that shellac finishes turn milky when you put a wet cup or, worse, a glass will alcohol on the outside on it.
    The problem, however, is not necessarily the water or alcohol itself, but the way how the paint is applied. When brushing on paint, you bring a lot of solvent onto the surface that then has a lot of time to interact with the surface, while it is evaporating. Airbrushing here is the solution.
    Also, when used as a sealer, the shellac should be rubbed down, e.g. with steel wool, so that it does not form a layer on the wood anymore. Then, even brush-painting should have less effect on the sealer. Several thin coats of paint are also less likely to interact with the shellac, as the little solvent from the first coat will evaporate quickly and then protect the shellac.
  8. A variant of the adapted needles mentioned by @Dziadeczek would be crochetting needles. These days the really tiny sizes don't seem to be available anymore commercially, but I enherited a small collection from my grandmother.
    Perhaps a more advanced investment would be so-called Castrovejo micro-scissors as used in eye-surgery. They are very sharp and should only be used on fine threads.
    Otherwise, as for all tools, it is a good idea to wait until a challenge arises and then buy the tool for the job, even if that interrupts your work, rather than kitting oneself out with tools that one perhaps never uses.
  9. The colour will depend on the kind of shellac used, there are orangee to almost white variations and the number of coats.
    I keep small amounts in old film-jars (wisely collected them over the decades ...) and they keep for years. I make different dilutions for different purposes. The good thing is, that you can just add more alcohol to dilute the solutions again. You can actually use denatured alcohol, if you don't mind the smell.
    Some of the nicest surfaces result, when you rub the shellac treated surface (after a good drying period) with very fine steel-wool (0000) and then polish it up again with felt-wheel in the hand-held drill.
  10. Because you really want something with less surface tension and something that is neither water- nor oil-repellent.
    Shellac is made up with alcohol and alcohol has a much lower surface tension than water. The same applies to nitrocellulose-based wood-sealers that use some organic solvent. The latter work better with more resinous woods, as the solvent attacks the resins, while a water-based acrylic sealer would be repelled.
    The effect of oxidising oils or shellac is that they fill the pores and act quasi like optical fibres: the incoming light is guided deeper into the wood pores and absorbed deeper in the wood. This is why wet wood or treated wood looks darker. On dry or untreated wood, the light is reflected already at the pore entrance, which is why it looks lighter.
    So for a good deep glow of the wood, you want something that penetrates deep into the wood and fills the pores.
  11. Nice progress!
    Looking at the chains, from which the boat is suspended, I think there should be a third one, leading to the stem- and stern-posts respectively. These chains are intended to limit the boat swinging forward and backward, when suspended from the davits.
    I think at that time the KM also used slip-hooks to attach the chains to the lower block of the davit, but this may be difficult to reproduce at this scale. The slip-hooks are there to ensure, that both tackles are releases at the same time, as otherwise the boat might be turned over in a sea.
    If you don't have it yet, you should perhaps get hold of a copy of
    BRIX, A. (1911-1929) Praktischer Schiffbau - Bootsbau (reprint 1982).- 394 p., Norderstedt/Hamburg (Egon Heinemann GmbH).
    The 4th to 7th editions would be more or less relevant to the period of SMS KARLSRUHE. Some of the editions are also available in digital form.
  12. If one can, one avoids exposing plank ends to the water, because this is where rot starts. So, the sternpost has a sort of rabbet into which the planking runs.
    The construction would be like that, that the sternpost has a notch cut out on which the transom rests. The planking runs across the transom, but as soon as it hits the sternpost, it runs into its rabbet instead.
  13. OK, here are the only two pictures of the thresher I took, plus a graphic that shows its functioning:
    I thought, I took more pictures, but perhaps not, because the little kit I have is one for a thresher of German make. Lanz, btw. made their own threshers to go with their portable steam-engines and later their Buldog.
    The pictures appear overexposed, because I lightened up the shadows so that one can better the mechanisms.
    The thresher is located in the Magyar Mezőgazdasági Múzeum (= Hungarian Agricultural Museum) in Budapest - https://www.mezogazdasagimuzeum.hu/exhibitions/the-history-of-hungarian-agriculture-from-the-beginning-to-1945.
    And now to the Lanz Ackerbulldog HL12 of 1924 in the Deutsche Museum in Munich. I forgot that this was the first model Lanz made and until 1938 the Bulldog considerably evolved. So the pictures would not be of much use to you. Here is just one to show you what they got:
    Here is a Web-page dedicated to the Bulldogs: http://www.lanz-bulldog-homepage.de/src/bida/hr8.html
  14. Apologies for the somewhat rough-and-ready images, but I was too lazy to pull out the scanner and just took a couple of shots with the telephone:
    From: MIDDENDORF, F.L. (1903): Bemastung und Takelung der Schiffe.- 401 p., Kassel (reprint 1977 by Horst Hamecher).
    These are for iron pins (= Belegnagel) in spiderbands (= Nagelband). Durchmesser stands for diameter. Unfortunately, the table only gives the total length f and the diameter of the lower part g, but not the other proportions. However, I think one can assume that the parts above and below the pinrail should stick out about the same length for functional reasons, which means that the total length below the handle should equal to the length of the handle plus the thickness of pinrail in which the pin is to be used.
    In any case, this discussion shows that the commercially/kit supplied belaying pins, particularly those made from wood, are just caricatures of belaying pins, being usually far to 'knobby'. From a manufacturing point of view this is quite understandable, as shape-turning such long, slender items is quite a challenge, even if one had a Swiss automatic lathe.
  15. ... I thought the thread was about home-use of such technologies.
    The traditional kit manufacturers sell the same models as 50 years ago, because the tooling as such and development of new tooling is expensive, too expensive for the the presumably declining margins due to Asian competition. The traditional tooling, such as moulds for injection moulding or casting metal parts, or the cutting templates for pre-cutting of wooden parts are rigid and expensive. These kit manufacturers probably should team up with Eastern European programmers and Asian workshops to stay in business. Otherwise, they will disappear.
    Small basement manufacturers seem to be much more flexible and adopted the new technologies fast, because the machinery is cheap compared to the traditional one and need very little skills in comparison to operate them. You can run a laser-cutter or 3D-printer without being a skilled mechanic.
    I don't think it is a question of plastic vs. wood, but a question of what look you want to achieve. For a 'realistic' model, it is not too difficult to achieve convincing wood-effects by painting (a technique in principle centuries old and known as 'wood-graining'), but the look of an 'artisanal' wood model can only be achieve only with wood.
    The fact that there are now many Russian, Ukrainian and Chinese wood-kits on the market seems to show that there still is a market, if the price is right. Some of these kits seem to be extremely well designed, so that also a relatively unexperienced modeller can achieve good results. This is likely to reduce the entrance threshold and may be good for this hobby.
    This is a bit off-topic, but the real problem for manufacturers of 'serious' models is, that over the past two decades or so children increasingly grow up in a cartoon and manga world. When most of us were children, these existed only magazines, but not everywhere around the childrens' rooms. They shape the childrens' world view and their expectations, when it comes to modelling. There seems to be quite a limited interest in history and historic or real world subjects, which is probably why the traditional manufacturers are struggling and selling mostly to past-middle-age adults.
  16. You have there quite an international collection: an Austrian thresher (Hofherr & Schranz), a German bulb-engine agricultural tractor (Lanz Bulldog), and a Czech(?) hit-and-miss engine (Slavia). Originally, those threshers where either driven from a steam traction-engine or a portable steam-engine. There used to be some white-metal kits of traction-egines in 1/32 scale, but I am not sure that they are still available.
    In May this year I revisited the Agricultural Museum in Budapest after many decades and took a couple of pictures of the Hofherr & Schranz thresher in their collection. If you are interested, I can post the pictures here.
    For decades I had such a thresher kit in 1/87 scale in my drawer, but I haven't got around yet to scratch-build the matching portable-steam engine I wanted for a little diorama.
    I also remember the Lanz-Bulldog on the fields, when I was a little boy, but they became replaced by more modern diesel tractors in the 1960s. Many though survived and have been lovingly restored. Their engine sound is quite characterstic. There are quite a few pictures of them on the Internet. I also took a lot of shots of the one preserved in the Deutsche Museum in Munich, when I revisted the museum in July this year. However, it is probabaly a different model. Anyway, if you are interested, I can also post pictures here.
  17. Found a picture, from
    BREART, E. (1885): Manuel du Gréement et de la Manœuvre des bâtiments à voile et à vapeur. Comprenant les matières exigées pour l’obtention du Brevet de Capitaine au long cours et de Maître au cabotage.- 459+13 p., 7 pl., Paris (Librairie Scientifique, industrielle et agricole, Eugène Lacroix).
    It's from a later period, but the left most illustration shows the principle that I remember having seen on the model in the Musée de la Marine (unfortunately lighting was not very conducive to taking pictures):
    The lever in Fig. 5, not fully drawn flips down parallel to the toothed rack and is tied against it.
    Such 'high-tech' solutions were not widespread in the navies, probably because battle damage would be more difficult to repair than the traditional system with deadeyes and lanyards.
    Before diving deeper into the rigging, you may want to get hold of some of the French literature on masting and rigging of the time, which can downloaded from the site of the French National Library: https://gallica.bnf.fr/, Unlike for the Google digitalisations, they unfold the tables in full!
    COSTE. F.-A. (18292): Manuel de Gréement ou l’art d’équiper les vaisseaux et autres batimens de mer, de tout ce qui est nécessaire a leurs mouvements.-  282 p., tables, Paris (Dezauche).
    Jaÿ, . (1860): Études sur le Greément d’après les réglement du 25 avril 1857, révisé en 1858.- Atlas du Génie Maritime, 2éme Serie, Annexe No. 1: 55 pl., Paris (Ministère de la Marine et des Colonies).
    VERDIER, M. (1837): Nouveau manuel complet de la marine. Premiere Partie. Gréement.- 290 p., Paris (Librairie Enciclopédique de Roret).
    Also, I would perouse @archjofo's building log here on LA CREOLE of 1827, which has wealth of information on French rigging in the second quarter of the 19th century.
  18. In fact the 'Pretty Chicken' was quite a modern ship at the time and some advanced features were tried out on her.
    Instead of deadeyes or bottle-screws (which at that time did not really exist yet, due to the difficulty of producing consistent machine-screws before Maudsley invented the the lead-screw for lathes), some French ships used a sort of rack-and-lever system. If you have ever seen a device that was used in the old days to suspend a cauldron at adjustable heights over an open fire, that's the same system. I am still looking for a picture that illustrates this ... somewhere in my books I have a picture ...
    I suppose you could fashion this system from piercing saws with a fine pitch ...
