Posts posted by popeye the sailor
Thanks all! I have plenty of masks Ken......I even have one at the spray booth
thanks John
they are just laid out on the deck for fitting the tube chocks in the slots.....not cemented in place I was reading about the 109.......Kennedy lashed a 37 mm cannon to the deck......he wanted more fire power. it was lashed in place of the life raft, as most though they were just in the way, they were relocated to other places on the deck or structures. it would be neat to add that bit of detail PT boats serving in the Pacific theater were olive drab in many different shades...at least from what I've read........and seen. the question of whether or not they were planked on deck, I'm still trying to get a definite on.......I'm thinking that they were planked at the bow, and plywood along the mid ship, returning to planking at the stern. I have a few pictures to show......but the admiral is adamant.......I need a shower {I got off work an hour or so ago}. I told her it was a new collogue...'ode de bearing grease, but she didn't buy it I'll return shortly
- Edwardkenway, Jack12477, Canute and 2 others
- 5
I made a bit more progress with the Agillis. there's more, but I only snapped one picture so far........
I'll have more a bit latter
- Edwardkenway and GrandpaPhil
- 2
thanks OC.....and those who hit the like button I went a little bit further......and of course, more today.
for a change of pace, I started to do a little on the torpedo tubes.......first to separate and sand all the chocks. they are made of resin and were all connected together.
never messed with resin before........kinda messy. after cleaning the floor before Gibbs comes sniffing around, the nose and tail parts were added to the tubes.......more detail to be added.
on deck are the pivot plates...these are the front ones for the forward and aft tubes......the rear ones are stationary, but are pinned to allow the tubes to be positioned inward and outward. as mentioned, these tubes were a bit unreliable........information I've read told of them having to be hit with a hammer, in order to get them to fire! sounded scary to me............ the last section to be assembled is the engine cover, which is connected to the day cabin. according to the instructions.....which is very scant......they don't even give measurements, just a few for positioning.
the center deck parts are warped pretty good......it is making it harder to get proper measurements. I see a change I want to make too, where the cover mates to the day cabin. I'll get into it more on the next update.
agreed with the chain detail.......I chose to use the PE chain on the Vendetta, and should they get bent {for some unseen reason}, they are difficult to lay down. also they look 'flat'. the deck is really nice.......interesting that they make them for this scale. do you have bits for the upper levels of the structures, or are they to remain 'metal' decking?
look'in good James
- Old Collingwood, Canute, mtaylor and 1 other
- 4
looks like your interested in everything they have there you just keep rolling along Andy........it's always nice to see train models being built. don't mind us if you see us gawking over your shoulder. I'll try and keep the garlic to a minimum
very nice work!.......glad to see you back!
we had waste oil heaters where I once worked. the original one they used looked like a small stove.......had to be stoked every morning. the new one they bought had a big register / blower that hung over the bench, pointed out over the bays. it would heat that part and the adjoining bays, even being separated by a partition wall. darn thing would drive you out, if you were in the center bay. are you gonna have air for pneumatic tools?
very nice diorama......really good detail
- thibaultron, Keith Black, mtaylor and 6 others
- 8
- 1
you can also look at the avatars.......if it says 'gone but not forgotten', you'll know that the gent has left the table. no harm, no foul......if I saw something this good, chances are I'd compliment the modeler too look'in forward to your log one fine day friend!
looks really good.......yep, too good to lay waste I've never seen that kit......what is the production year?
have you got a log on her yet?
- Keith Black and mtaylor
- 2
that size of gun has a elongated breech and barrel.......if your gonna fire something that big, you'll need the room look at the size of the breech on Leopold, the German rail gun....freak'in huge! I'm sure your using magnification for this one.......very nice!
- Edwardkenway, CDW, Canute and 2 others
- 5
we seem to think alike? you save the parts panels! I do as well, using them to clone other hulls and fit them out as I like fine looking project......love your below deck details.......it's the little things. I don't usually double plank......it seems hard with this model, given the deep rabbits and the way the assembly runs. I've used the thin strip and thread method for simulated calking......I settled on using a Pritt pen to do it
very nice model....really looks the nine! I'm envious of your planking skills.
gee.........'an I thought those styro foam dit-dots were annoying
- mtaylor, Canute and Old Collingwood
- 3
nice........your half way there sanding and filler is still your friend.......paint covers a lot of sin. you'll get better......the other side might come out better, it may surprise you I haven't got it down pat either....... I wouldn't double plank.......filler.....sand it smooth and to contour, and paint. to me, the only reason that one would double plank a hull, is to avoid stain. cover with Walnut, mahogany, or Oak thin strip and a clear sealer [especially if that particular color of stain is unavailable}. looks fine........your on the right track. when you can get the two hull halves together, you'll see
- Keith Black and Halvor
- 2
I have been all over that 103 site........indeed there is a lot of good info there. since the model is of the PT 109, I though I'd take a browse into John F. Kennedy while I was at it. originally, he was assigned to PT 101, squadron 14 {RON 14}, to patrol along the Panama Canal. while he languished here, PT 109 was in the process of being shipped to the Pacific theatre, aboard the U.S.S. Joseph Stanton, along with three other boats. these transport ships could only carry four at a time.
Kennedy put in for a transfer against his parents wishes, and with the Help of a Mass. congressman, found himself heading for Tulagi Island, where Squadron 2 was based. he took command of PT 109 on April 23, 1943.
two other things I found out in my browsings, was that the torpedoes weren't that great, and neither was the radar systems in these boats......half the time they were unreliable or didn't work at all. now that the hull can sit on her new stand, I can start to flesh out the deck layout. the deck platform has a punch out on each half, to enable access to the R/C works.......the entire structure can be removed. matching the punch outs to the correct side that they came from.......makes for a better fit.
that's the new table.......a bit lower than what I had before. I'll see if the creases in the top gives me any trouble. if they do, I'll have to get something to cover it over.....Formica or the like. I wasn't sure if I wanted to trim the helm structure or the turret rook to fit.......easiest was to just trim the helm structure.
basically, this is how it will sit......to be removed along with the rest of the center structures. the structure isn't finished yet........and there's something I'm not too crazy about. the companionway entry to me seems too small.......that, and I'm still puzzled how the back wall {that little piece I made earlier} fits. so I cut it all out except for the control panel.
thinking it should be wider, I cut about 1/8 off of the control panel. the opening was walled off again with cast off basswood, and added a door, which was an extra from the Progress's fittings kit. those two choppy looking pieces in front are additional shields.....gotta figure how they come into play with this part of the structures. the wood is Spruce plywood.......terrible stuff to work with. as mentioned, being die cut, the parts need to be scored before they are punched out of the parts panels. as for that small section of back wall, it too was shortened by about an 1/8, and trimmed to fit the relief toward the end of the port side wall. now it has the proper configuration.
...and with the turret rook in place.....
I started with the starboard side shield. here where the wood grain can help you.......cutting a piece of 1/32 basswood the height needed, I got it wet, and let it set for a few moments. patting it down damp, it was cemented {with CA} around the edge of the shield 'floor'. with a pair of scissors, it was trimmed with a curve, ending straight down where it opens to the deck. the grain when wet will be a lot more forgiving, for bending it to this degree. it was then glued to the flat surface of the starboard side 'end' box. the wood still damp, it still remembers that it was once straight, so it need to be taught that it now has the bend. the structure was clamped to the table, keeping everything flat until it dries.
using the grain as a tool can add interest and natural curvature and contour. it beats having to round off corners. there are a few chiggers in the shield floor......there will be in the other one too. I could have simply scratch cut another pair, but I have something else in mind. I could have gone further, but I started to clean off table white....then ended up painting the pin rail parts for the Agillis while the work I did on the PT boat dries. I should have more tomorrow
- BLACK VIKING, lmagna, CDW and 9 others
- 12
thanks everyone the nod thing doesn't just apply to the computer, it happens when I spend too much time doing the same thing. I've done it at work too.......runn'in around all day working.......they call a meeting, and they expect you to sit through it. I've been moving all day....now they want me to sit....I call it stagnant this is why I don't sit at the 'drawing board' when I model.......I have to be in motion. I hardly ever draw anything out....the only thing I've ever drawn out, was the dance floor for the M&M boat. I dunno.........maybe I should look into my ancestry, to see if I'm related to Rip Van Winkle or something second cousin to the Sandman...........Prince Valium {Spaceballs antidote}
but no......really, glad I got up the gusto to finally finish her toys that would try to kill you......the Puppetmaster comes to mind
- cog, lmagna, Old Collingwood and 3 others
- 6
hey-ho gents!.......getting caught up with the goings on here.....thanks for all the kind comments yepper......strange events going on.......we saw snow, but you would hardly know it. the flakes were as big as dimes.........really wet stuff. it's over now I think.......haven't seen any more precip since lunch. I knew I wasn't going to get another coat on the hull.......I haven't touched it either. I did put her on the stand though, and now I'm thinking of what goes on the deck. I'm thinking of how many dead lights are on the deck......so I pulled out the Revell kit of the PT 109 and took a look. I also looked on that 103 website, but the diagram there must include the placements of different variants.......cripes, there's a bout 50 of 'em. oh......I did sand around the edge of the deck sheer....a little resin did collect. I'm thinking though that a light sanding might be all it will need......the one coat of resin is good. especially since it's going to be a static model. for anyone who might do an R/C, this is the way to go. after two coats........even without the cloth, it will more than suffice to seal the hull. Vaseline or a light grease should seal up the rudder and screw tubes. I just glad that the day came.......and to me, it was a complete success!
I did some more reno to the spare room........I have a different table now. the table I was using, was actually a shelf I built for some of my modeling stuff. I added a couple more shelves, and opened the room up some more........although I think that dream of a 'wrap around' work table has gone poof in the process I should have a bit more to report very soon. thanks for look'in in
- CDW, GrandpaPhil, mtaylor and 6 others
- 9
PT 109 by popeye the sailor - Dumas
was it fully planked? pictures I've seen looked like it was planking up to the helm, plywood at the mid ship around the structures......I'm guessing about the stern. was it laid fore to aft, or angled?
I thought it kinda silly not to show the gun turrets without at least part of the goodies attached. it's too bad those center deck parts are so warped.....it makes the whole thing look so disheveled. since there really isn't much to go on, I just guessed with the framework for the engine cover.
there's a bit more to it....when this was dry enough, I added more framing......some pictures of how it would look in place
the port side is trimmed to allow the gun turret, but I wasn't keen on the gap between the cover and the day cabin.
the shield that branches off on the starboard side of the turret crosses over this gap and divides it
side view of the starboard shield......you can just make out where the cover roof ends. looking at this diagram, you'd almost get the sense that this area of the deck frame is cut out and all this is assembled as an assembly. it then can be removed to access the R/C stuff. at this point, this is what you get.
basically, I simply take some of the same thickness plywood {what the roof is made of}, and fill the gap in.
cut out the continuance of the circle cut out, and you get this
when its all cemented on the deck, some quarter round stripping will pretty it up. I started to make the ammo boxes......there are a couple more structure bits that fill it out.
