Posts posted by popeye the sailor
there's quite a history on this aircraft.........many variants......A....all the way to M! over 18,000 were built.......there are only two that are flyable today.
nicknames for them included the flying boxcar, but most notably, the flying coffin.......since the only escape route was through the hatch in the tail section. scalemates shows an interesting timeline on this kit. I'm finally caught up in this forum.....my word.....you folks have been busy!
- Old Collingwood, ccoyle, Blackreed and 6 others
- 9
gotta also consider that there wasn't too much of the 'fast food' junk either.........home cooked meals from scratch and all that jee........think of all the chemicals and additives we eat every day?!?!?
hey there OC.......just caught up to your antics! very nice work! the drummer fella came out great really top notch work!
- Canute, FriedClams, mtaylor and 2 others
- 5
look'in good !
- Edwardkenway, lmagna, FriedClams and 5 others
- 7
- 1
great look'in models........camo looks sweet!
- Edwardkenway, Canute, Egilman and 3 others
- 6
congrats Chris! very nice finish..........glad to hear the first outing was a success! building a model has it's pride........but building a 1:1 model and taking her out to enjoy beyond, has to hold a special sense of accomplishment! as a young lad, I used to enjoy rowing around the lake at my uncle's camp............I am soooooo envious!
the decals is small potatoes........you can only see one side at a time
- Canute, ccoyle, Edwardkenway and 4 others
- 7
your off to a good start........the instrument panel looks really good
- Egilman, mtaylor, Edwardkenway and 3 others
- 6
as most know, I've been doing some remodeling to the 'ole hobby room. most of it is done now.....just got to get the particulars in place. it's been a while since I had a plane in the works, so I though I'd drag one of these Atlantis kits out and play with it. the Atlantis kit is actually an old Revell kit, dating back as early as 1954.
the kit went through a series of reboxing and retooling through the years........the second not notably in the early 60's. Atlantis began reproducing the kit in 2019, as well as other older Revell kits. there were different variants of the kit
this one is the Pacific kit....I built it once upon a time
the old by gone days of kits.........when oddball scales were the most prevalent. one still might see them, but now a days streamlined to the normal scales.....1:32, 1:48, 1:72........and so on. this streamlining made it easier to tool new kits, and for aftermarket manufacturers to produce upgrades and photo etch embellishments, adding the extra detailing that modelers desired. now.......back in the early days of the plastic kit, rivets and panel lines weren't the norm, leaving the kit as a blank slate, for modelers to work with. as time went on, the manufacturers heard the complaints and began adding these bits of detail to their model kits. in some instances, the molded panel lines did cause some alarm......detail though that could have been added to the kit was left out. this kit is no exception.
two thing I find with this kit, is the rivet detail is too 'loud'.......the wing riveting sticks out like a sore thumb, but oddly enough, doesn't replicate over the entire model. the fuselage is mostly barren of the rivet detail and only bears the panel lines. certain detail is left out.......such as bomb bay doors and landing gear flaps, creating it more of a challenge to some, to add extra detail. the scale size is another obstacle...being a 1:92 scale kit, there is a much slimmer chance that aftermarket has produced anything for it. one never knows though the one big draw to a model for most, is authenticity. sadly, this model fell flat from the get go.........there is no such plane as Buffalo bill.....the serial number doesn't jive either. for me as a younger modeler, this really didn't matter.......I'd just slap it together and pay no mind to the validity of the subject. modeling taste has changed through the years.........and mine along with it.
older kits also suffer from use........the molds that Atlantis has must be quite old. flash is a huge problem with this model, although others may not be as bad. it can change from run to run in the production of kits. one flaw I see with it, is the injection pressure......it seemed to be out of calibration.
you can also see the injection pin marks......yea, gotta clean up some of the parts. I still plan to build the model.......I'm gonna change up the subject a bit though.
this is a good model to use as a second installment for a KG 200 collection as I mentioned, back when I built the Wulfe Hound, there were many different planes captured and flown by the KG 200. the B 17 was the most prolific plane used.......the B 24 seems to be the second in capture rate, although it wasn't used as much as the B 17. the first B 24 to have been captured, was known as the 'Blonde Bomber II', B 24D-1-CO, 41-23659, after it landed in Sicily, in 1943. there was also # 42-52106, 'Sunshine' B 24H-5-FO.......there are a few more. the kit also supplies a really neat stand.
the model can be posed in any angle by a socket and ball construction....should be neat. I've cleaned up one of the wings due to the amount of flash and odd molding. the plastic is very soft, so when trimming the parts, I need to be careful.
not really impressed with how the landing gear is done.......I wish the gear panels were open. the tire is exposed, so I might just put the tire in the well and do away with the rest. the plane is in flight if I use the stand {very good chance I will}. there was some camo.......even a mission that involved planes that were painted black {operation carpetbagger}......decals might be an issue.
these are some pictures I took of the kit earlier with another camera......just thought I'd add them. I have a kit of a B 25 Mitchel........and Atlantis also put out the 'Pacific Raiders' kit as well { keeping an eye out for that kit}. in short......I wouldn't suggest these kits to an experienced modeler....they aren't worth the effort if you want a good representative of the plane. there are many better kits out there. but if you like to experiment and bash, they would be a good candidate.
I'll have more when I start to get more into it
- Ryland Craze, Jack12477, Egilman and 13 others
- 16
I dunno Craig.........if you saw that shelf right now, you might want to run the other way! my 'active' projects outnumber the stash......I fit 13 in the shelf, and that's not all of them. of course, there are a couple that I'm just toying with, just so I don't lose my train of though with them. the room is almost done, except for one snag...........the little table is leaving. my younger son wants it........we're getting his table, so the one we have is taking it's place. it's longer and much higher, so I'll have a lot more space to work with the landlord has been having stuff done to the house, so things have been hectic here.........we've had our first heat wave too.......which adds to the situation. I finally ordered a couple of crane lamps. I may set them both up on table black, to make it more user friendly. no pictures yet.........I hope to get back underway soon
thanks for your kind comments and waiting.
- GrandpaPhil, Edwardkenway, mtaylor and 3 others
- 6
I have to apologize.......I forgot you were building this one what you did on this scale of a kit is truly amazing! the model looks fantastic.....a real testament of your skill
- Old Collingwood, mtaylor, RGL and 1 other
- 4
your not shy with the PE.....that's a good thing you must feel like your in Gulliver's world, when pin heads are larger than some of the parts your working with but it's fun, and your doing a fine job........glad I tuned in!
- Old Collingwood, mtaylor and Canute
- 3
I looked in scalemates.......no dice I have the Nichimo 1:500 Shokaku and the Hasegawa 1:450 U.S.S. Missouri...not so concerned about the Missouri, more on the Shokaku.
sounds like a good idea to try..........at present, I have issues with the printer to straighten out.
- mtaylor, Canute, Old Collingwood and 1 other
- 4
it's good to mass the goodies before the build are railings on the menu as well?
- Edwardkenway, mtaylor and Canute
- 3
I've got two kits that are in the boat as your project here.........both sets of instructions are in Japanese. do you have a solution for it? I have a friend that was stationed in Japan.....even married while he was there I have an IJN aircraft carrier that is going to be hard to paint, not knowing what colors to use...I've yet to do research......I'm hoping my friend can help me. thanks to Lou........I have a variety of IJN colors....I just hope I have the right ones
don't feel bad Craig........I work from very few reference books as well. I depend mostly on pictures and stuff from the net. the one big bugger of it all, is that a lot of the pictures are black n white. she's look'in really good........you did a great job! this one is sort of on my bucket list, since most of the ships I've done in the past are American warships.......next to nothing on other nationalities. very good idea concerning the rigging.......I was never good with it.
look'in forward seeing her finished!
- Canute, lmagna, Old Collingwood and 3 others
- 6
just be careful of what you dream........I drempt that I made some progress on one of my models...found out this morning that it was a bust! during my research of the PT boat, I read that tenders were used to move them over large distances, so these types of vessels were very important and performed a lot of different functions.
getting somewhere near normal here........the hobby room is almost functional
not enough of a focus on this era of warship........and in resin no less should be child's play for you since you seem to use a lot of CA in your projects.
I've heard that regular model cements doesn't work well for resin.......I've used it on what little resin I've used and it didn't seem to make a difference.
should be a sweet look'in model in your capable hands
I know this is still a bit off track, but the end is near I didn't get to do any work on the model, nor any other model, but it has given me some ideas with how I want the room to look. yesterday was clean out the closets day. we took a break and got food for Gibbs.....the admiral got him a couple of his favorite treats. where did he take it...........why, he made himself at home in the new room!
by the end of the day, the closet transfer was finished.......except for the shipyard. I had an idea not to toss all the kits in the closet, but I might since the 'berth' idea seems so logical. all the active projects will become centralized.......not in this closet, that closet, or out in the hallway. in the meantime, more of the stash has been added to the clutter.
today.......was the start on the 'berth' idea. we've thrown out a lot of stuff we've been hanging onto.......there still more to go my son had brought me some sheets.......best described as sawdust board........or chipboard. really not ideal stuff to work with, but then again......I don't need something that's permanent......if it does, fine.....if not I can simply break it up and get rid of it. it's 4' X 32" X16"......I may choose to build another
I'm still working on trying to get the treadmill out of here ......I still have the room for another though.
I will do my best to be up and running by the time my work week is done. from time to time, folks have asked just how many projects I have in the works. if the Berth does what it's supposed to, you'll get a good idea the next time you see it I did get a table cleared off....small wonders
- mtaylor, md1400cs, Edwardkenway and 5 others
- 8
I just finished catching up Valeriy........and I must say that I'm in awe! such fine metal work........you do some very detailed work definitely museum quality
- Keith Black, mtaylor, Valeriy V and 1 other
- 4
IJN Akitsushima by CDW - FINISHED - Pit-Road - 1:700 Scale PLASTIC - Seaplane Tender
look'in good! this is just the upper hull......are you gonna add the bottom?
