druxey
Everything posted by druxey
  1. I was lucky enough to catch the display at Greenwich. It was fascinating to see the 'new' model by Matthew Betts alongside the contemporary Erebus model. See: https://collections.rmg.co.uk/collections/objects/66676.html
  2. Spars are all proportional to each other and to the size of ship. So you should be able to re-size them to 'fit' any other ship-rigged vessel.
  3. Supplement is on sail making. Scale spar and rigging plans are in a pocket at the rear of Volume IV.
  4. A wooden horse? That's interesting. Could be a real impediment forward! Nice work as usual, Maury.
  5. Nicely shown, Mark P! These show all the intricacies of the headwork clearly. I have similar photos that I took years ago, but all on 35mm slides, unfortunately.
  6. Those chutes in your photo seem to be either side of the second head timber, not forward of the third (foremost) one. And yes, the headwork is in the line of 'drop'. However, at sea I'm sure this was washed clean! In harbour it would be a different story....
  7. You make a number of very good observations in your carving tutorial, Marc. You are absolutely correct in that you can't make something unless you can draw it (or have a drawing of it). Two small points one might add: one, directional light to cast shadows and show highlights while carving. Two, make a maquette in modeling clay to work out the piece in 3D first.
  8. I wondered for a moment what the 'Pacmen' were for! Nice progress.
  9. Your secret is safe with us - for a price! It is interesting to see the relationship between all the components making up the headwork. May I suggest that there is no seat of ease that far forward? Any gratings there rise steeply with main rail. There would be one as you have it (or even twinned ones) ahead of the middle head timber and another, as you've drawn it, in the aft outer corner between the roundhouse and main rail. I've even seen a two level two-holer in the corner like stadium seating!
  10. You have to please yourself, Gerard, but know what it is (or isn't) that you are building. Enjoy the experience!
  11. Not to pour cold water on your project, but Davis' Lexington is a fiction - a pretty one, but still a fiction. Davis' book entranced me as an 11-year old when I found a copy in my local library. I renewed the book over and over at the time. I wanted to build a framed model too! Many years later, I did, but not of Lexington. A few years back Dr. Clay Feldman did a study of what he thought Lexington really looked like. His articles appeared in The Nautical Research Journal. I can't quote the date, but someone like Kurt Van Dahm would know.
  12. Have you tried using SilkSpan paper? I've not tried limp sails, but furled ones worked out well, as the material can be re-wetted many times without tearing to be shaped as needed.
  13. Some figures were 9' 0" to 11' 0" high. Distinctly larger than life- size. Those on sixth rates were about life size. Tip the shield away a bit around to port and it will be perfect!
  14. Your version of the spear looks good. The original figure's spear would certainly have been of metal and removable. I suspect it was painted to protect it from corrosion. I might suggest the shield be ported (carried by its straps on her left arm) rather than resting in front of her. It wouldn't be much protective help like that if she were armed and going into battle! The gorgon's head would feature on this shield, as Bellona assisted in the killing of her. The chicken or rooster might be, as suggested, used for augury by reading of its entrails and sacrifice, or be perhaps a symbol of aggression (think fighting cocks). Great discussion above, too many posts to click all for 'likes'!
  15. Well, I can see how much wood you'll save at that scale - assuming you don't have to re-make too many pieces! Looks like an excellent result so far, Giampiero.
  16. You have become quite the master mason! Love the new gateway.
  17. Velkommen indeed, Gaffrig!
