druxey
Everything posted by druxey
  1. I don't think that the head was part of the beakhead platform. It was beside it at upper deck level. See: https://collections.rmg.co.uk/collections/objects/81298.html https://collections.rmg.co.uk/collections/objects/81196.html and, in particular https://collections.rmg.co.uk/collections/objects/81164.html
  2. If you absolutely have to use lead, please seal it with clear finish. With time and air it will deteriorate to white lead salts. That's ugly! If you can substitute non-lead metal such as pewter, so much the better.
  3. Yup, that's what happens to the log if not processed promptly. However, if you can access your neighbour's saw soon, that is much better! Read up on quarter sawing as well.
  4. The lines converge too much at the bow. You will have strakes that taper to points. Let the first thread above the keel end at about bulkhead 2 and space out the other threads above. If you read Antscherl's advice, you'll see that the garboard strake ends just where the stem begins to rise, which you do indicate. Aft, the strakes should spread out over the deadwood all the way down to the keel, or you will end up with splinter thin strake ends there as well. The lower edge of the garboard should be parallel to the top of the keel.
  5. If you don't cut it soon, it will split as it dries. Slab it as soon as you can. Of, course, winter cutting when the sap is down is the ideal. Now is not the best time of year.
  6. Well, the Swedish employed Frederick Chapman, son of a British naval officer, so I'm sure that there was a fair bit of trading of ideas and personnel between nations in terms of design. I'm sure that, as an Irishman, that gentleman was more than happy to design against the British!
  7. So, the truss tensioning method is what later was termed a 'Spanish windlass' I believe. Lovely work on your model. It has an air of authenticity about it.
  8. I used to have a Dumore sensitive drill press....
  9. True enough, Jim. Very few knew how to swim. But falling off the bowsprit while at anchor, unless he was unusually clumsy if he was not drunk?
  10. The best way to tell if the light is real or dummy is to see at what level it sits relative to the decks.
  11. My condolences on the loss of your favorite drill bit. Certainly outlived its expected life span, though. Glad the flag locker will now work out for you.
  12. Looking very nice, Mark. Thank goodness there's a bit of wiggle room to even out that channel wale if you need to!
  13. If it's not a gronicle, then it's a thrupple nut. Sorry, Bob; but Steel defines 'mast hoops' as follows (Rigging and Seamanship, 1794, Volume I, page 6): HOOPS are strong circles of iron driven on masts and yards. Hoops are also as Bob describes.
  14. "...he chortled in his joy! " New coping blades indeed! You have a good lady there, Steven. My own, bless her, wouldn't know a coping saw blade from a jeweler's saw blade.
  15. Glad the change worked out for you, Andy. That detail make all the difference.
  16. Very impressive that you can get such a high level of repetition using a Dremel. Thanks for explaining.
