Everything posted by druxey
I think you should be OK after the first casting or two, when things have warmed up. Don't pour too slowly - be intentional! Certainly talc will help flow.
And, of course, the excess metal is completely recyclable for the next casting....
Catching up with your progress, Maury. Coming along nicely. Glad you decided to modify the metalwork.
In addition, make the filling vent area larger: the weight of the head of metal will help ensure good filling of the mold.
Item: the moulding along the knuckle of the junctions of the counters should be 1" below the lower counter plank as a drip edge. You can see this feature on contemporary models if you squat down! Your illustration is above incorrect. Also, the upper surfaces of the mouldings are parallel to the sheer, not the decks. If this is not the case, you will end up with an ugly joint at the corners with the quarter galleries!
Much nicer belaying pins! I do hope you paint them to look like wood, though.
- 87 replies
- royal caroline
- yacht
Unusual cutaway! I've run out of superlatives....
- 589 replies
- le gros ventre
- cargo
Welcome, Romulus! Modelmaking will help pass the time for all of us. Here in North America the performing arts are also shut down. It's very frustrating for all the artists preparing for the summer season. I can sympathize with your situation. You'll find lots of help when you need it here.
Well, at least someone was prescient....
A pretty sophisticated set-up. Great if you are making large numbers of spars. However, for the small number most models need....
Nice clean work, Andy! Don't get me started on thrown out archives. I once worked for a Toronto company - no longer in existence - whose library was assembled in the 1900-1930's time period. There were art books galore (it was an advertising company) and mementos of folk who once worked there. Canadian readers will recognise The Group of Seven, many of whom had been employed as illustrators there. All were thrown in a dumpster in the mid 1980's....
I'm no expert on the details of these pumps, Jim. However; There appears to be a shut off valve both at F and to the left of G. The tubes to the limber strakes seem to be for flushing or emptying the bilges when required. There would be no logical reason to have a blind end to them. One variation (left side) has the tube simply pointing down to the bilge to flood it when turned on, and the other version (right) has a two-way diverter. Note also the second valve down the tube nearer the bilge end on that side. When there is water in the bilges, it can be drawn up by suction in the usual way that brake pumps work using flapper valves.
Cruizer-class Brig-Sloops of the Royal Navy
druxey replied to molasses's topic in Nautical/Naval History
Often the upper strakes of planking below the wale were top and butt or anchor stock as well. No easy to see, but: https://collections.rmg.co.uk/collections/objects/83495.html as well as the Cruizer class planking expansion you mentioned. -
Yes, Carol took my isopropanol bottle. However, I had another one stashed away, (not for medicinal purposes only) heh heh!
Keith, it's obvious - now! With all due respect to your talents, I agree with wefalck: those lateral supports take the eye away from the model. Perhaps lower them or even substitute clear acrylic would make them less obtrusive. I hesitate to be critical of your superb work, but....
I'm sure that you will complete her rigging to the same standard - or even better!
- 1,035 replies
- royal katherine
- ship of the line
Steel wire or hemp rope on Thames sailing barge circa 1940?
druxey replied to bolin's topic in Masting, rigging and sails
A caveat to Bob's post: in the early 1940's steel was in great demand for the war effort and would have been in short supply for other purposes. In London, for instance, miles of iron railings were torn up to be recycled for the war effort.
